How do you program a simple comfort AM7890-DHW thermorstat
Does anyone have a manul for this thermostat?
3 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: I am looking for the
Please look this video which may help you. Thanks.
http://www.youtube.com/watch?v=fEppTCPBkOU&feature=related
Posted on Jan 08, 2011
SOURCE: Hi i have a simple
We're having exactly the same problem. I called ICM at 1-800-382-3113 and asked for tech support and they emailed the 2-page manual right away. I talked to Eric Wood, an Electrical Engineer there, and he sent it immediately. I hope this helps!
Posted on Apr 07, 2011
Simple comfort thermostat
most thermostat are plus or mines 5 degree for turn on or off
Jan 29, 2018 | Cars & Trucks
Have you already searched the manufacturer's website?
Jan 16, 2013 | Heating & Cooling
Simple comfort 2200 thermostat not working properly
We have a Simple Comfort 2200 Electronic Thermostat and last night it quit blowing cool air and the # sign beside the air temp (the set to temp) starting blinking
Aug 11, 2012 | Heating & Cooling
Hi i have a simple comfort AM7890-DHW thermostat and my condo is just cooking. I know that the two settings are for heat and cold to kick in and i have them set properly but it still is not fixing the...
Apr 02, 2011 | Heating & Cooling
Can't get my Simple Comfort 7890-DHW thermostat to set on heat. Tried the mode/program and have made it worse.
Push up or down arrow once. H will flash, this is heat setting. Set your temp. Then C will flash, this cool temp. Set your cool temp. After short delay stat will go back to display room temp. Red light heat is on. Green light cool is on. Hope that helps
Mar 24, 2010 | Honeywell Electronic Programmable...
Switching thermostats
The two wires are the control circuit from the heater your running. They go to the thermostat and close when it get below the thermo. setting and start the heater.
Jun 28, 2009 | Honeywell Electronic Programmable...
Can not figure out how to control thermostat
If you take off the front control panel cover (simply prying off on the edge with finger) you will find 2 small buttons under the display panel, one being mode and the other being prog.
Press both simultaneously and hold down for 5 secs and the display will blink, press prog to advance to what you want to program, kinda like setting a timex watch. As I recall you can set degrees celcius or farenhight/ cycle/Hi/Lo etc.
Just keep in mind when you set using the up and down arrows:
flashing H means: at what temp do you want HEAT to kick in?
flashing C means: at what temp do you want AC (if you have it) to kick in....if no A/C fan simply blows air.
Hope that helps.
May 03, 2009 | Heating & Cooling
Honeywell T8400B Thermostat Display Intermittently Blank
most likely a bad tstat i would replace I recommend honeywell focus pro 6000
Jan 29, 2009 | Heating & Cooling
Ariston micro genus combi boiler central heating works okay but domestic hotwater fails to rise but burners seem to be lit and the boiler doesnt appear to cycle dhw temp gets to about 30 degrees instead of...
having found a circuit diagram, realised that the divertor valve was electrically operated.i unplugged this then unclipped the motor from the valve body,the diverter valve is spring loaded and once i'd removed the motor the spring raised the valve to divert water through the dhw heat exchanger,giving us hot water but no heating, if i refit the motor the problem comes back heating no dhw.ordered new motorised valve assembly £30 next day order .
this was a simple fix without having to drain the system down.
Dec 07, 2008 | Heating & Cooling
Heating & Cooling Logo
572 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
