Question about Whirlpool LER5636P Electric Dryer
Heating element dosent go off
Ive changed the heating element twice in 2 days all the fuses and the heating wont go off. I havr to unplug after use
    President:
  • Whirlpool Master
  • 2,651 Answers
Sounds like yo have a wire shorting to the unit itself or a contact closed onthe dryer timer, always allowingheat.. I would point to a shorted wire somewhere. might be a ***** to find sorry!
Posted on Jan 27, 2009
Roper dryer takes 2 cycles to dry clothes. How do I look at the heating element? OR since it is still heating, just not quickly enough, could it be something else? OR does it have 2 heating elements?
First of all, unplug the unit before working on it. Be careful inside a fuse box, dangerous voltages. It's usually safe to change fuses or flip a breaker so long as your not in a wet location. Most dryers run the heating element on 220 volts, meaning you can either have one larger breaker or you could have 2 smaller breakers or fuses. If that is the case, possibly one of these breaker "legs" has tripped. Check that first. I would sooner think one of the heating elements are open or "not heating". I would look up the Roper Model number and search for the heating elements section. Some do have a thermal fuse but I think that would cause both elements to quit. Take a look here: https://www.youtube.com/results?search_query=roper+dryer+heating+element+replacement
Dec 20, 2017 | Roper Dryers
The wire connecting to the heating element keeps melting/burning. Ive replaced it twice, each time it melted, how do i fix it?
What size wire? When you replaced the heating coil, what did you use? Was it OEM? What part number? Do you have an ohm meter?
Apr 11, 2014 | Dryers
Dishwasher is not heating water and wont dry dishes.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element for mineral deposit on it, clean the deposits using a soft brush and a cleaning solution (Don't scrub the element hard). If this doesn't resolves the issue then remove the panel and examine all the wiring connections to the heating element. Now, use a multimeter and check for the resistance reading (ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue. Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Dishwashers
My worldpool dryer truns but will not heat up??
Thank you for contacting Fixya.com.
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Check the thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) that is mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation.
Please check the bellow link to have an in-depth knowledge as to when the dryer wont heat up...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have any further query.
Have a nice day.
Nov 29, 2010 | Whirlpool Dryers
Dishwasher is running through cycles ok but water is not heating so only cold cycles.
Hi
The water is not heating as the heating element has gone bad or a fuse has blown which is preventing heating element to turn on. To check the heating element you'll need to turn off the dishwasher, unplug it. After unplugging it check the heating element formineral deposit on it, clean the deposits using a soft brush and a cleaning solution(Don't scrub the elemnt hard). If this doesn't resolves the issue then remove the panel and examine all the wirin connections to the heating element. Now, use a multimeter and check for the resistance reading(ohms, Rx1) for the heating element. The multimeter should display between 1200-1600 ohms or 1.2K ohms. If it is less than 1200 then you'll need to get the heating element replaced. Also, check for any blown fuse around the element. This should resolve your issue.
Thanks
Daniel
Aug 07, 2010 | Microwave Ovens
No heat
unplug remove the back check the heater box fuse and heating element,they are to your right,the fuse is on the left side top,and the heating element is the bottom half of the heater box,remove 2 screws,if you don't have a meter,you can tape the 2 fuse wires together to see if you get,heat,but you can;t leave it like that,it is only for a test,the heating element remove it and look for a broken wire-mike
Feb 21, 2010 | Kenmore 64902 Electric Dryer
Heating element has stopped working just 2 days
use a multimeter to check the continuity of the heating elements. if there is an open, replacing it will solve the problem.
Aug 04, 2009 | Dryers
Whirlpool dryer model LEB6000PQ0 its not heating up anymore''it starts it turns but the clothes dont dry its only 2 yrs old.
check your breaker first.A dryer will run on 110 but wont heat.if not breaker it could be your thermal fuse or element.the thermal fuse is located on element cage,unplug machine and test for continuity to your thermal cut off fuse which will be the top one on cage and check continuity to element.
Mar 08, 2009 | Whirlpool Dryers
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Whirlpool LER5636P Electric Dryer Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
