Question about IBM ThinkPad A21m 2628 Notebook
LOCK LAPTOP IBM
CAN NOT GET TO WINDOWS "START-UP,locked by previous adminstrator
  • williamjkick Jan 24, 2009
    Still does not work,there is a symble on the screen of a mouse & a Lock.
  • williamjkick Jan 29, 2009
    Still on this ibm,if i erase the Dard-Drive,can i start from scratch bying reloading WILDOWS?
  • 40 Answers
Try going into safe mode. Shut your computer off completely and then turn it back on, when you do start tapping f8 and then choose safe mode with networking. Once your system comes back up see if you can get into any user account. If you can press the start button and click the picture at the top beside your name to enter the user accounts screen, then press the home button, and click on the administrator. from here you can have the option to remove the passwords. If you cant get into any accounts in safe mode you will sadly have to do a recovery, which entails reinstalling windows.
Posted on Jan 24, 2009
  • jadestephen Jan 24, 2009
    then unfortunatly the only way to solve the issue is going to be erasing your system and doing a recovery.
  • jadestephen Jan 29, 2009
    absolutely!
Lenovo p580 numlock off
What options have you tried ??
Number Lock on IBM Laptop Computers b> Laptop computers have the advantage being portable and self-contained, but among their drawbacks is a keyboard without a separate number keypad. While for most applications number keypads are unnecessary, they can be useful for data entry. Laptops sometimes provide a number keypad by giving certain keys double duty, allowing them to enter numbers rather than letters when a "Number Lock" setting is turned on. Number Lock, however, can get turned on accidentally, or enabled by an operating system by default, which can really mess up your typing. If typing "M" ends up displaying a "0" on your screen, Number Lock is probably the problem.
Try to locate the function key. On a T-series ThinkPad, it's in the lower left hand corner. It should be labeled "Fn," and the lettering may be blue, green or red instead of white. If your laptop lacks a "Fn" key, use the "Shift" key for Step 3 below instead. Locate the key labeled with "NmLk". On a T-series ThinkPad it shares a key with "ScrLk" which sits on the very top row between the "PrtSc" and "Pause" keys. On other IBM laptops, the "NmLk" key might share a key with "Delete." While holding down the "Fn" key or the "Shift" key, depending on your model, press the "NmLk" key. This should turn off Number Lock and restore your keyboard to its usual state. Number Lock on an IBM laptop is a "toggle" setting. You can turn Number Lock on by following the same steps.
also Examine your keyboard to ensure your "Number Lock" key is not activated. This activation is indicated by the key being lit up. If the key is activated, press it to deactivate the lock. The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor. In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
Jan 30, 2013 | Computers & Internet
When I disconnect my IBM ThinkPad R50e from an external monitor, the text on the laptop is wacky. How do I fix this?
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
hope this helps
Jul 11, 2012 | IBM ThinkPad Computers & Internet
I have a cmos lock on my ibm laotop
There is no such thing as a CMOS Lock. CMOS is a battery.
Maybe you have a BIOS Password lock? Or a Hard Drive Password Lock? Or A Windows Welcome Screen User Login Password Lock?
Apr 09, 2012 | IBM ThinkPad R51 Notebook
When i turn on my labtop only a lock symbol comes up
BIOS password locked...
Either Remember the password, or you will have to call IBM to ask for a code..
Nov 19, 2009 | IBM ThinkPad T20 2647 Notebook
I bought this laptop on ebay and when I turn it on, the ibm screen comes up but when it disappear there is a little computer and lock in the top left corner of the screen. How can I remove it. I emailed...
Can you post me the exact model of your IBM laptop, some of these IBM models can not be reset at home and you might have to take it to a IBM service center, they might not unlock it since you bought it from ebay, so you might have bought a big paper weight.
Nov 08, 2009 | Office Equipment & Supplies
Access IBM Button does nothing-- need it to start my comp up
The Access IBM button is F11. This lets you boot the recovery partition. It is possible the previous owner removed the recovery partition to regain the hard disk space it uses.
If the recovery partition is gone, you can order the recovery disks from IBM/Lenovo.
Also, make sure you have the BIOS boot sequence in the correct order.. the primary boot device should be the cd-rom for installing the Vista disk. It is usually F8 on startup to load the BIOS.
Make sure the Vista disk is in the drive when you startup the install.
Here's a link to all the Thinkpad R50e drivers you'll need to get it fully working in Vista:
http://www-307.ibm.com/pc/support/site.wss/MIGR-55042.html
If you have just formatted, have you let the Vista disk finish the installation? Just a thought..
Good Luck!
Chris (ziraffa)
Dec 29, 2008 | IBM ThinkPad R50e Notebook
Lock out bioas or harddrive lock
you have luck on BIOS or HDD or both? What's on the screen when you power on the laptop?
Nov 16, 2008 | IBM ThinkPad A31 Notebook
Lostuserandpassword
When you power the machine start pressing F8 until it goes to a menu screen, then start in safe mode. Log in as administrator, not your account, from the administrator account you can clear the password in your account.
Aug 29, 2008 | IBM ThinkPad T42 Notebook
IBM ThinkPad A21m 2628 Notebook Logo
137 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
