Question about Intel Motherboard
Internal wiring on iQon pc. (philips)
Disconnected front mic/headphone sockets from m/board.gigabyte ga k8vm 800m. tought it 1 block but 4 different ones. tanx.
    President:
  • 2,692 Answers
Your welcome. Fix Ya?
Posted on Jan 24, 2009
What is the audio driver on the iqon 1033 and video controller
The specs for this motherboard are:
system model == gigabyte technologyco,ltd
945gzm-s2
main circuit board = iqon ie 945gzm-s2
bus clock 200 megahertz
bios award softwareinternational,inc
ff iq 03/07/07
from another user.
Here is the support page for the drivers.
GIGABYTE Motherboard Socket 775 GA 945GZM S2 rev 2 1
Feb 22, 2015 | Computers & Internet
Ddr1 ram voltage variation in giga bye mother board model ga k8vm
Hello download the manual here:
http://www.gigabyte.com/products/product-page.aspx?pid=1810#manual
Adobe reader is needed to read the content.
A setting in the the bios, controls the voltage to the ram module.
The setting needs to be set to default, and do not overclock the ram
they will not last long when you do this.
Good luck
Oct 05, 2012 | Gigabyte GA-G41M-Combo Motherboard
No sound in front panel and even pop message not coming on pluging in headphone in front panel of newly installed mother board
The front panel audio jacks are not connected to the motherboard. Take the computer to the service who installed new motherboard and tell them your problem!
May 16, 2011 | Gigabyte GA-P55-UD3L Socket 1156/ Intel...
I dont have mother cd with me and i need to install the mother board cd in my computer becoz display are not working properly
Your board has Socket 754, VIA K8m800 and KIA VT8237 chipsets With Realtek sound. S3 Graphics Unichrome. This is Gigabytes link to downloads. I ahve entered your info but will outline for you.;
http://www.gigabyte.us/support-downloads/download-center.aspx
Option 1
1 Select Product catagory Motherboard
2 By socket- socket 754
3 By chipset-VIA K8M800
4 Model Name- GA K8VM800M
Click search
New screen, scroll down and enter o/s
Drivers will show up Scroll down to VGA Driver and pick
"VIA K8M800 Driver. scroll to right and click on "America"
This will give you your most recent driver.
Mar 26, 2011 | Gigabyte GA-K8VM800M Motherboard
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Sv400 rev 1.0 motherboard the mic sockets are not working the rear socket has been linked out (speaker socket still workin) the front socket has 5 unconnected wires (mic power, mic in, ground, r-out,...
each motherboard has different pin connection, so its best to check the booklet that came with motherboared, in the book there is color colding for mic and headphone.
Feb 10, 2010 | Computers & Internet
Internal rewiring problem
Hello. You are going to have to go to the web site of the company that made your main board. look on your main board for the manufacture. take notes of the model number. go to support, and you will be able to download a manual on the mainboard. it will show you where everything plugs in. good luck !
Jan 19, 2009 | Computers & Internet
Havimg prob with the 2 usb ports located in front
Hi manky, Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
Jun 01, 2007 | Intel Motherboard
Intel Motherboard Logo
149 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
