Back to:
Tags:
Nesa Vision NRM-5600 5.6 in. Car Monitor
Fuse size?
posted by bradonj on Jul 11, 2007
what size fuse should i use to protect this unit?
Comment by bradonj, posted on Jul 13, 2007
Thanks icansurf. i brought the unit second hand. it didn't come with a fuse holder, so i just wanted to make sure what protection i should give it when i install. i'm using it for a reverse camera screen.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jul 11, 2007
Helpful (85)
icansurf
Rank:Wiz Wiz
Rating: 84%, 190 votes
i'd say use a small value, such as 5 amp or less. did you wire this up yourself? most stuff like this comes with an in-line fuse already built into the red power wire. in that case you wouldn't need to have additional fusing.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on fuse size?:
I don't want to Accept this solution
Can you Help with these Car Monitors problems?
Car Monitors
it says eject lock what i go to insert a **** how to i...
Car Monitors
I have a Mitsubishi FTO. I go out and stop at where I am...
Car Monitors
pixels on dash board is not working
Car Monitors
the two 5in screens are made by power acoustik their are 3...
Car Monitors
does anyone know where i can get instructions for blue...
Loading problems.
Repair Service
Find Car Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
