Question about Fisher Washing Machines
Spin out of balance
I have a fisher and paykle quicksmart MW613 that goes out of balance on sspin cycle on average about every 2-3 loads when doing a full load of washing on the full water level. how can i fix this? what is this a symptom of?
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
SOURCE: Out of balance
Installed no slip carpeting underneath machine, worked fine.
Posted on Feb 16, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
BIKER T
  • 909 Answers
SOURCE: spin cycle is off balance washing machine is
i dont believe it is the agitator per say. Assuming this problem has just started and doesnt have transportation bolts still attatched. Two conditions cause the imballance. 1)(if unit is a top loader) Check if all 4 shock absorber springs are well lubricated and not sticking. 2)A more involved problem which often happens, Underneath the washer, is the drive motor. on the motor, is a round pulley. this pulley needs to come off and strip further until you see a long spring. If it is not broken, clean it up using a solvent and a rag. reassemble and test. (if spring is defective, it will slip instead of grip on a spin cycle.
Posted on Sep 17, 2009
SOURCE: Admiral Mega 22 Plus-Heavy Duty-2 speed Washing Machine
After spinning it does not release the water
Posted on Aug 04, 2010
Fisher and paykel model gw712 . During rinse or spin cycle unit goes out of balance and stops. The rince or spin light flashes and a beeping sound is heard.
your clothes load is too heavy on one side; stop it move some around and turn it back on and see if it doesn't wobble all over.
Jun 06, 2015 | Fisher and Paykel Washing Machines
WILL NOT SPIN/DRAIN CYCLE
Lid / out of balance switch faulty
Drip dry switch / button on
Sud save switch / button on
Apr 03, 2014 | Fisher and Paykel GWL11 Top Load Washer
Washing machine
check lid isolation switch. check for balance of clothes. I would go for the lid switch first. The balance second as if it starts to spin and wobbles violently it will switch itself off to prevent damage and you will have to move the clothes around to balance the drum.
May 18, 2013 | Washing Machines
Spin cycle causing load off balance
Unless there's damage to the machine it is the load. Make sure you aren't washing to small of a load. People do not realize how fast washers spin to extract. Just like they use tiny weights to balance your car tire, it only takes a little bit of weight to unbalance it.
May 02, 2013 | Fisher and Paykel Aquasmart wl80t65c
Continues to go out of balance
The stainless steel bowl has lost its ballast water & goes out of balance,Replace faulty bowl.
Oct 03, 2012 | Fisher Paykel Fisher & Paykel AquaSmart...
Our fisher paykle washer would not complete the spin cycle yesterday, my husband got it to finish the load yesterday and now when I went to start a load tonight the power button will not work. We checked...
Hi just found your posting.Do you still require assistance?The problem with your machine if you 100% have power to it is either your drain pump is faulty or your control module is faulty.Please reply and I can help you further if needed.Hope this helps.
Jun 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Not working fisher and paykle washing machine
what is it not doing? Is it getting power? Is it not going into cycles or what is it going on?
Oct 01, 2009 | Washing Machines
Tub goes out of balance every spin cycle
If it doesnt bang and crash around or doesnt seem like there it is out of balance (ie try running with nothing in it) then theres probably and electronic component problem
Jul 15, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
