Question about CVA Optima .50 Caliber Muzzleloader
Need a hammer assembly for a cva optima 50 cal
Anyone know where to get one since optima does not have parts for these guns now
I was told there was no such thing as Benjamin Franklin mod 312 Ser h322837 but is in enshrined on the barrel, I need to know
Definitely exists and looks collectible.
  • Benjamin Franklin 312 .22 ' Gun Values Board www.gunvaluesboard.com/benjamin-franklin-312-.22-2923214.html My father has a Benjamin Franklin , model 312 .22 cal. Lever pump rifle , ... A Benjamin 22cal air rifle with a ser ... .22 cal Mod. 312, ...
  • i have a benjamin franklin 312 air rifle with no serial ... https://answers.yahoo.com/question/index?qid=20110411133733AAHQmgM
    • RESOLVED
    • 4 POSTS
    • 3 TOTAL ANSWERS
    2011-04-11 · I have a benjamin franklin 312 air rifle with no serial numbers on ... What you have is a Benjamin model 312, ... I have a benjamin franklin 312 air ...
  • Advice on what to do with Benjamin 312? - Airguns & Guns ... www.gatewaytoairguns.org/GTA/index.php?topic=25607.0 Advice on what to do with Benjamin 312?, ... Benjamin Pump mod. 397 ... SE CT; Beeman C1 .177 Daisy 230 (Milbro)
  • Related searches for Benjamin Franklin mod 312 Ser h322837
  • I Have A Benjamin Franklin Model #312 - Lever Pump Air ... www.gunvaluesboard.com/i-have-a-benjamin-franklin-model-312...rifle... I have a Benjamin Franklin Model #312 - lever pump air rifle in .22 cal. The stock is broken & I would like to get it fixed. ... A Benjamin 22cal air rifle with a ser ...
  • Benjamin Franklin Brass Mod 312 22 Cal Pump Pellet Rifle ... www.ebay.com/sch/sis.html?_nkw=Benjamin+Franklin+Brass+Mod+312+22... Find best value and selection for your Benjamin Franklin Brass Mod 312 22 Cal Pump Pellet Rifle Gun For Parts search on ... Benjamin Franklin Air Rifle for parts . $ ...
  • Item:8679966 Benjamin Franklin 312 AIR RIFLE PARTS .22 For ... classic.gunauction.com/search/displayitem.cfm?itemnum=8679966 Seller's Description: Benjamin Franklin 312 AIR RIFLE PARTS .22 Nice old Benjamin 312 barrel, receiver and stock Pumps air okay but there is no way to release it as ...
  • benjamin franklin 312 - Airguns & Guns Forum www.gatewaytoairguns.org/GTA/index.php?topic=37115.0 benjamin franklin 312, Air guns, Airgun Forum ... 2 RWS mod. 48s, 177, & 22 2 Benjamin Marauders 22, & 25 Benjamin Trail NPXL1100 Benjamin Pump mod. 397, ...
  • Benjamin 312 strip, tear down & dis-assembly - YouTube www.youtube.com/watch?v=W1_DGNaaAs0
    • BY NORTHWESTAIRGUN
    • 17 MIN
    • 45K VIEWS
    2014-02-06 · Video embedded · Video of the dis-assembly of the Benjamin, or Benjamin Franklin, model 312. This is similar to the model 310, 317, 342, 347, and ...
  • Ben franklin air rifle mod 312 parts diagram - fnsxowf.gq fnsxowf.gq/zeuimpooku I have come across a Benjamin Franklin Mod.340 Cal.Buy Benjamin & Sheridan ... Benjamin Franklin 312 Pump air rifle.New airguns and vintage are available in our ...
  • Need A Repair Kit For A Benjamin Air Rifle Model 312 ' Gun ... www.gunvaluesboard.com/need-a-repair-kit-for-a-benjamin-air-rifle... need a repair kit for a benjamin air rifle model 312 ... I bought an old Benjamin air rifle model # 312. ... I have a Benjamin Franklin Model #312 ...
  • What is my Benjamin Franklin model 312 cal 22 h148881 man in USA
    May 20, 2016 | Optics
    Cva optima .50 cal hammer won't lock back
    Try pushing the trigger forward while cocking it, if it locks it's probably a bad trigger spring. Remove the hammer/lock assembly, it's only two screws, and have a look inside. The lock is very simple and should become obvious once you're in there.
    Oct 14, 2015 | Cars & Trucks
    Does anyone know where I can find a schematic diagram of a 1891 Marlin Safety 32 cal. lever action. Parts list,owners manual,photocopies okay. Patent information?
    Jack First, Numrich Arms and the Gun Parts Co all have parts drawings but guns didn't come with manuals and break downs until after WW-II.
    Feb 11, 2015 | Optics
    Need diagram of trigger assembly for CVA OPTIMA MUZZLELOADER RIFLE
    go to www.ehow.com it has the assembly for everything i use it all the time. if that doesnt help let me know.
    Mar 30, 2012 | Optics
    Cant assemble my makita battery gun i need a diagram
    go to makitausa.com and you can download a parts schematic. You will need your model number for this. Let me know if you need more assistance and if you do I need the model number also.
    Oct 13, 2011 | Makita 18 Volt Cordless Hammer Drill Kit ...
    I need help reassembling my Crosman 1088....I had to take it apart for repair now im having trouble figuring out how the hammer mechanism goes back together correctly....I have the exploded view and parts...
    Well.. it's really rather late, so I don't know if you're still trying to put the thing back together, but I was just having issues getting the hammer assembly on mine to work..
    Going from this parts list: http://www.shans2003.ru/Article/pi_Crosman_1088-EVP.pdf
    Assuming you had the same problem I did:
    Start by putting the trigger assembly in (parts 37 and 40, the shorter pin on 40 goes through the holes on 37 as shown in the diagram)
    Then insert pin 28 in to the hole that's right at the crook where your thumb rests.
    Then part 35 goes over that pin with the little tiny nub pointing towards the back of the gun.
    Spring 36 goes over that nub, and slides against the flat spot in the frame.
    Pin 27 will then be placed in to the hole just above the hole for pin 28.
    Then slide the hammer over said pin. now comes the tricky part. You will need something of moderate length, extremely thin and decently strong, I used an exacto knife. Use your tool of choice to press part 35 back, compressing the spring and push the hammer against the frame.
    The two pins on the hammer should be in position such that the hook on the trigger assembly, and the crook on part 35 rest against them.
    Once you have that done, keep holding the hammer in place, hook the spring hanging from it over the pin set in the frame. (should be pretty clear which one. and then re-assemble the rest of the gun.
    Be warned spring 29 does not like going back in. you will likely feel like you need 3 hands (one for the hammer, one for assembly 60/spring 29 and one to put the frame back on.
    Hope it helps.
    Nov 10, 2009 | Sport & Outdoor - Others
    CVA Optima .50 Caliber Muzzleloader Logo
    15 people viewed this question
    Top CVA Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    Mark Campeau
    Level 1 Expert
    Are you a CVA Optic Expert? Answer questions, earn points and help others
