Question about Lexmark X5150 All-In-One InkJet Printer
Only prints one document
We can print one document, but if we try to print something after that it sits in que. When I pull up the printer dialog box, it says that it is trying to delete the previous document (the one that just printed). I never deletes. If I manually do it, it still doesn't delete. We have to reboot the printer to get it to print.
  • aawolters Jan 24, 2009
    It didn't work.
  • Anonymous Jan 26, 2009
    I have this same problem and I updated everything I could. =/
    President:
  • 2,692 Answers
I would start by reinstalling the software and updating the driver. That will norrow down the problem to being hardware if it does not fix it.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Jan 24, 2009
No content prints on document when word document is sent to the printer
Is the problem only with Microsoft Word? If so you might have selected something else in the "Print What" box in the "Print" dialog box instead of "Document". See the below screenshot and make sure that the "Document" is selected. The Print dialog box will come up when you click the "Print" sub-menu from the "File" menu, i.e. click "File" and select "Print".
If this doesn't help, reinstall the printers drivers/softwares. That should fix your problem.
If the problem isn't only with Microsoft Word Documents, then there might be other problems with your printer, it could be cartridge/s, ink, drivers, etc..
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 14, 2011 | HP Officejet 6500 AllInOne InkJet Printer
I have a pinnacle Pro 901. How do I print in black & white only?
Hello, try this: Start Menu, > Printers and Faxes> then right-click on your printer. Move the pointer down to 'Printing Preferences' and click the 'Advanced' tab. There you will (should!) see 'print in greyscale' . Select this then click 'Apply' then 'OK' at the bottom of the page.
Regards,
nicam49
Dec 01, 2010 | Lexmark X2250 All-In-One InkJet Printer
How do i get rid of the queue ?
Open printers and faxes from the start menu or in control panel if it is not on your start menu list.
Double click the printer icon for the 5610
Under the "Printer" menu heading scroll down to select "cancel all documents"
Select yes if the confirm box pops up.
NOTE: if there is a large que it may take a while.
To reduce number of copies in the printer dialog box when you click "PRINT" make sure that the number of copies is set to "1".
NOTE: This dialog box comes up if you select print from the Menu bar but not if you use the quick print icon on the toolbar.
Hope this helps
If not repost with more info like your specific OS and connection type etc.
RJ
Jun 01, 2010 | HP Officejet 5610 All-In-One InkJet...
WHEN I AM TRYING TO PRINT THE PDF FILE , I AM GETTING DIFFERENT MARGINS COMPARED TO ORIGINAL PDF FILE.SOME PRINTER IT IS ACTUAL AND SOME PRINTER IT IS DIFFERENT.HOW TO RECTIFY SUCH PROBLEM.KINDLY...
Acrobat reader scales pages on printing, depending on the printer and its driver. By default, Acrobat Reader will use one of the scaling options.
Before printing the PDF document be sure that you select the right kind of paper size such as A4, Letter and B5 which will be printed. Paper size is defined in the Document Setup dialog box for the document.
To print the document without different margin problem:
- Open the Acrobat Reader’s Print dialog box (Choose File > Print).
- Choose “None” from the “Page Scaling” drop-down list. (It will not change until you change it again).
- Then click “OK” to print the document.
This may solve your problem.
Mar 22, 2010 | Adobe Acrobat 6.0 Professional for PC
Can not delete document in print q - nothing else will print
Open task manager,(Ctrl +Alt +delete) and end task on print spooler,delete the file.print spooler will restart automatically.
This works best if you have the que window open first.
Please rate this fixya
Jan 25, 2009 | Lexmark X3550 All-In-One Printer
Dell Laser Printer 1720dn Will only print test pages. When attempting to print a document, I click on 'Print', and the command is sent to the printer que, but the printer doesn't print. I've tried deleting...
Check that the correct printer is set as default. Also use File Print so that the selected printer is shown rather than using the Print button. If the test pages are being printed from the computer then the communication is working.
Dec 31, 2008 | Dell 1720dn Laser Printer
Not alinged
Does your printer Dialog box have a setting "Fit to Page" in the Properties Dialog box?
If yes, click on this setting.
You have not stated what documents you are trying to print.In Excel you may need to set the print area first. In most other programs fit to page will fix the problem.
Good luck.
Apr 25, 2008 | HP Deskjet 6980 InkJet Photo Printer
Mirror image
Printing Iron-on Transfers
Load the iron-on transfers.
With your document open, click File, then Print. The Print dialog box appears.
In the Print dialog box, click Properties, Preferences (or Options).
Select a print quality:
In the Print Properties dialog box, click the Quality/Copies tab.
From the Quality/Speed area, select Normal or Better.
Select a paper type:
In the Print Properties dialog box, click the Paper Setup tab.
From the Type area, select Iron-on Transfer.
If your software program does not have mirror or iron-on settings, select a print layout:
In the Print Properties dialog box, click the Print Layout tab.
From the Layout area, select Mirror.
Click OK.
To print your iron-on transfers, click OK.
NOTE: To prevent smudging, remove each iron-on transfer as it exits the printer and then let it dry before stacking.
Mar 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
Printer will default to "save as" screen when que to print
In administrator login the default printer is "Microsoft XPS Document Writer", make sure that the default printer is the HP Printer.
OR
You have to change in the Print dialog box, select the HP Printer instead of "Microsoft XPS Document Writer"
Cheers - Parveen
Feb 08, 2008 | Dell Inspiron 1501 Notebook
Lexmark X5150 All-In-One InkJet Printer Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
