Question about Universal Kreepy Krauly In-Ground Pool Cleaner
Kreepy Crawler won't lay flat in pool while working
3 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Kreepy Krauly In-Ground Pool Cleaner: my creepy crawler wont hammer...
This usually happens when there is a small stick jambing in the bottom of the openning in the Kreepy Krauly where it sucks in the water and rubbish. It is the rubber tube that has a ****, usually something is jambed in the **** to prevent it from thumping.
Posted on May 25, 2010
jharwell668
  • 640 Answers
SOURCE: My Kreepy has a Starfish
If the cleaner is getting stuck on objects (steps, ladder, corners, benches, etc), you need to remove the dive float restrictor and install a wall climb adjuster. It is part number K12065. Anyone that sells Pentair products should have one. This will keep your pool cleaner from becoming stuck. It might also help with the seal problem, but that is most likely something caught in the flapper. Check to be sure that the pool cleaners getting proper flow and that the flapper is clear of debris.
Posted on Jul 27, 2011
I have a 20X40 rectangular liner pool and my kreepy krauly stays in the deep end of the pool. I think I need to adjust the weights. Where should the weights be placed?
The first weight from the cleaning head should be adjusted so the Kreepy sits flat on the floor with the system turned off. Then you can start moving the next weight until it starts climbing the hill to the shallow end. It may take a few times but if you get the weights set correctly it should work.
Aug 17, 2011 | Universal Kreepy Krauly In-Ground Pool...
Our kreepy has a beige paint like film all over it and it's not kreeping anymore. Nothing is stuck inside of it. Any ideas as to why it has this film/stopped working? I have it soaking in vinegar and...
sounds like something caused your water to precipitate scale. high pH or alkalinity coupled with an elevated calcium hardness may do that. make sure the footpad is in good shape, should have visible groves, if it's completely flat get a new footpad.
Aug 13, 2011 | Universal Kreepy Krauly In-Ground Pool...
My Kreepy has a Starfish seal on it. It is being used in a pebble tec pool. I bought it new less than a year ago. Here are my problems...The Kreepy is getting stuck by my stairs (they are more like...
Jul 09, 2011 | Universal Kreepy Krauly In-Ground Pool...
Can't get my creepy crawler to work in my pool, i have a purex triton filter system, i can't get any suction on from the crawler
It sounds like your automatic pool cleaner might have a leak that is causing the pump to lose its prime. Check the hose to make sure that there are no leaks or cracks. Check the vacuum connection. It should be submerged so no air enters the system. Look and check the pump basket lid for looseness, cracks, and worn or missing O-rings.
Feb 26, 2011 | Universal Kreepy Krauly In-Ground Pool...
I put the eyeball diverter on my pool and the cleaner runs up to it and the hose hangs on it. I keep my hose laying out strait when not in use. It does seem to stay on the sides also.
If the eyeball diverter is not working, you might need to install a wall climb adjuster (Part #K12065). This will keep the automatic pool cleaner on the pool's floor and walls and away from pool obstructions. Make sure the narrow end of the wall climb adjuster points down to the drive tubes.
Aug 23, 2010 | Universal Kreepy Krauly In-Ground Pool...
May 16, 2010 | Universal Kreepy Krauly In-Ground Pool...
My creepy crawler wont hammer
You need to check in by the flapper for obstruction and check inside the tubes also. Provided the water flo is good. If this does not help you need to work backwards to the pump to look for the problem. Usually if you put a small sponge in the suction pipe and it does not come out in the pump basket then your problem is somewhere in the suction pipe.
Apr 10, 2010 | Universal Kreepy Krauly In-Ground Pool...
Hi my kreepy krauly wont stay flat on the bottom of the pool???
Do you have any hose weights fitted to the kreepy hose? If you do,take it off and see if it makes a difference.Is this happening while the kreepy is operating?
Nov 21, 2009 | Universal Kreepy Krauly In-Ground Pool...
My kreepy krawly stays on the side of the pool and wont clean the bottom.I have placed the weights in the correct position. Any suggestions?
Try no weights.
Try weights in a incorrect position.
How is the hose....is it flexible......is it steering it to the sides and keeping it there?
Sep 30, 2009 | Universal Kreepy Krauly In-Ground Pool...
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
70 people viewed this question
Top Universal Pool & Spa Experts
Bill Jordan
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
