Question about Gateway LT2104u Netbook
How to reset gateway lt2104u
The power light, upon booting up the netbook, flashes only a couple of times and nothing else starts to boot
  • 38 Answers
SOURCE: gateway mx6447 wont power up at all
Basic rules say check the fuse in the olug, is it still woking. 2 is check the lead with Multimeter or Voltmeter, 3 is check the battery. I wont go further.
Posted on Feb 10, 2009
  • 1019 Answers
SOURCE: red light on the front blinks 4 times
The 4 blinks are telling you that there is a fault. The same as Computer Bios Beeps.
I,d suggest removing the RAM/Memory, and replacing it. Press and hold the power button for more than 4 seconds, to ensure it isn,t in standby mode. failing this remove the cpu and re-seat it as it may be slightly out of position, or out of it,s socket. finally have a look at the back or underside to see if there is a reset switch/hole.
Mike @ Compurepair.
Posted on Jun 12, 2009
  • 177 Answers
SOURCE: Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Posted on Mar 07, 2010
sethdileswar
  • 253 Answers
SOURCE: gATEWAY mt3422 WILL NOT BOOT UP. Power light is
if your harddisk is ok than , u open your notebook motherboard and clean processor fan properly,,than again fitting your laptop than boot from cd rom (make sure that your cd rom is ok )
Posted on Apr 14, 2010
jamespcastle
  • 128 Answers
SOURCE: I have a Gateway MD2614u, and it won't boot up.
I suspect that the hard drive motor is going out. Try a new hard drive. If it doesn't fix it, you can always return it.
Good luck,
James.
Posted on Apr 25, 2010
Forgot admin password cannot how to reset admin password gateway lt2104u
Look on Ebay for a password reset disk. Many vendors on Ebay sell a bootable "linux" disk that you boot from and then you can edit your password file on Windows. I have versions for XP/ Vista.Windows 7.
Be sure to get one that works for your version of windows. You must set the BIOS to boot from the CD drive first for this to work. About $5 to $10 for the reset disk.
Regards,
Dennis
Apr 18, 2014 | Gateway LT2104u Netbook
Gateway laptop i push power button it wont boot up but leds in front flash 4 times
Try holding down the power button instead of just pushing it. I had this problem with my HP dv7 and holding the power button down for around 5 seconds worked for me. Also make sure that its plugged in to a power source.
Oct 23, 2012 | Gateway Computers & Internet
Gateway LT2104u netbook camera not working
Go to Gateway support and download and install the drivers for the camera. The ones in your computer were probably corrupted in some way. Go to the control panel open the device manager find the yellow explanation point. That will probably be your camera. Right click on it and click update drivers, click on search for drivers and it will eventually get on the internet and hopefully download the drivers. If not go to the Gateway support and download
Jun 22, 2012 | Gateway LT2104u Netbook
I have a gateway nv79u and it wont stay on for more than 30 mins. It keeps shutting off with error code 41 kernal-power.
Hi Michael,
Kernel Power - Error Code 41 often times caused by conflicting drivers. If you are trying to play a game or watching videos then the computer suddenly turns off, you must first check the following:
1. Open Device Manager (click Start > type Device Manager) and go to Sound, Video, and Game Controllers and see you have two audio drivers installed and disable one at a time and see if it fixes the issue.
2. Boot into Safe mode (press F8 continuously upon boot up) and see if the computer still shuts down there. (If it doesn't try disabling start-up items using this guide
3. If you're pop-up error messages like "System services cannot be started" upon boot-up, you're operating system is corrupted and must be restored to default settings. (you need to press F11 upon boot up - remember to backup your important files)
3. If Step 2 above is true, check if the computer is overheating. If it does, the computer needs to be serviced. Contact gateway support at 1-800-846-2000.
Cheers.
Sep 01, 2011 | Gateway NV7915u Notebook
Gateway MA7 (MX6955) Will not boot up, or power on. Battery and AC plugged in battery LED light flashes 4 times and nothing... battery in AC unplugged.. same thing... battery out, AC plugged in.. nothing,...
hold on i have a gateway here let me see if it does or not.nope mine works without battery i had to push the power button a couple times but it fired up.could be your MB
Oct 08, 2009 | Computers & Internet
Computer won't turn on
pull the battery out of you motherboard it will reset your bios leave the battery out for a couple minutes then when you put it back in boot up and it should go into bios use your arrows to select set defaults hit enter then reboot it should boot up then if not its possible you have a hard drive issue.
Jan 03, 2008 | Gateway 506GR PC Desktop
Gateway LT2104u Netbook Logo
60 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
