Question about Oyen Digital U32 Shadow 480GB External USB 3.0 Portable Solid State Drive SSD
U32 shadow not visible in my computer - Oyen Digital U32 Shadow 480GB External USB 3.0 Portable Solid State Drive SSD
Why does it give me corrupted files?
MAY BE SECTOR ERROR.use data recovery software to recover the items
Jun 29, 2014 | Oyen Digital U32 Shadow 500GB External USB...
Why am I getting corrupted files?
The hard drive is going bad. Save whatever you can elsewhere, now.
A shadow on the picture
The shadow could be caused by a dust partical that is trapped. You could try to dislodge it with an air duster or a vacuum with a soft brissel attachment
Feb 07, 2014 | BenQ W100 DLP Projector
THE STARTING WINDOWS IS NOT VISIBLE ON THE MONITOR BUT THERE IS SHADOWS CAN BE SEEN. THE POWER IS FUNCTIONING ALSO THE CPU.
LCD monitors have backlight (NEON / LED backlight), the screen will go dark if the backlight circuit / electronics or the backlight itself fails. Get it to a tech who will have spares for your LCD to get it replaced.
Mar 08, 2011 | Samsung T220HD LCD Monitor
The computer is heng not
if you mean your computer is hanging
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Oct 06, 2010 | Seagate Hard Drive SCSI 73GB 10000RPM 3...
All typeset and pictures have shadows/blur have changed out video card on Lenovo computer - seemed successful for a while but now back to square one. any ideas
Try a different "data" cable between the monitor and the computer.
Connect the monitor to a different desktop/laptop.
If the "shadowing" is still visible, then it's the monitor that has gone "bad'.
Connect a different monitor to your Lenovo computer.
If the "shadowing" is still visible, then your monitor is OK, and your video-card is the problem.
May 18, 2010 | Lenovo ThinkVision L192 19" LCD Monitor
I have a SyncMAster 2220wm and have connected it to a new CPU using a VGA cable. Now everything has a shadow on it. Do I need a SVGA cable.
Hi, Check the VGA cable connectors. This type of shadows usually occur if the cable is not connected securely to the VGA socket of the CPU. Remove and reconnect the cable securely. Also check the cable for any visible damage.  This should solve the problem. Thanks.
Aug 02, 2009 | Computers & Internet
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
Oyen Digital U32 Shadow 480GB External USB 3.0 Portable Solid State Drive SSD Logo
Top Oyen Digital Computers & Internet Experts
David Payne
David Payne
Are you an Oyen Digital Computer and Internet Expert? Answer questions, earn points and help others
