Bosch WFL2060 wont stop bouncing
I am a repair tech. I looked at his washer and am unsure where to go next. It is dead bubble level w/ the leveling legs locked in place. The floor is not the greatest but the owner says its always worked in the past, The upper support springs are ok, as are the lower support struts. I see no sign of the balance weight being loose or damaged. I ran it with and w/o a load. Depending on the weight made this worse, but it was still not quite right w/o a load either. I cant think where to turn next. Help if you can.
  • 135 Answers
The only thing i can suggest is motor picking up too quickly.
Find this quite often but shouldnt really bounce with no load.
If anything else comes to mind will post again.
Good luck.
Posted on Jan 24, 2009
  • 85 Answers
Possibly bent drum shaft
The washing Machine knocks during spinning
Easy fix: Readjust the riser supports and level the washer. Some washers have adjustable feet that screw up and down. Put a level across the top of the washer and when it is level front and back, the legs are in the correct position. Some units have auto-level adjustment meaning you have to pull your washer forward and bounce it gently back toward the wall and lift the Front in the same fashion. In some cases side to side adjustment by lifting one side up and then the other can do the same thing in adjusting the levels. Either way you must LEVEL the washer in order to STOP the rattle or bounce.
Dec 14, 2013 | Whirlpool Washing Machines
Bosch WFL 2462 is out of balance during spin cycle
I would think it unlikely that the springs have failed unless they are fractured.It's more likely to be the shock absorber or absorbers. Depress the drum and watch how it settles, if it continues to 'bounce' around its the absorber(s), if it settles after one bounce then it's something else.
Make sure it's levelled ok
regards
w
Nov 02, 2011 | Bosch Classixx WFL 2462 Front Load Washer
The air bubble in level has grown larger than the circle. Is there anything that can be done about this.
Products are repaired at the Bosch National Reconditioning Center by factory trained technicians using genuine factory replacement parts.
For questions about Parts, Warranty, Technical Support or to find a service center near you, call Robert Bosch Tool Corporation. directly at 877-267-2499.
Nov 15, 2010 | Cst /Berger 24X Automatic Level
When sprining the mechine have so noisy
Usually over a period of use the washer tends to get out of balance, and then make more noise when it get to the spin cycle. I would suggest leveling the washer and then trying it out. The best way to fix this issue is by getting yourself a water level, u can get it in any hardware store. I personally would recommend a small circular water level for this job. Place the water level on top of the washer; make sure it is in the center. Take a look at the level and see where the bubble is in the water level? Accordingly you have to lower or raise either 4 corners of the washer to bring the bubble in the water level to the center. Now you have to be very gentle and small increments when rising or lower the corners of the washer, it does not take too much to move the bubble in the center.
If the problem continues then you have to open the top cover and check inside. 9 out of 10 the washer needs to be leveled.
Aug 09, 2010 | Hoover H130E Front Load Washer
The washer is consistently off balance during the spin cycle
If the problem continues then you have to open the top cover in your case since its a top load the back cover and check inside if any of the weights are out of place. 9 out of 10 the washer needs to be leveled.
Aug 09, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Excessive vibrating and banging in the spin cycle with some washes. The unit is only 1 month old. Any advice?
You have a improper installation. The machine has to be perfectly level side to side and frotnt to back. After leveling, check the feet on the bottom and see if one is bouncing on spin with a load. Adjust the bouncing foot down until machine stops bouncing.
Jan 25, 2010 | GE Profile WPRE6100G Top Load Washer
Wash bounces all over the place
nothing, i'll live with it. thanks for your reply
Apr 08, 2009 | Maytag Washing Machines
Bosch WFL2060
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 24, 2009 | Washing Machines
Bosch Axxis Washer WFL2060 leaking when filling
yes.you are right.somethin might have cracked.
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Dec 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
My new washer bounces around the room like its posesd
hi,
have you removed the shipping bolts at the back before you run the unit?
if it is brand new, it is shipped with mounting bolts at the back that holds the unit securely. look at the back and you will see notice there about shipping bolts that you need to remove.
tnx 4 using fixya,
drcool
Nov 14, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
