Question about Norelco 7800XLCC Electric Shaver
How to open a case of a 5821xl Norelco
Need instructions for replacing battery for Norelco 5821xl
Replace batteries of Norelco 5821XL
Posted on Jan 06, 2011
    New Friend:
There are two screws on the back, but one of them is hidden. You have to pop up the sideburn trimmer to see it.
Posted on Jun 10, 2013
Replacement head for 5821xl
philips norelco HQ5 replacement heads for electric shaver norelco 5821xl cutter blades replacement parts.
Sep 04, 2012 | Norelco Reflex 5821 XL Electric Shaver
Need instructions to open to replace battery in the Norelco 5821 XL
You will find replacement batteries for model 5821XL at shaveroutlet.com. See link below. Scroll down the page for helpful installationtip videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Aug 16, 2011 | Norelco 7800XLCC Electric Shaver
Need instructions how to open a Norelco 5821XL to repl battery
Model 5821XL simply has two screws on the back. With the unit UNPLUGGED, simply remove the screws and remove the back of the casing
Need to replace the batteries in a norelco 5821xl
norelco battery replacement NiCd two batteries pack for electric shaver philips norelco 5821xl replacement parts.
Feb 06, 2011 | Norelco Reflex 5821 XL Electric Shaver
PROBLEM: WILL NOT TAKE A CHARGE. DEAD BATTERIES (?) - WOULD APPRECIATE PROCEEDURE NEEDED TO REPLACE BATTERY(S) FOR NORELCO ELECTRIC SHAVER MODEL 5821XL. SHAVER IS SEVERAL+ YRS. OLD AND IN EXCELLENT...
Dead batteries will cause the shaver not to charge. Batteries for model 5821XL can be found at shaveroutlet.com. See link below
To change, remove two screws on back and remove back cover. Remove plastic clip that is in the way of removing batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Dec 31, 2010 | Norelco Reflex 5821 XL Electric Shaver
How to change batteries?
mcdevito75 here, There are 2 versions of batteries in Norelco shavers 1 system is where the batteries are soldered to a circuit board in which case you"d have to replace the shaver or find an appliance repair shop in your area, The 2nd is where you can replace the batteries your self but, you;ll need a set od torx screwdrivers available at any auto parts store, refer to Norelco online at Norelco.com for Battery replacement. Look for these torx screws on the back cover or by lifting the shaver head .
Jun 20, 2010 | Norelco Reflex 5825 XL Electric Shaver
Need batteries and instructions for replacing
You will find replacement battery pack for model 5821XL on shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To change batteries, you will need to remove the two screws on the back to take off the back cover. You will then have access to th batteries.
Batteries are soldered to the circuit board. You can unsolder to remove but I would suggest that you carefully break the tabs off of the old batteries. This will leave the old battery tabs connected to the circuit board. You can then just solder the new batteries to the old tabs. This way you dont have to solder irectly to the circuit board.
If you are unable to repair the shaver yourself, shaveroutlet.com can do it for you. See info at link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Apr 12, 2010 | Norelco Reflex 5821 XL Electric Shaver
How to open case on Norelco T-3000 beard trimmer
Remove the bottom screw. Next, the on/off slide switch has to be lifted off carefully with a small flat screw driver. Its kept in place with a small spring steel clamp. After you've removed it lift off the steel clamp and remove the slide mechanism by carefully twisting it out of position. Once that's done it will twist open easily.
Jul 25, 2009 | Norelco Health & Beauty
Battery needs replacement
Replacing the batteries is not an easy job. You need to have a special Torx screwdriver to undo the screws.
The batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant)
It may be worth speaking to your local Philips Service Center (refer to www.philips.com)
Your shaver should also be a Mains shaver - if you plug it in and it works full power immediately you've got a workaround. I usually recommend if you're replacing a shaver to spend a little more $$'s to get one that is mains and rechargeable so that when the batteries die, the shaver is still useable.
Apr 26, 2009 | Norelco Quadra 6846 XL Electric Shaver
How to replace Battery
You will also need a soldering iron, as the batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant)
You could obtain batteries from your local Philips Service Center (refer to www.philips.com) or check your Yellow pages for Battery Suppliers.
Apr 07, 2009 | Norelco Cool Skin 7775X Electric Shaver
Norelco 7800XLCC Electric Shaver Logo
510 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
