Question about Garmin nuvi 350 GPS Receiver
GARMIN C330 my c330 starts i get a message (do you realy want to erase all user data) no does nothing ,yes restarts and returns to same message
I TOOK THE UNIT OUTSIDE TO GET BETTER
SATELLITE COVERAGE
Posted on Jan 25, 2009
Erase hard drive on Sharp AR-C330 Copier
any printer has a spot on your computer that saves data there yes you can erase it
Sep 26, 2012 | Sharp AR-C330 Color Copier
C330 garminstreetpilot not working
hey man your prob is so simple just go through this
1.connect your device to computer
2.go to my com
3.right click on your device
4.click format
5. then restart it now its time to update driver
right click on computer then
1. click properties
2.hardware
3.device manager
4.universal serial bus controller(open the + sign)
5.click upper one double click
6 go to driver
7.click on the update driver
8. then choose second one (advanced) then next
9.click don't search
10.then next next if it is over
same process with anotherone then restart your computer a
Nov 18, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 says trouble tracking satelites, not acquiring signal. what to do?
If your StreetPilot c300 or c500 series device is no longer acquiring satellites please read the article linked below to ensure that this is not being caused by something in your environment:
Why won't my unit acquire satellites?
If after reading the above article your unit is still having problems, please ensure that your unit's software is up to date. You can do this by using our WebUpdater® program.
If you have tried all of the above suggestions and your unit is still not acquiring satellites, you can perform a master reset by doing the following:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit powered OFF and unplugged from power.
  2. Touch and hold the bottom right corner of the touchscreen.
  3. Power the unit ON and continue pressing the screen until a new message displays, "Do You Really Want To Erase All User Data?".
  4. Touch Yes and go through the set up again.
Take the unit outside and let it set with a clear view of the sky for 3-5 minutes to acquire satellites. If the unit still does not acquire satellites after this, please contact Garmin Product Support.
Nov 17, 2010 | Garmin StreetPilot C330 GPS Receiver
My Garmin C330 won't turn on.
This is likely a failed battery.
The battery on these units is not user-replaceable (soldered to the PCB) and must be returned to Garmin for repair.
CLICK HERE to see more about their FLAT RATE repair service.
Your StreetPilot C330 is listed as a $79 flat rate repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 17, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin streetpilot c330 can't find satelite
The Garmin c330s will have trouble acquiring satellites as the batteries wear out, which usually happens around 15 mo. Batteries are soldered in, so replacement requires sending it in to Garmin. I've seen some reports from users who had this problem right out of the box or shortly after purchase.
You May try
No.1
You can try both a normal reset or a master reset and see if either one works for you.
The normal reset button is behind the front bezel. You access it by using your thumbnail under the top part of the bezel and carefully pull the bezel off. Once off you press the reset button on the right side of the front face labeled reset.
Option #2 - Master reset, will lose all data.
With the unit off, use a pencil eraser to depress the bottom right corner of the screen while turning the unit on. Once on, let go of the on button and keep the lower right screen depressed and answer yes to do you want to reset unit and lose all data. Once reset you must allow the unit 45 minutes of good reception to reload all satellite data, moon data, time, etc...
Sure this would help .
God Bless.
Jul 08, 2009 | Garmin StreetPilot C330 GPS Receiver
POS Garmin Streetpilot C330.... HELP REQUESTED!
I think this one is a return to seller or send to Garmin.
Jul 05, 2009 | Garmin StreetPilot C330 GPS Receiver
Cannot take Garmin c330 apart to change battery
The internal battery on a C330 is not user replaceable. You will need to return the GPS to Garmin to have the battery changed.
Apr 04, 2009 | GPS
Frozen screen on ''aquiring satelite''
Try resetting the I5. Hold the left button, the wheel button and the power button down at the same time. Keep holding until the screen say that " Do you really want to erase all user data?" Select Yes and then restart the I5.
Nov 11, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 no map data available
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench,
then press Map, then look for Map info.
This will show the the current map version installed
Jan 12, 2008 | Garmin StreetPilot C330 GPS Receiver
Names of states, lodging, food, fuel etc. data base missing in US.
Just replying to this to remove it from the unsolved answer category. As I'm sure you know, the C330 comes with just a small set up guide, not the manual. The manual is available on Garmin's web site. I'm sure this is not covered in the manual though, as it is not a problem most users may encounter.
Nov 27, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
18 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
