Question about Advantech Computers & Internet
Sata cable between Raid controller and HD - Advantech Computers & Internet
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Advantech Master
  • 2,226 Answers
Gose in one way one to the board and one to the hd one power plug as well to the hd only
Posted on May 27, 2014
5 Suggested Answers
colliewob
  • 781 Answers
SOURCE: sata hard instalation
Do you have an IDE hard drive fitted as well.
If so remove it as I have found out that unless setup properly IDE and SATA do not mix
Posted on Nov 04, 2008
  • 63 Answers
SOURCE: M7NCD ULTRA raid drivers
If the SATA drive is operating in 3.0 Gbps mode and your motherboard can only support 1.5 Gbps mode, the drive will not be detected in BIOS or XP. Try jumpering the drive to SATA 1.5 Gbps mode. The label on your hard drive should indicate which pins should be shorted to achieve this setting; if not, look up your particular model on WD's website to find the manual.
Posted on Nov 19, 2007
colliewob
  • 781 Answers
SOURCE: SATA Drive on MSI K8T Neo MS-6702 Ver 1.0
I believe when first installing windows it asks you to press F2 if you want to load sata drivers
Have them handy and follow instructions
Posted on Sep 19, 2008
  • 13 Answers
SOURCE: XP is Not Recognizing Sata H.D. and I Need a RAID Controller Driver
This one should be right for you, remember to put it on a floppy, since XP needs a floppy for a 3rd party driver during install.. good luck!
http://download1.msi.com/files/downloads/dvr_exe/sis_sataraid_floppy_mb.zip
Posted on Jun 02, 2009
Having trouble booting two Raid-0 discs on Asrock Z77 Ex4 UEFI
RAID implementations will vary from controller to controller, and even from bios to bios revision or version for the same controllers.
You should "image" the raid on the old board, then delete the raid on the old system.
In the new system, you need to treat these drives like they are new, blank hard disks. Any partitions will need to be removed, and the RAID created on the new board. Once this is done, you can use your partition imaging software to drop the data back onto the new RAID partition. Seagate I believe has imaging software available in Seatools, or you can use something like Acronis True Image or GHOST.
May 16, 2012 | Computers & Internet
Hitachi 1Tb SATA HD installation for Acer Predator Sniper G7700
you say you have RAID formation?
can you specify which RAID you are supposedly using?
are the other drives in this RAID exactly the same?
Oct 17, 2009 | Computers & Internet
Jun 02, 2009 | MSI 661FM3-V Motherboard
Cannot install winxp
I am aware your motherboard has just two sets of sata pins ( only two hard drives can be used )
Have you flashed your bios to latest one ?
Sure your cables for sata are not damaged ?
Are you sure the sata drives are in working order ?
Aug 07, 2008 | ASUS P5S800-VM Motherboard
Sata raid config
first check your bios & see what raid chips are enabled,usually there's 2. Your main raid is on the first 4 sata connectors, the other chipset probably controlls the remaining sata ports. So if there's an option to disable one raid chip,disable one,just not the one that you're using. I don't know what your bios screen looks like,so this is just a general view based on my experences with various boards,mainly asus.
Jul 13, 2008 | Abit AW9D-MAX Motherboard
I cant install my hdd sata
Under many cases, the default settings for additional onboard SATA/RAID controller could have been set to [Disabled] when delivered. This will cause the controller to stop its function completely. Suggestion: Please refer to your user’s manual for detailed description on how to enable onboard SATA/RAID controller via adjusting jumper or BIOS settings. Clean SATA cable with a couple cotton sticks lightly dipped into alcohol. If you sitll can not see the SATA drive from within the bios your onboard SATA/RAID controller is defective. Contact Asus tech M-F eastern time at: 812-282-2787. Tech will assign you a case number. Tech will than connect you to the RMA department for replacment/repair.
Jan 09, 2008 | ASUS K8V-MX Motherboard
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
Nov 05, 2007 | Biostar M7NCD ULTRA Motherboard
Computers & Internet Logo
37 people viewed this question
Top Advantech Computers & Internet Experts
Rajendra Singh
Rajendra Singh
Stan Ford
Mishan Kasiparsad
Are you an Advantech Computer and Internet Expert? Answer questions, earn points and help others
