Tray not ejecting when unloaded
The tray will not open when there is no disc in it. However, it will eject if the sliding locking-rod type thing is gently pushed forward from behind by my finger (on the right hand side of runner of the tray, towards the back). Not sure if this is the motor having lost power over time, or wear on the mechanical parts. Any advice would be greatly appreciated
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 109 Answers
Yeah it sounds like time to let that bad boy go - they are pretty cheap now and you can get one for about $30.00 and they are easy to install.
Posted on Jan 16, 2013
  • 93 Answers
SOURCE: CD tray got knocked off track
You can try to fix mechanics by takin apart cd, remove tray and try open/close operation WITHOUT tray. Leave it as OPEN, then try to place tray back in fully open position, but be careful, you have to pres OPEN and then unplug it from outlet to avoid electric shock risk. BE CAREFUL!!!
Posted on Oct 04, 2007
  • 6 Answers
SOURCE: Numark CD mix 3 right cd door seldom opens
Defective load belt or defect in laser assembly
Posted on Dec 14, 2008
  • 165 Answers
SOURCE: faulty eject tray
hello you have a dirty switch on erratic use clean or change it
this switch is usually under the main drawer saludos
Posted on Jan 08, 2009
  • 165 Answers
SOURCE: Drawer opens when the player is switched on
hello marc you have a dirty laser,blocked sensor or even a misaligned condition try this clean the lens put a disc and turn it off with the tray inside wait about a minute and turn it on saludos
Posted on Jan 11, 2009
SOURCE: Numark Axis 8 Problem, does not recognize any CDs
where can I locate a tech in az?
Posted on Jan 03, 2010
I have satellite C50D-B-10q. How do I open the CD/DVD drive?
Removing discs
To remove the disc, follow the steps as detailed below:
Do not press the eject button while the computer is accessing the optical disc drive. Wait for the optical disc drive indicator to go out before you open the disc tray. Also, if the disc is spinning when you open the disc tray, wait for it to stop before you remove it.
1. To pop the disc tray partially open, press the eject button. Gently pull the disc tray out until it is fully opened. When the disc tray pops open slightly, wait a moment to make sure the disc has stopped spinning before pulling the disc tray fully open.
2. The disc extends slightly over the sides of the disc tray so you can grasp it. Gently lift out the disc.
3. Push the center of the disc tray to close it. Press gently until it locks into place.
How to remove disc when the disc tray will not open:
Pressing the eject button will not open the disc tray when the computer power is off. If the power is off, you can open the disc tray by inserting a slender object (about 20 mm) such as a traightened paper clip into the manual eject hole near the eject button.
Manual eject hole:
Turn off the power before you use the manual eject hole. If the disc is spinning when you open the disc tray, the disc could fly off the spindle and cause injury.
See page 4-8 of the user manual:
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=11&cad=rja&uact=8&ved=0CB0QFjAAOAo&url=http%3A%2F%2Fwww.mytoshiba.com.au%2Ffile%2Fdownload%2Fresource%2Ffile%2F25248%2Fsatc50-satpro%2520c50%2520userguide.pdf&ei=hP8qVL7FH8jygwSZtIDwDw&usg=AFQjCNG3BeuYjMmp05rKf6DHmKe2CwfZxQ&sig2=5VtO-__wyjN_V8vBe9na3g&bvm=bv.76477589,d.eXY
Jun 05, 2015 | Toshiba Computers & Internet
CD deck
That means that there is a mechanical error concerning the tray gears
Oct 11, 2008 | JVC UX-S57 CD Shelf System
What is the proper procedure for opening the dvd drawer on a gateway ne 522 laptop
Locking device or software installed First, verify no locking software is being loaded that prevents the tray from opening. If you are unable to determine this, reboot the computer and as it is booting up, eject the tray. If the tray is able to eject as it is booting, but stops working after loading Windows or your operating system something is being loaded that is preventing the drive tray from opening. This is most commonly software such as a CD burner program that has taken control of the drive.
Bad eject button If you are running Microsoft Windows open My computer, right-click on the disc drive icon and choose the option to eject. If this ejects your CD-ROM drive tray, the button on the disc drive is defective and it is recommended that the drive be replaced.
Jan 06, 2014 | HP Computers & Internet
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Ejecting a Stuck CD in Mac OSX
  • First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
  • If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
  • Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
  • If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
  • Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
  • Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
  • Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
  • Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
  • Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
  • If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Sep 17, 2010 | Apple iMac G4 Desktop
Tray for dvds will not open on philips mx 5000d surround system
first try to eject the tray from windows Right click on the drive icon and seect eject, it will tr to open,, but if this dont work then
turn off your computer and locate a tiny hole near eject button insert a pin in it and press " There is lock inside the pin will release the lock" and tray will come eject...
This happens because there is a rubber belt inside attached with the motor which opens the tray as we press the eject button,and that belt is loosen up, all u can do replace the small belt and problem will get solve.
Apr 13, 2010 | Philips MX5000D System
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
I can't eject a dvd from my mac pro desktop
Try these tips.....usually holding down the touchpad buttton while tapping the eject button during bootup works.
picexporterror Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
picexporterror If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
picexporterror Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
picexporterror Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
picexporterror Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
picexporterror Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
picexporterror Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
picexporterror If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
Oct 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
My cd is stuck in macbook and is not being read by my computer it only makes a funny sound when i reload it
A CD or DVD disc can become stuck in your Macintosh. It may not be appearing on your desktop or could be causing the computer to lock up if the computer cannot recognize it properly.
[edit] Solutions
Sep 30, 2009 | Apple iBook G3 Clamshell (M2453B) Mac...
DVD will not eject the tray
Open up the unit find the load and unload motor on the DVD carriage and turn it manually and this should eject the tray. You may even have to unscrew the carriage to get to the bottom of it to access the load and unload motor.
Jun 21, 2007 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
 Grubhead
Grubhead
