Question about Fahrenheat Electric Convector Baseboard Heater, 240 Volt
8 foot heaters in tandem
2- 8 foot 220 volt heaters next to each other. feed end has 2 wires. Other end has 4 wires spliced together in pairs. Want to feed another heater from the 4 wire side to another heater, the side with 2 wires. Tried breaking the crimped splices skinned then wire nut to feed out to another heater. The second heater is not working.Is this wiring correct?
    New Friend:
  • 92 Answers
You should not wire heaters in series in less you know how to size wire and the amps that a wire can carry.you are flirting with fire
Posted on Feb 24, 2009
How do I wire two tandem batteries for an electric scooter
Tandem batteries... is a fairly loose term to be dealing with on batteries... SIMPLY BECAUSE THEY ARE EXPLOSIVE.
TANDEM voltage
(assuming you were trying to achieve 24 volts with 2
12 volt batteries would NORMALLY be called serial...
Where as to increase AMPACITY ... called "parallel."
Rather than risk severe burn, blindness (end of life
experimenting with EXPLOSIVES...
You need to go back to your source for better information ...
or
Provide better information here... Pretty please
Jan 12, 2017 | Electric Health & Beauty
Controlled by wall thermostat. Heater has two wires, both ends, white/black
so my question is this is electric heat? it sounds it so next question is it 120 or 240 volt. but you will have a black and a white wire from your electric panel feeding the line side of the thermostat then another wire loading from the t-stat to the electric heat. i hope this helps. Tom the electrician
Apr 04, 2015 | Heating & Cooling
I have a pnlc1001ya can I get a replacement charging unit as the rabbit has chewed the cord
You want the AC adapter, not the charging unit. If there is sufficient undamaged cord, you can splice both the wires together and use the AC adapter.
Carefully identify the wires - one will have a raised rib or line printed on it. Strip 1/2 inch of insulation off each end of all wires. Matching the wire pairs, twist the stripped wires together. Fold the stripped wire back in line, and wrap the spliced wire connection with electrical tape. Do this for the other wire. Inspect you work to ensure the spliced wires are completely covered and do not touch each other. Wrap the entire spliced section in electrical tape and hook it up to the charging base.
Ebay has a selection of replacement ac chargers. Look on the back of the charging unit for the model number, and observe the voltage and current ratings.
Mar 17, 2015 | Panasonic Lands Phones
I am wiring my new Fahrenheat hydronic baseboard heater. I notice that inside the left endcap (and also inside the right endcap) there are TWO pairs of wires already attached together, a red with a...
Hello,For 220volt Choose which side you will connect to.Take the nut off that side black=black / white=red leave the other side alone.The manual is useless.
Oct 17, 2010 | Fahrenheat Electric Hydronic Baseboard...
Installing an up to date leviton how do i know which wire crosses over to the next? 30A
follow the wires to where they enter the breaker cabinet, the ones coming out of a cable will be a pair, red and black or black and white. If you have a volt meter, turn on one set of switches on the breaker and measure the terminals, the one with 230 volts will be the ones to connect that set of wires to
Sep 04, 2010 | General Electric 40/30Amp 4-pole tandem...
I'm replacing a non-hydronic electric baseboard heating unit with a Fahrenheat hydronic one. My old unit was 240v using 2 conductors plus bare ground wire. The fahrenheat (PLF series) unit's instructions...
Hello. The red and the black are the hot wires. Therefore, connect one of your conductors to the red and the other conductor to the black. Use wirenuts. The bare ground wire should be solidly attached to the new unit's green wire using a wire nut.
Regards, Joe
PS: please rate my answer. Thank you.
Jan 06, 2010 | Fahrenheat Electric Hydronic Baseboard...
I pulled the wires out of the abs plug that goes to the sensor im going to cut the other plug off and splice the wires together without the plug i need to know what i should pair the green wire to and what...
Splicing your wires together will accomplish nothing but to waste your time.The sensors send an electrical signal to the computer.No signal means no ABS and the light will turn on.You will not get a signal by splicing the wires.
Oct 18, 2009 | 2007 Chevrolet Colorado (Extended Cab) New...
I cut the wires to my home theatre speakers and I want to splice them back together. How do i do it?
Dont worry this is easy,
1. Strip the wires back about 1/2" each
2. Twist the ends together nice & tight
3. Wrap the exposed wire with electrical tape so you cant see the bare wire
4. test run the speakers
5. If you get any feed back or it sounds bad switch the wires around on the back of the speakers
That should do it
Good Luck
Jul 16, 2009 | Philips HTS-6500/37 System
Wiring diagram for ford focus 2005 ghia 1.6
If you know which wires they are, ask an electrician to "but-splice" the wires back together.
Or if you think yourself wise enough to handle the situation, go buy, wire-strippers, **** splices and a crimper for those wire splices.
MAKE SURE YOU GET THE RIGHT SPLICES FOR THE GAUGE WIRE.
Strip the ends of either wire(you only need to strip about a1/4 inch), twist them CLOCKWISE, place them in the **** splice, and crimp the ends, and PRESTO! wire has continuity.
Make sure you splice the right wires together, or you will have blown fuses, and things not operating correctly.
Oct 07, 2008 | 2005 Ford Focus
Fahrenheat Electric Convector Baseboard Heater, 240 Volt Logo
178 people viewed this question
Top Fahrenheat Heating & Cooling Experts
butch welch
Paul Carew
Are you a Fahrenheat Heating and Cooling Expert? Answer questions, earn points and help others
