Question about Coleman L135f 135 Disc Limit Switch 8866-329 8866-3291
Lakewood 798/240 thermostat switch L135F - Coleman L135f 135 Disc Limit Switch 8866-329 8866-3291
Got a lakewood heater jr 762 and the switch is burned out. Where do I got to find the replacement, or what's the part number? Thanks
I would assume you are talking about the thermostat switch. These switches are very simple to repair on your own. They are open without any housings and can be accesses by generally removing the panel from the heater. These thermostats fail at the two contact points due to the consistent arcing from opening and closing or on and off. These arcs create carbon buildup which then will not allow them to make the continuity necessary to turn the heater on. In some cases they may even fuse together keeping the heat source consistently running. If the heat source is continuously running with a faulty thermostat the thermal fuse may fault out. If the thermal fuse faults the fan may work but the heat source will not. These fuses will need replaced by an experienced person, you can generally pick these up on ebay for a few dollars. For carbon build up use a small wire brush to remove, while using fine sandpaper to drag between the contact points of the thermostat. Good luck. Mike
Apr 15, 2011 | Lakewood 792/JR Utility Heater
I bought my lakewood heater used and when i tested it started to heat up. When i brought it home the heat was very low so i rose the thermostat. An hour later - there was no heat. whats wrong?
Contact the seller, and ask him to refund you. If you can't, the problem seems to be the thermostat, or the switch.
Tries first see if the switch its on place (normally just have to pull it)
Next, if you know how to, open the heater and test the thermostat.
If don't know how, the can't help it more.
Sep 15, 2010 | Lakewood Oil-Filled Electric Radiator...
Model 707 Lakewood portable heater stopped working
I don't know how to make your heater work again, but I do know (from long experience with Lakewood 707s) that the setting knobs often fail to function properly even if the heating element still works. My solution is to plug the heater into an adapter with an on/off switch on it and use that to control the power. I leave the setting knobs on the heater itself in the position where I usually use them (max heat). These are excellent heaters except for the knob problem.
Apr 06, 2010 | Lakewood LAK707 Utility Heater
Lakewood heater 7101 schematic
The power cord goes the switch terminal 1 and 3.
Terminal 2 must be the opposite of terminal 1, such that when switched on, 1 & 2 connects. Terminal 4 must be the opposite of terminal 3, such that 3 & 4 connects.
Under this setup, you may connect red to terminal 2
and black to terminal 4.
Be sure of the 1 & 2 pair, as well as the 3 & 4 pair.
then, connect the red and black wires.
Hope this will help you.
Jan 06, 2010 | Lakewood Oil-Filled Electric Radiator...
Lakewood space heater thermostat source
No I never had any luck and the parts likely 1/2 the cost or more of a new one at wal mart and the heat element would still be old too
Dec 31, 2009 | Lakewood 5101 Oil Filled Radiator Heater
Switch burned out on Lakewood radiator heater.
Hi, go to amazon.com and you can get a switch for the Lakewood model 905 heater.Best of luck,
Shastalaker7
Nov 24, 2009 | Lakewood 905 Radiator Heater
Need a thermostat for a space heater
visit this page for Lakewood parts and service center info:
http://www.lakewoodeng.com/html/parts.html
Feb 22, 2009 | Heating & Cooling
Heater pops the circuit breaker
Lakewood 5500 Heater - Here is a picture of the rear side of the open heater thermostat with the two switches for 600 and 990W at the left. The 3oz metal piece is the weight that broke off from the thermostat assembly. It fell down and made a short between the case and the power switch. There is a visible burn mark where the short occurred.
I am convinced that if the heater ever falls over, the metal weight will break off and fall down and probably create a short against the case. It may disconnect the 120V power at the thermostat or cause a high enough current to kick out your breaker in the house.
The attachment of the 3oz metal weight to the back of the thermostat is not strong enough to survive when the heater falls over; it wil break off.
Nov 13, 2008 | Lakewood (5500) Oil Filled Radiator Heater
Coleman L135f 135 Disc Limit Switch 8866-329 8866-3291 Logo
91 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
