Question about D-Link DIR-625 (790069292637) Wireless Router
Dlink DR-615 not allowing access to certain live feed websites
I have an iMac and my roommate has a laptop pc [Vista]...when we are both using the Dlink DR-615 router he could not access certain live feed news network websites he was used to accessing when he had a direct connection through the modem [not the router] to his computer...after a few tries I fixed some of the issues by unchecking the "Enable Quos Engine" option in the advanced option. That fixed the problem for him to access live news feed on one website, but the problem still persists on two other websites [every other website works like cnn live news works]....Has anyone else had a similar problem and been able to fix it cause as of now the only option for him to access these two other websites live feed is to disconnect the router and plug directly from his modem to his laptop which is a pain cause I don't have access to the internet until he is done...
    Genius:
  • 1,269 Answers
You need to update the router's firmware and hard reset it by pressing the reset button for 20 seconds, unplug power for 10 sec then plug it back in.
Posted on Feb 13, 2009
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
I have Dlink DIR-615 Hardware Version: C2 Firmware Version: 3.01 and want to upgrade firmware as it hangs when i use my Samsung Tab2 over wifi...
The new firmware is available with instructions at Dlink's Website.
http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
This is the english address for the support on your model of router.
Feb 01, 2013 | D-Link DIR-615 Wireless Router
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
Why can't I connect my iMac to my Dlink DIR-615 wireless router?
That is a older wifi access point and maybe the N is not compatible for your imac. I would get a dual band 2.4/5Mhz wifi Access Point.
Feb 02, 2012 | Apple iMac 17" MA199LLA Desktop
I have a DLink DIR 615 wireless router from my cable/internet provider. It works (mostly), but setting up and securing a wireless network is nearly impossible. How can I create one, secure it, and can I...
I am not sure what you are missing, you should be able to do what you desire, with the unit you specify.
Here is how:
Wireless Router settings:
It is usually easiest to run the install wizard, which you can get from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below:
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your Internet Browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit. Look under support, downloads, drivers or similar sounding areas.
Things to set:
(Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes. SAVE OFTEN.)
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is typically NOT the security issue.
2. Set a recognizable system ID (descriptive name is easier to find when you need to connect wirelessly).
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits.
May 31, 2011 | D-Link DIR-615 Wireless Router
I installed dlind DR-615 into my laptop and it says the connection is strong but it still won't connect.
understand that using an operating system Vista or 7.
Try updating the laptop's wifi driver
Feb 05, 2011 | D-Link DIR-615 Wireless Router
Dlink DIR 615, network name changed, won't accept password
It appears your brother has changed your wireless router settings.
You can reset the Dlink back to the default settings by -
Power off the Dlink and press and hold the RESET button on the back of the Dlink and the power on the Dlink. Hold the RESET button for 5 secs. until the LEDs flash at the same time.
Connect a LAN cable from the computer to the Dlink. Open a browser and enter the Dlink's configuration URL
http://192.168.0.1
Default login = admin
PW = blank (just press Enter)
You can now change the admin password and set up a new passphrase (ie encryption)
For details on how to secure your wireless from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
May 19, 2010 | D-Link DIR-615 Wireless Router
Cannot access yahoo website at all.
There might be some configurations needed in your dlink 615. It is better to let your ISP check it. Maybe there is a DNS problem and misconfigurations.
Jan 03, 2010 | Yahoo Mail
I FORGOT PASSWORD FOR DLINK-DIR 615 AS IT NEEDS TO CONNECT TO LAPTOP ..HOW COULD I FIND IT?? I TRIED TO LOG IN AS IT REFUSED.. THANK YOU
Use an Ethernet cable to connect the laptop to the router.
Access the router's built-in web-interface, and run the "Wireless Networking Setup Wizard", and choose a password.
Dec 26, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
I currently use a cable modem to connect to the internet from my Imac. I have dlink wireless router that I used to have for my old pc so that my work laptop could connect. How do I install the dlink on the...
No need to install the dlink on the imac. All you need to do is connect the modem first the dlink. (Modem connected to Internet or WAN port of the dlink). Now if they are connected, your imac should be plugged in to port 1 of dlink, and your PC to port 2. That should do it.
Nov 18, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
D-Link DIR-625 (790069292637) Wireless Router Logo
336 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
