Black screen on a gateway netbook
The power light is on but the screen is black.
    Problem Solver:
  • 8 Answers
We need to know the following:
  1. is the fan running ?
  2. does the HDD spin or sound when you trun on
if the above is okay, we might suspect you lapmonitor - try connecting an external monitor then power up
Posted on Jan 16, 2013
3 Suggested Answers
SOURCE: Black screen
After last night and we could not get it to go I had an other look around the net and found that if I download a bios for the mother board and put it on a flash drive and booted it off the flash drive so that the bios updated I got the netbook to work again. I quickly then did a back up of all the files. Thank you for your help last night.
Posted on May 13, 2009
  • 92 Answers
SOURCE: When I turn on my netbook the screen is black
You can try check if you have any special function keys on your computer that allow you to disable the screen image or simply put it to another output port. Just like you would do if you would like to connect you pc to and external video projector.
I had similar problem with my netbook, and on my case a BIOS update solved the problem.
Posted on May 16, 2010
Screen turns dark
Clarification Question:
Did it went black while you are using it or it is already black when you press the power button?
Mar 14, 2013 | Gateway LT3119u (LUWEW02001) Netbook
Black screen gateway kav60? acer user i need something that wont use cd cause i dont have one!! something wit alt or w.e method with out cd thank u so much
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 25, 2012 | Gateway LT2021u Netbook
White screen problem on my netbook gateway lt2016u
I Got lt2016u/LT20 Gateway Netbook I need help restore my net-book and i need please restore it cause it got blue screen and keep going to slow and poping up errors messages PLEASE PLEASE help
Feb 27, 2012 | Gateway LT2021u Netbook
My screen on my gateway netbook has a small crack in it that caused the whole screen to turn black. Will I be able to fix it or should I buy a new one?
If your comfortable opening up the laptop, and either have done it before, or know someone who has and is willing to help you, yes you can replace the LCD screen in the netbook.
If not, your best solution would be to take it to a technician or repair shop, or, if financially viable, buy a new one, and swap out the harddrives to that your new machine has all of the information of the old one on it.
Sep 15, 2011 | Gateway LT2030u Netbook
When i turn on my gateway nv52 the screen is black and white with horizontal lines. i can plug my laptop into an external monitor and it is fine so it has to be something with my video cable or monitor. ...
First things first simpers,your netbook might have a "hotkey" combination that toggles between external monitor and your screen .On my netbook iits Fn/F5 but yours might be different. Goto your manufactures site to find out the exact "hotkey" function.
Good Luck
Davey Snake!
Jul 20, 2011 | Gateway Computers & Internet
When I turn on my netbook, the screen stays black. Nothing appears.
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Gateway LT2030u Netbook
My gateway lt2016u netbook fell and now the screen is messed up. how do I fix this?
You will need a razor blade.
Where the black flat part of your screen meets the silver outlining there is a crease. Take the razor blade and slide it through the **** all the way around the screen. You might need to pull up on the black flat part with the razor blade to get it to unsnap. Then inside you will see the screen and a bunck of screws. Unscrew all the BLACK screws. Then pull the scrren forward. It will be screwed in on a metal rod on both sides. On the side of the metal rods will be some screws. Unscrew theses screws, then the screen will come out. You are not finished yet. The screen will be hook up to a a chord in on its back. Unplug the end that is hooked directly into the screen. You may need to take some tape off in the process. Then do the reverse steps with a new screen.
Aug 18, 2010 | Gateway LT2030u Netbook
When I turn on my netbook the screen is black after the Gateway logo screen pops up. How do I fix this problem? I was in the airport and just closed the netbook not actually shutting it down and now I only...
May 16, 2010 | Gateway LT2021u Netbook
I have the acer aspire netbook and it is stuck on blaCK SCREEN.alt f10 is not bringing up any sort of menu...what can i do?
so it's charged up or plugged in and the power indicator looks normal, then you press the power button and what is the sequence of events that follow?
also if you look really closely at the screen can you see anything very dimly appearing on the LCD?
Jan 13, 2010 | Gateway GT4016 Desktop PC
Computers & Internet Logo
David Payne
David Payne
