Question about Car Audio & Video
I need remote for alpine 8030b - Car Audio & Video
How to fix alpine remote model RUX-4220 MISSING COVER FOR BATTERY
http://www.newremotecontrol.com/Mfrs/OtherBrands/Def/dyn_part_data.php?catnum=01E40601S01
Jan 22, 2015 | Alpine New Original EX10 Remote Control
I have an alpine mc 20 marine remote control unit for my alpine Ida x 100m and the remote says to add an mc2 and no radio found.i ave tried to reprogram the remote according to the manual .what is going on
connect cable (delivered together with mc20) to ida x 100, then switch on radio b4 you switch on mc 20, then follow instructions on mc20 instruction sheet
Feb 23, 2013 | Alpine Car Audio & Video
I purchased an Alpine Remote RUE-4168 to work with my DVA 5205. Is there some setup procedure needed to sync these two items or should it be plug and play? because nothing is happening.
The DVA-5205 has to have an infrared remote module plugged into it to receive the signal from the remote. I have one also and it doesnt have one and it wont do anything without it. I'd like to know where to get one if you find out. Alpine seems to stop making everything for older models once they come out with new ones.
Dec 11, 2010 | Alpine DVA 5205 Car DVD Player
Alpine INA W900 and pac tr7 installed.
Connect your
Alpine INA-W900 to your iPod via Bluetoot and do the setting from your Alpine dash receiver as per instructed
May 31, 2010 | Universal Remote Control Pac Tr 7...
No sound with USB and IPOD Apline IDA-X100
You connected your blue alpine wire (power antenna) to your blue wire (amplifier remote on) on the BMW harness adapter. You need to undo this, amputate your blue alpine wire (because your E36 has no power antenna) and connect the alpine blue wire with white stripe (remote power) to your blue wire on the harness adapter.
When you switch source from the radio, alpine is shutting off your amplifier through the connected power antenna wire. Since you're not listening to the radio anymore, it sees no reason why it should give it power.
Dec 27, 2008 | Alpine CDA-9851 CD Player
Schematics alpine
Hi
Here's a ->LINK<- to the owners manual, it includes the wiring schematics.
Regards
Philip
Nov 22, 2008 | Alpine IVA-D300 Car DVD Player
No sound from front speakers during CD operation.
I think you are using an external amplifier,if this is the case,you may be using the wrong remote wire for the amp.
Alpine use two blue wires,BLUE (only) this wire is for the pwr antenna and every time you insert a cd, this pwr line cut out.
BLUE/WHITE STRIPE this is the remote wire that you need to connect the remote of the amplifier.
thanks for rating
Feb 11, 2008 | Alpine CDE-9846 CD/MP3 Car Stereo
No bass thru cd player
it seems like you connected the wrong remote wire to the amp.
Alpine has two remote wires.
BLUE (only) This is the pwr antenna remote wire,every time you insert a cd this remote wire,the pwr cut out.
BLUE/WHITE STRIPE This is the AMP REMOTE WIRE,THIS IS THE REMOTE WIRE THAT YOU NEED TO CONNECT TO THE AMP
LET ME KNOW IF IT WORKS
thank's
Dec 25, 2007 | Alpine CDA-9807 CD Player
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
