Awm 8900 turns off not getting booted
I've accidently put 380V on my whirlpool awm 8900 and
have now as result a burnt down filter (condensator)
and now it takes the washing machine much time to get
ready for work but before that it turns off. what could
be the problem with? what details should be examined
and replaced? thank you so much in advance
Max, Leipzig
  • 15,935 Answers
It appears your timer/main controller and motor controller has failed in this instance. It might have even caused damage to the motor itself.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
I have a window air conditioner that is leaking water on the inside. we've have 90+ temps now for 5 days straight.
The problem you're having is usually a result of the condensation pan under the unit has a clogged drain hole. In addition, if the outer exterior of the unit is not tilted down 1/4' to 1/2", water backs up in the condensation pan and can not flow toward the drain hole.
Clearing the drain hole and being sure the unit is tilted enough, should solve the problem.
Jul 20, 2011 | Whirlpool ACQ128 Air Conditioner
Hi i have whirpool awm 8900 and i have fault f11 what is this?
In your service manual it states for the f11 code
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
If you have any further questions message me back I await your reply Thanks again Rick
Jun 20, 2011 | Whirlpool AWM8000 Front Load Washer
I have a Whirlpool 1200 Spin AWM 1201 Washing Machine. There is a funny smell coming from it like suage. Also sometimes there is water on the floor after its use. We have checked the pipe going outside and...
The smell is a build up of bacteria which can be flushed out to help/ The leakage could be a few things a hose , pump or door boot seal ,a small rip in this you need to check further....
Feb 22, 2011 | Whirlpool Washing Machines
I have a Whirlpool AWM 8900. When I try to use it, start to evacuate and some time after, it shows an F dL error. I have tried to find any kind of doc. inside the washer but it came with nothing. Can any...
Greetings,
this could be the door latch problem which part costs 50-60 dollars and it can even be the main control board which costs 190-210.00 ...it could be either one of these ...
Jan 24, 2011 | Whirlpool AWM8000 Front Load Washer
How do i clean a filter of a whirlpool awm 5080 front loader
If you are talking about the drain pump strainer, you need to remove the lower front panel. should be 3 screws on the bottom facing forward. Once you have that off, the pump strainer is almost in the center, facing you. unscrew it counterclockwise to remove.
Apr 26, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Washing Machine AWM 029 is not draining
Hi.
I assume you have checked to see if the pump is working,
Select drain and spin, if water does not go away, then you have a pump problem, which will stop the programme completing.
Please leave feedback.
Thanks
Nov 25, 2008 | Whirlpool Washing Machines
Whirlpool AWM 8900 wont fill with water. Solenoid is ok but there is no power output to it from the control box. I fitted another control box from a known good machine but it still didn't fill. Eventually...
perhaps the small rubber tube that comes from the drum to the pressure switch is blocked with soapy gunge ...what i do is PULL OUT PLUG to CUT OFF POWER .dis connect tube off pressure sensor and use ballon pump to clear tube. reconnect
tube to sensor and test machine.
Apr 30, 2008 | Washing Machines
Whirlpool AWM 8103/1 error FP
it looks like you have a clog filter or pump issue.
take a look at this forum
http://www.howtomendit.com/answers.php?id=53072
Feb 24, 2008 | Washing Machines
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
