E03 Paper remaining inside the equipment at power-ON.
Open the cover of the unit/area whose picture is blinking on the control panel. Is there any
paper on the transport path?
Remove the paper.
Power-ON jam:
The paper is remaining on the
paper transport path when power is turned ON.
1) Check if the connector of the sensor is disconnected.
2) Check if any of the connectors on the MAIN board is disconnected.
3) Check if the connector pins are disconnected and the harnesses are open circuited.
4) Replace the sensor.
5) Replace the MAIN board.
just check propely any small piece of paper is in machine or any sensor in paper path is disturbed check all sensors and there levers .or take a hard file cover and from bypass with ur hand pull it in copier and send him to toward exit tray .just off copier first and do this .
