Question about Samsung CLP 310 Laser Printer
Samsung clp 310 blurred printing
Just changed ink cartridges. Lighter colours and blurred
komguy
  • 2306 Answers
SOURCE: how to print miror image
After you select the image to print the printer dialogue box opens, click on preferences and tell the printer to print a mirror image. It's set in your computer and not at the printer.
Posted on Jun 22, 2009
  • 13 Answers
SOURCE: Samsung clp 300 paper jams after feeding about
Lift Machine up 4 inches at the front with a thick book.
Paper will now run downhill slightly,
Richard
Posted on Oct 29, 2009
  • 7 Answers
SOURCE: My CLP-350 Samsung printer only prints black ink
Here is my solution, hope it will solve your problem.
From your post, I believe your CLP-350N printer has enough black toner. The black cartridge is on the far right side of the printer, so the black toner is harder to go to left side of the roller than right side. Everytime we start the printer, it will move some toner of each color to the roller before it shows ready to print.
Because we always use B&W printing when we start the printer, but less Color printing. The result is there are always enough toner on the 3 color rollers, but the black toner is lean on the black roller. When this gets worse, the left side of the black roller may hardly get any toner at all -- so it only print black on the right side fo paper.
Step by step solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.(Hold the printer button for 3-5 seconds, it will print the test page.)
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Posted on Feb 10, 2010
jyvibar
  • 148 Answers
SOURCE: samsung clp 310 printer regularly jams
avoid using paper that is below 50 gsm
Posted on Mar 26, 2010
  • 3 Answers
SOURCE: Papr Jam, Samsung CLP310 - paper jams half way through the job
If it jams every page, it is the infamous Samsung design flaw. There are dozens of reports of this problem all over the internet. The best solution: sell it or otherwise get rid of it ASAP and buy another type or model of printer. The 2nd best solution: call trained technician and ask to replace the broken part. It could be thermistor near fuser, some people say it is a photo-interrupter.
Posted on May 05, 2010
Testimonial: "Thankyou"
Colour lighter than previouse copies
Replace the ink-cartridges, to see if that fixes the problem.
Check the printer setup to see if it is in "draft" mode or "normal" mode.
Feb 24, 2015 | Canon SELPHY CP740 InkJet Photo Printer
Colour Printing on a Samsung clp 500
Try unplugging printer from the power and connecting it back.
Try also extracting all toners and putting toners back.
Oct 30, 2008 | Samsung CLP-500 Laser Printer
Samsung CLP 510 - won't print on photo paper.
Have you changeed the PAPER type to (specialty or card stock) this always work for me. Your printer will have these setting
Aug 31, 2008 | Samsung Office Equipment & Supplies
Samsung CLP-310 Colour laser doesn't print properly
This is not a driver or Windows issue, has the ink cartridges been changed recently, it sounds like the the paper is not being magnetically charged before the ink, unplug the power cord for 30 sec plug back in and try printing again
Nov 07, 2013 | Samsung CLP 300 Laser Printer
Samsung CLP-310 printer shadow printing on second half of page
I would check that the tension between your fusing rollers is ok as the toner will come off the paper and than return back to paper on its next revolution causing a faint image further down the page
May 19, 2012 | Samsung CLP 310 Laser Printer
How to change the ink toner for clp 310 n
open fron door and slide cartridges out, slide new cartridges in, just remove protective tabs from new cartridges and that is all...
Jul 22, 2010 | Samsung CLP 315 Laser Printer
Samsung CLP-315 colour laser printer - is it true that you cannot print only with the black toner cartridge, if one or more of the colour cartridges is empty? I only need to print black!
Yes, it is true that most of Color printers will not allow you to print document if one or more of the recommended Cartridge of the printer is empty or removed from the printer. for printing only black, the better option will be to change your printer settings while printing a document. ex: when on a document ,and your press Ctrl+P for document printing, there is a option where you can select print color as black and the printer will print your document in Black only.
Feb 05, 2010 | Samsung CLP 315 Laser Printer
Printing in black is not the same shade through out the paper
This is a very common problem with the Samsung CLP 300 and CLX 3160 printers. What happens is that the toner or developer blades become coated with toner. The developer blades meter the amount of toner that the printer uses to make the image on the paper. When the blade become blocked, the image become faint. To fix this problem, you and either replace the imaging unit for about $100 or you can clean the blades yourself. I have posted instructions how to clean them on my Tips section.
Jan 26, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-300 Printer not printing black well
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It's best to do this each time you install a new cartridge. get more information and help from here .
Jan 10, 2010 | Samsung CLP 300 Laser Printer
Ink issues Samsung CLP-510
Some paper tints can cause problems with color images, so make sure that you're using plain white paper, not another color such as beige, yellow, or blue. Even an off-white shade can affect your colors.
In addition, paper type can slightly influence your ink color. Highly absorbent papers can draw in the ink so quickly that the printed image may seem dull or a little washed out. If this is the case, try a coated paper that is specifically intended for color printing. If you're printing those important family vacation photos, use a good-quality glossy paper.
If your colors are way off, you may be running out of one or more ink colors. For example, blue and yellow are mixed to make green, so if your grass seems blue rather than green, you may be running out of yellow. Check your ink cartridges and replace any that are low or exhausted.
Thank you, & post back if you still need assistance.
May 07, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP 310 Laser Printer Logo
79 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
