In need of a driver for my system. Driver disk that came with it doesn't work and I'm assure what to do. Had error messages when installing like: Unable to launch C:\Windows\Options\Install\DeINF.exe And Unable to launch C:\Windows\CleanDev,exe Went to folders and couldn't find either file. Can't find them on the CD either. Not sure what to do, and don't want any of those driver programs because I've used one and it hasn't helped, it's only screwed up my computer further.
Click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam Click start control panel administrative tools computer management device manager scroll down image devices you could see a yellow question mark? right click to reinstall drivers or update driver xp Click start right click on computer select properties device manager scroll to image devices expand right click to update driver in W7 http://download.cnet.com/2000-20_4.html on the home page you should see a search tab just type in what you are looking for IE: webcam name webcam driver you might have to try a few times to get it right software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 It might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated Some webcams and programs require additional software, although that should be installed with the webcam if things are right. But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date. But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing. Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10). http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer Hope this helps.
SOURCE: Unable to install the GE MiniCam Pro HO98756 with Vista
Install driver from the link below
http://www.jascoproducts.com/products/pc/viewCategories.asp?idCategory=14
SOURCE: Can't get my GE Easycam pro, model #ho98064 webcam to work
down load split cam and install it from the site mentioned below run the software then connect your pc , open split cam from the progrrame, in split cam icon choose usb cam your cam shall work,
http://www.giveawayoftheday.com/freeware/usb/webcam-driver
thank you ,
domnickr
Yes, all hardware devices need 64-bit drivers to work on a 64-bit version of Windows. Drivers designed for 32-bit versions of Windows won't work on computers running 64-bit versions of Windows.
Description: This file contains the Epson Stylus NX230 Printer Driver v6.91. The Epson Status Monitor 3 is incorporated into this driver.
Compatible Systems: Windows 7 32-bit, Windows Vista 32-bit, Windows XP 32-bit
Your instructions aren't really all that clear at all. I already have Direct 11&10 installed, that's not the problem. I said the problem was the Drivers. The website you provided wasn't really any help at all. I know how to update drivers and everything, the problem is that windows isn't recognizing the drivers I have for it, nor the inf.
You can update the drivers in two ways, either by running the Windows update manager in your PC or by installing directly from a driver downloaded from the laptop manufacturer's website. After installation, and rebooting your PC, the webcam should be functioning fully, both recognized and usable. Run the "Add a device"application, accessed by clicking on the "Start" button, opening the "Control Panel," and then double-clicking on "Add a device." The "Add a device" window will open and Windows will search for devices connected to your system but not installed. Click on the webcam name that shows in the search box and then click "Next." Choose whether you want Windows to search for the webcam device driver using Windows Update over the Internet, or if you'd prefer to have the device manager search for the driver using a disc supplied by your laptop manufacturer Most drivers can be found on the system recovery disc included with your laptop, if you choose to add the driver from the provided disc. Place a check in the box next to your choice and then click "Next>" to continue. An active Internet connection is required for Windows to successfully do this. Allow the computer to install the driver and then reboot the system for the webcam to become recognized by the system.Otherwise, you can use the system recovery disc or a driver downloaded directly from your laptop manufacturer to install the driver without using the Windows Update search feature. Open the CD/DVD-ROM drive and insert the system recovery disc, or place the driver downloaded from the manufacturer in an easily accessed file directory on your PC, such as on the desktop, or in your "My Documents" folder.Choose the option "Install the software automatically (Recommended)" in the "Add a device" application, and press "Next>" to begin searching for your webcam driver.
http://www.jascoproducts.com/support/dow... manual ,http://www.jascoproducts.com/support/sof... - pccams drivers if these dont fix the problem ther could be a problem with the webcam power lead
