Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Bottom drawer will not close
Drawer is empty, but will not close the last 75mm Nothing in it to cause any obstruction. No error codes
  • Fisher and P... Master
  • 3,247 Answers
Either the lid seal is broken and obstructing the drawer movement or the drawer has come off its rail. Best option is to take the drawer out and examine the inside of the housing. Make sure the mains power supply to dishwasher is turned off before working on it.
Posted on Jan 21, 2013
5 Suggested Answers
  • 784 Answers
SOURCE: Top drawer obstruction, can not close.
Pull out the drawer.at the bottom near the front panel at both sides, press the square tabs in and pull the drawer further. When you have the clearance from the edge of the drawer, lift it up out of the rails then put it down to floor. It may not be the hose. I think the top lid seal is sagging down causing the resistance. If this is a case, you need to replaces both actuators to lift up and down the lid to overcome this problem.
Good luck.
Posted on Apr 25, 2010
  • 10 Answers
SOURCE: the top drawer will not take in water. The tap
1 the inlet valve need replacing its bottom of the draw bit tricky to replace it to check it just unclip bottom draw to the side disconect the hose from the inlet top draw valve and turn it on for a sec see if water pumps out make sure you got small bucket if that works finne. 2 its the pump under neath the dish draw thats very tricky took me 1 hour to do
Posted on Sep 24, 2010
Daniel S
  • 4323 Answers
SOURCE: Fisher Paykel DD603 SS - After
Hi
Plesae check the below procedure to remove the drawer----
Slide open drawer.
Locate draw pin on either side of the tub.
Using a sharp pair of long nose pliers or slip jaw pliers grasp the center dividing web of the pin and pull away from the tub to remove the pin. Support the drawer front with your hand while doing this.
Note: The pin web is vertical.
With both pins removed the bottom of the drawer front can now be eased out slightly.
Now carefully pull the drawer front down to allow it to come free from the handle and top locating slots.
Carefully remove the earth wire from the tab on the drawer front. (if it is an integrated model you will also need to unplug the integrated badge from the isolating module)
Refit in reverse manner ensuring the drawer slides are right forward and the pin secures through the hook on the front end of the slide.
Note: When reinserting the pins make sure the dividing web is vertical.
Hope this helps... Please post back if you need more information.
Daniel
Posted on Dec 27, 2010
arikrom
  • 528 Answers
SOURCE: After cleaning out the crud accumulated in the
the position of the dishes tray in the drawer , make sure that the spray arm not tuching it wile it spin
Posted on Mar 28, 2011
F1 Error code
F1 is flood error. basically water has arrived at the bottom board. you can unplug the dishdrawer, remove the bottom drawer and dry the board at the bottom, maybe with a hair dryer carefully. this will reset the fault, but this is a fault that may appear again. replace the actuators that close the lid of the drawer that is leaking (look for signs of water running our of one of the drawers).
Jul 13, 2014 | Fisher and Paykel DishDrawer DS605FDSM...
I have a double drawer fisher and paykel DCS dd-224p model. bottom drawer works fine. top not working
These units are nothing but grief!! Problem sounds similar to my one, it caused me no end of problems from the time it was installed and don\'t bother calling F&P service coz it will cost you almost as much as a new dishwasher. They have an inherent prob with circuit board, even service tech (on the quiet) said they are bad.The best thing I did for mine was throw it on the scrap metal pile and bought myself a Meile, not one problem. its super quiet and designed to last 20 years. Use the bottom one till it completely craps itself (prob not long) and then buy a NON F&P one!!!
Dec 20, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel Dish Drawer: I flooded it by using wrong soap. It was flashing F1 but I solved this by drying it out after removing the bottom drawer. That problem is solved but now the top drawer is...
Most likely the lid seal is dislodged and is obstructing the bottom drawer. Need to manually operate the lid seal actuator yoke and motor to bring the seal back to normal position. Can be messy.
Will need to get the bottom drawer out from housing and work on lid seal assembly located in the main housing.
http://spares.bigwarehouse.com.au/images/files/6145_5635c632f6805f5644d3f35b6feea5bc.pdf
Sep 25, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
The bottom freezer drawer is not closing so the freezer is getting an ice build up
It sounds like you either have a drawer that's off track, or something has fallen behind the drawer, not allowing the drawer to close. Empty the freezer, and pull the drawer all the way out. Look behind the basket of the drawer and see if some thing has fallen behind it. If nothing is behind the drawer, then the drawer must be off track. At this point, you'll need to pull the drawer out to the most extended point. Now push the drawer back in about 3-4 inches an **** it open fairly hard. Not hard enough to move the whole refrigerator. Just enough to put the drawer back on track. Hope this helps. : )
Apr 24, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Machine displaying f1
The F1 error refers to 'internal flood.'
You may wish to reset the power of the unit, this may clear the error code.
One common cause is too much or 'wrong' detergent causing too many suds. In this case, giving the unit time and a reset is all you need to do.
You may wish to check under the unit to look for a tray with a widget floating in it. If you find such a tray, empty it & cycle the power to reset the F1 error.
I hope that helps.
Mar 14, 2011 | Fisher and Paykel DD605SS Stainless Steel...
I have a Minolta CSPro 4000, and I am getting the following errors on the display screen code 0d50
C0d50 means you have a duplex error. This would be coming from the duplex drawer just under the main front door. You must open then close the duplex drawer to reset this code. It can not be reset by opening/closing the front door as with most other codes. Most of the time the c0d50 code will reset by opening/closing the duplex drawer. If not you will need service on the drawer as there is a drive or sensor problem in the drawer. The guides in this drawer have to jog in and out for different paper sizes and orientations. This code is usually causes by a failure of the guides to move properly.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 29, 2010 | Minolta EP4000/5000 CS/PRO Copier
U3 error code
I believe U3 error on your model of dishwasher could also mean a couple of other things like either the drain hose has an obstruction (kink) or the inlet water pressure is not correct.
Hope this helps in finding out what could be the actual reason. T
o find the kink if any, pull the drawer out as much as possible and feel the hose. Might be better if you took the bottom drawer out from the casing and inspect the hose completely. As the problem is limited to upper drawer you do not have to worry about what is under the bottom drawer. Check the water pressure setting is same for both drawers. If so then that is not an issue as bottom drawer is working ok according to your description. See your manual for instruction on how to check the water supply pressure setting on your dishwasher.
Jun 13, 2010 | Fisher and Paykel DishDrawer DS605FDSM...
Good luck.
Apr 24, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
Jan 24, 2010 | Konica Minolta DiALTA Di200 Copier
Water build up in the bottom of the refridgerator under the fruit and vegtable cripser draws. maytag model #MTB1954ARW
Water build up under the fresh food drawers is usually associated with an air intrusion from the exterior. Warm air intruding into the fresh food compartment creates excess condensation, which eventually accumulates on the bottom.
Some causes are:
1. Internal obstruction, not allowing door(s) to close tightly enough.
2. Deteriorated door seal, (torn, pinched, deformed, misaligned,).
3. Light not turning off when door closed,(faulty door switch, misaligned door, loose hinges allowing door to drop).
Make sure all drawer have nothing obstructing their closure, and door shelves have nothing extending beyond the support bars.
Other less obvious causes may be creating this issue also and are not normally addressable by the novice servicer.
Hope this helps find the cause.
May 25, 2008 | Refrigerators
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
57 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
