How do you program a simple comfort AM7890-DHW thermorstat
Does anyone have a manual that they can email me? thx.
    Problem Solver:
  • 12 Answers
Have you already searched the manufacturer's website?
Posted on Mar 06, 2016
3 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: I am looking for the
Please look this video which may help you. Thanks.
http://www.youtube.com/watch?v=fEppTCPBkOU&feature=related
Posted on Jan 08, 2011
SOURCE: Hi i have a simple
We're having exactly the same problem. I called ICM at 1-800-382-3113 and asked for tech support and they emailed the 2-page manual right away. I talked to Eric Wood, an Electrical Engineer there, and he sent it immediately. I hope this helps!
Posted on Apr 07, 2011
I am wanting to wire a Baxi 105E boiler to a Danfoss 102 mechanical timer. The boiler has 5 wires = red, blue, earth, black and yellow. The Timer has six terminals = 1 DHW, 2 HTG, 3 COM, I (earth), 5...
1) Contact baxi:
http://www.baxi.co.uk/contact.htm
2) Which boiler wires? I don't know. Page 24 manual.
Manual says to disconnect link between terminals 1 and 2, and instert timer in-line.
http://www.acwilgar.co.uk/Boiler-Manual-PDF/Baxi/Combi%20instant%2080E%20&%20105E.pdf
2) I can tell you about the timer wiring.
Timer is 230Volts
Not sure if you have British Hot-Neutral 230Volt, or Hot-Hot 230Volt.
Wiring is same 2 wires, but words to describe are different.
Let's say you have Hot-Neutral 230V
Connect Hot to L6
Connect Neutral to N5
This will power the timer so it runs and keeps time.
You can get Hot-Neutral wires from Hot-Neutral that arrive to power the boiler.
Now the timer terminals are separate.
E terminal is Earth or ground.
The Common is Hot wire.
The timer then turns on-off and switches back and forth between DHW and HTG.
HTG is heating
DHW is defrost.
Timer has 2 sets contacts.
When timer activates first set of contacts, then DHW defrost terminal receives power from Hot wire on Com terminal. At this time, all power is cut to HTG heating terminal.
When the defrost cycle ends, then the heating circuit receives power, and then the timer has programming that opens and closes a second set of contacts going to HTG heating terminal.
Which wires from boiler connect to each terminal, I am not sure.
Feb 03, 2013 | Hardware & Accessories
Hi i have a simple comfort AM7890-DHW thermostat and my condo is just cooking. I know that the two settings are for heat and cold to kick in and i have them set properly but it still is not fixing the...
Apr 02, 2011 | Heating & Cooling
Lost ozark trail wmt 1390 tent manual
I have a copy of the Ozark Trail wmt-1390 tent manual. It is in pdf format. Just email me for a copy.
Mar 26, 2011 | Sport & Outdoor - Others
I have a York T710 Platinum series treadmill and have lost the manual. Treadmill needs a little maintenance. does anyone know how I can download a manual for this
hi , i have most manuals what is it you need to know
please email me on x.celfitness@live.com
and i can send you the manual
Kind Regards
Joe
Apr 05, 2010 | York Yankees Bedding MLB Comforter
Can't get my Simple Comfort 7890-DHW thermostat to set on heat. Tried the mode/program and have made it worse.
Push up or down arrow once. H will flash, this is heat setting. Set your temp. Then C will flash, this cool temp. Set your cool temp. After short delay stat will go back to display room temp. Red light heat is on. Green light cool is on. Hope that helps
Mar 24, 2010 | Honeywell Electronic Programmable...
Innovage lcd touch panel phone
hi found a link to a user manual, its very hard to read it, very small writing and not to clear but got basics of phone working, still need to find a hard copy of user manual thx
Jun 23, 2009 | Innovage Speaker/Caller ID* LCD Touch...
Honeywell T8400B Thermostat Display Intermittently Blank
most likely a bad tstat i would replace I recommend honeywell focus pro 6000
Jan 29, 2009 | Heating & Cooling
Ariston micro genus combi boiler central heating works okay but domestic hotwater fails to rise but burners seem to be lit and the boiler doesnt appear to cycle dhw temp gets to about 30 degrees instead of...
having found a circuit diagram, realised that the divertor valve was electrically operated.i unplugged this then unclipped the motor from the valve body,the diverter valve is spring loaded and once i'd removed the motor the spring raised the valve to divert water through the dhw heat exchanger,giving us hot water but no heating, if i refit the motor the problem comes back heating no dhw.ordered new motorised valve assembly £30 next day order .
this was a simple fix without having to drain the system down.
Dec 07, 2008 | Heating & Cooling
Heating & Cooling Logo
270 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
