Question about Photography
Mamiya ze-x film advance problem - Photography
5 Suggested Answers
Gryfox
  • 216 Answers
SOURCE: Mamiya M645j film counter not advancing to start when roll loaded
It's a common problem in the 645 - if you want to do it yourself, without a permanent fix, put a DROP ( not a lot ) of lighter fluid, or rubbing alcohol on the tip of a fine screwdriver and apply it to the gear you use to rewind the camera, and turn back and forth a few times. If that doesn't loosen it, it'll have to be disassembled.
Posted on Jan 08, 2009
  • 302 Answers
SOURCE: The mamiya 7 shutter does not trigger after each
Very likely that some of the teeth on an internal gear are broken, or stripped. It could have been jarred or over time, just gotten brittle if its plastic.
Another poss. is that the shutter lubrication could have dried out = more resistance = snap.
sounds like it gonna require taking apart. At Minimum, a CLA, otherwise, parts too.
Posted on Oct 21, 2009
ttriolo
  • 5 Answers
SOURCE: My Mamiya RB67 triggers and shutter lease lever
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Posted on Nov 14, 2009
cammedic
  • 667 Answers
SOURCE: Pro-S film back doesn't advance film properly.
There is good chance that the back needs a spring replaced. I've seen them fail many times.
Posted on Dec 07, 2009
I just bought a nice used Mamiya twin lens C3 but the shutter is locked up. There is a small metal piece holding the shutter release from moving. Not sure how to un-lock, seams to be a safety device of...
The vertical shutter sliding lever gets locked if the film doesn't get advanced to the next frame, and the mode selector is set for single exposure. You can't trip the shutter unless you have film in the camera and you forward the film to the next frame. That should allow you to release the shutter with the sliding lever.
Mar 17, 2014 | Mamiya Cameras
Mamiya RB67 Pro S: film counter does not advance, but the film does advance purchase another back same problem. Is there a switch that I'm missing??
If the problem is on the magazine's counter and if the spacing of frames is correct then the counter dial is loose. two screws on the outside front of the top of magazine, two screws in the film chamber hold the top cover. remove leather cover on winding lever loosen screw and remove. you can then remove the complete top housing to expose the counter mechanism.
Oct 30, 2013 | Mamiya Rb67 Pro S Medium Format Camera-...
Mamiya C3 film advance
Hi there,Here's a link to a PDF instruction manual of your camera body.
http://www.cameramanuals.org/mamiya_pdf/mamiya_c3.pdf
It is possible that the crank handle is missing, as it is a removable piece. Bring your camera to a camera shop and see if they have a box of old parts to replace it with. You can either use a regular round knob, or (if you're lucky) one with a crank on it.
Aug 01, 2012 | Mamiya Used C3 Professional Tlr Body...
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
I bought a second hand Mamiya 645 Af but as soon as I load a film it shows a error message ERR 01 .... what is that ?
From the manual:
"If the error display is not canceled when the shutter release button is pressed again, insert the Dark slide, half-press the shutter release button while pressing the roll film holder's manual film advance button to wind up the film, then contact your nearest Mamiya agent or service center."
If you need a manual, you can download one from
http://butkus.org/chinon/mamiya/mamiya_645af/mamiya_645af.htm
Aug 04, 2011 | Mamiya 645AF Medium Format Camera
My Mamiya C330 Pro only gives me 4 photos per roll
A few things to consider:
-Loading: Make sure you are not over loading the film before you start to shoot. I have sometimes turned the film advance too many times and end up cutting down on the amount of usable film.
-Are you loading the film in a dark area and careful to close up the back just after it has started to load to avoid exposing it?
-Shooting: Are you metering properly when shooting? Obviously underexposed images won't develop. You should consider a hand held meter.
-Shooting: Are you advancing the film more than it needs to be after you take your shot? Watch the film counter and feel for that click as it hits the next frame. I have advanced past the next shot many times by accident.
Hope that helps, Matt
Apr 05, 2011 | Mamiya C330 F Professional TLR Film Camera
Mamiya 645 AF back won't advance film.
The battery in the film back is only used to supply power when the back is off the camera, when it is on the body power is supplied by the six batteries in the body so try them and also make sure the film insert is properly seated.
Feb 07, 2010 | Mamiya 645AF Medium Format Camera
Nov 14, 2009 | Mamiya RB67 Pro SD Medium Format Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Jan 07, 2009 | Mamiya 645 Medium Format Camera
Photography Logo
87 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
