Question about Maytag MZD2766GES Side by Side Refrigerator
MAYTAG MZD2766GE SIDE BY SIDE
Our refrigerator is only 5 years old. Why do we continue to have problems getting the right side to "cool". The part has been replaced 3 times in 1 year & it continues to go bad. We have had to throw out food way too many times. need any help anyone can offer?
  • 1 more comment
  • tampakev Jul 16, 2008
    I am having the same problem with the right (rifrig) side not getting cold. I tried to unplug/defrost it and clean it out, but it still isn't much better? Are there any easy fix available??
  • ranger2997 Jan 08, 2009
    I purchased my Maytag plus side by side in June 2002. It worked fine until March 2008, when the fridge side stopped cooling. I had a friend in the business so I asked him to tell me what the problem was. He indicated that these units are notorious for this problem. Said that the Adaptive defrost module had failed. I had this part replaced. The unit worked great for 1 month, then the same thing occurred. Again I had the part replaced thinking maybe I just got a bad part. The unit worked again for 4 months and failed with the same problem. I have been told that all I can do is replace the part and hope for the best. Sometimes they will last for along time and other times shorter. I have looked to see if there are any recalls for this situation and am not able to find anything. If anyone has had the same problem and knows a solution or if there are recalls, please respond.
  • tanellav Jan 13, 2009
    We bought ours in 2002 and it is having the same problem, it is not cold enough in the refriderator side
Mine kept doing the same thing- the flap between the freezer & the frig is getting stuck. I finally just broke mine off & left it that way. Now the frig is really cold, sometimes things partially freeze- but that is better than going rotten. I now have a section under the water/ice dispense tray bubbling/peeling the white paint off. Mine is 6.5 years old & out of warranty, so I'm searching for a way to repair this problem. Any suggestions?
Posted on Aug 31, 2007
  • 72 Answers
You didnt say what part has been replaced
Posted on Jul 11, 2007
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: MAYTAG MZD2766GE SIDE BY SIDE
The freezer on top unit was keeping everything up top nice and cold, but the customer began to notice things in the fresh food section getting a little to warm. When the temperature selectors were adjusted to a colder setting, it seemed to help for a day or two, but then started getting warmer again. Sounding like a defrost problem, I paid this refrigerator a visit with hairdryer in hand, and parts in the van. Frost free refrigerators use a defrost heater to periodically assist with the melting of frost that builds up on the fins of the evaporator located in the freezer section. Frost forms each time the doors are opened to the unit, and the warmer, moist air from outside gets inside and heads toward the cold surface of the evaporator. As the frost continues to collect, the air passages in and around the evaporator start to close up and begin to prevent air circulation by the evaporator fan from the freezer to the fresh food section. As the cycle continues, the temperature in and around the evaporator will be cold, but the fresh food section will get warmer because warm air is not being exchanged with the colder air from above. The defrost sections of most units will consist of the same components. Namely, the heater itself, the bi-metal terminator, and the timer or defrost control. Each one of these components need to work properly for the defrost cycle to properly keep the unit frost free. On this unit, the timer could be advanced to begin a defrost cycle, but there was no current flow to the heater. After checking all connections and doing a quick resistance check of the circuit, I determined the bi-metal terminator had failed open. These bi-metal devices are used to prevent an overheating situation in the freezer section should the heater remain on to long. Once the trip temperature is reached, the bi-metal will open up a set of electrical contacts thus opening the circuit. Then when the unit cools back down to it's reset temperature, the contacts will again close, closing the circuit for the next defrost cycle. Because this bi-metal didn't reset, the circuit remained open and no defrosting took place. After using my trusty hairdryer and warm water squirt bottle to defrost the evaporator, I wired a new defrost terminator in line with the heater. With all the frost removed, the cold air started circulating again, and now everything within the fresh food section stays properly chilled.
Have a manual and can help you. Visit my site and enter your model number and part number in search feature. Click link below
http://servicepartstec.blogspot.com/
saebreezehvac@yahoo.com Thank You, Sea Breeze
Posted on Apr 02, 2009
Maytag MZD2766GE
Apparently, you will need to call a service man.
You may be low on freon.
Sometimes leaks occur and are not serviceable except by a service man.
I recommend that you find a service man in your area. There may be one at this website listed who would be close.
Apr 06, 2008 | Maytag MZD2766GES Side by Side...
Hello, Problem with Maytag plus Side by Side refrigerator model MZD2766GE.The Freezer part is working fine but the fridge part is not cold at all even after I adjusted the temperature to number 8. I do not...
You most likely have a defrost heater and/or defrost term switch. (switch is built into heater on your fridge).that needs replaced causing your coil to completely freeze up and blocking cool air flow to fridge side. Here is the part you need to order.
http://www.appliancepartspros.com/part_details.aspx?part_id=4069923
Thanks, Randy
Feb 07, 2011 | Maytag MZD2766G Side by Side Refrigerator
Maytag MZD2766GE refrigerator side is not cooling well. Freezer side has no problem. Where are the coils for cleaning? Any other ideas?
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 31, 2010 | Maytag MZD2766GES Side by Side...
Refrigerator side doesn't feel cool but the freezer side is cold for a Maytag refrigerator model # MZD2766GE
Is there ice build-up in the back of the freezer? If so take the panel off the back of the freezer section inside the freezer and replace the heating element.
Jul 21, 2010 | Maytag MZD2766GES Side by Side...
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Maytag Widey Side not cooling enough
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. If it is that it's going to fill the pan under your fridge and overflow.
Apr 19, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
MAYTAG PLUS, MOD MZD2766GE STOPPED COOLING ON THE RIGHT SIDE,
After they replaced the part did they defrost the unit. there is probably ice build up on the coil behind the service panel in the freezer compartment. If the defrost control was the part replaced you can probably push the refrigerator side light switch in and out 5-6 times and force a defrost. if the unit goes into defrost then all the components are fine and you just need to manually defrost the coil either by off loading all food and leaving the unit off for 4-6 hours with doors open. of offloading freezer side remove rear access cover in freezer exosing evaporator coils and use a hairdryer to defrost the ice accumulation. good luck Peyton
Mar 06, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag mzd2766ge not cooling
could be the defroster is't working,low in freon or the conpressor is shot,
May 18, 2008 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
1,964 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
