I just bought a Pioneer PL-740
A used one of course. Before I bought it, we tested it, everything works. But when I reach home, ON it, without pressing any button, suddenly the table rotated continuosly and the arm keep on moving up and down. How can I solve this problem?
petraman7
  • 1175 Answers
SOURCE: the arm will not return to stationary and the table keeps spinning afer the record is played
HI...
One or two mechanical linkages inside have "let go"
Denon is good stuff. Depending on where you live I might be able to suggest someone to fix it.
Posted on Jan 19, 2009
  • 864 Answers
SOURCE: I need to reattach the belt under the table
Download the manual free at http://www.nodevice.com/user_manual/pioneer/other_home_component/pl-990.html
There are instructions there and pictures showing how to attach the belt.
Posted on May 21, 2009
SOURCE: Is there any pictures available on how to reattach
u can watch it on youtube
Posted on Oct 23, 2009
  • 5 Answers
SOURCE: aiwa lx 70 turntable needle arm
This is not a solution but it is information. I just got one of these turntables and the platter rotates but the tonearm does not move. I took it apart after downloading the service manual and found that there are two small thin rubber belts that due to age have fallen apart and "melt" when you try to pick up the pieces. One controlled the sideways movement of the tonearm "carriage", the other controlled the lifting and lowering of the tonearm. The replacements are expensive (I think around $18 each) and in trying to pop loose a worm gear with a pulley buit into it, so that I could try a cheap rubber band out just to see if the unit would work with new bands, I broke the stiff plastic "retainer" that by its shape was designed to be pushed out of the way a bit to allow the worm gear to be removed. The service manual, by the way, had all sorts of information about how to make fine adjustments, but said nothing at all about how to replace the belts. Unless removed there was no way to put the replacement band in place over the gear/pulley combination because there was no exposed end to slip a complete band over. So I think it was a bad design, made worse by the aging of the components that made the bands melt and the plastic "keeper" brittle so that instead of flexing out the way it broke. So I'm going to recycle the components. I did not find any reviews to tell me how good a component unit this was, so before you hire a pro to try to fix this unit you need to figure out if it will be worth it to you in the long run. Anyway, good luck.
Posted on Apr 12, 2011
STYLUSCITY
  • 271 Answers
SOURCE: How can i use a pioneer PL-Z93 turntable with a pioneer A-717 amp?
Hi, there is no reason for the turntable not to work with your amp. This amp has 2 phono inputs. Moving magnet and moving coil. Your tt likely has a moving magnet cartridge fitted so connect via that input. Cheers John. styluscity.com
Posted on Nov 14, 2011
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
Nov 14, 2011 | Audio Players & Recorders
I just bought a pioneer pl-420 direct drive record player and when i hooked it up to my samsung home theater system via the aux ports in front but when i play records the sound is too low im have to turn...
If the player has a MD/MC pickup head, you need to use an input suitable for MD/MC
(Magneto Dynamic/Moving Coil). If that is not available, you need to buy a standalone
phono pre-amp (pre-amplifier with RIAA-correction curve). Like the TCC TC-400G/L.
Example: See HERE and some info HERE.
Oct 07, 2011 | Pioneer PL-990 Turntable
About 11 months ago I bought an Elliptical upgrade stylus for the PL-990 and it worked great. Recently, it started giving me problems. The left channel would be very distorted and also would fade in and...
Very odd! Sounds like it's not fitting in right. Are you sure that you have the right type of stylus for the cartridge? If in doubt replace the entire cartridge & Stylus. If it still plays up then it's in your amp after that course of action.
Aug 18, 2011 | Pioneer PL-990 Turntable
I have a pioneer home theater HTZ585 DVD system. Since yesterday, i get 'SUB COM' message displayed (blinking) and nothing seems to work anymore. Any suggestions?
I can't find that message in the manual but I would guess it's trying to tell you something is wrong going out to the subwoofer. Trace the wiring. If you don't see anything wrong, disconnect the sub and see if the message disappears or changes.
Apr 30, 2011 | Pioneer 740 DV Home Theater System System
I have a Pioneer PL-740 turntable that works extremely well, except there is zero damping when either lifting or dropping (and I mean dropping) the needle. I know there is generally a hydraulic oil that...
most turntables actually only dampen during automatic play and return (eject) not when manually manipulating the needle. Better turntables will have a counterweight at the back of the arm behind the pivot point, but that is to decrease wear on the vinyl and increase needle life and audio fidelity in the higher end.
Some turntables have a lifter arm that is dampened, but if your player doesn't have such a mechanism, or if it has one and you choose to manually manipulate the needle without it's usage, there is no dampening.
The fix unfortunately is to buy a turntable with a dampened lifter arm, and to use the arm when lifting and lowering the needle.
Mar 23, 2011 | Pioneer Audio Players & Recorders
I bought pioneer cdj's 200 in the USA. Unfortunately it was used in SA without a correct adapter. I think it blew my cdj's because the 210 adapter was not used. Is there anyway i can fix them?
u could have bloo the trancformer,but check the fuse inside the unit first, & the plug coz u never know unless u test it.
if it still doesnt work then the trancformers probobly gone.
http://www.donberg.ie/warehs/groupbe.htm
Aug 04, 2009 | Pioneer CDJ-800 Turntable
Pioneer VSX-D903S
What country did this set come from?
Feb 27, 2008 | Audio Players & Recorders
81 people viewed this question
 Grubhead
Grubhead
