Question about Bear Archery Charge RTH Compound Bow Package
Upgrade my bear charge bow accessories
I want to use my bear charge but i would like to upgrade my bow to an expert level
What year was a Fred Bear bow made that has writing on the riser 9R865 AMO-56 45#, ON THE LIMB IS PRINTED, BEAR GLASS POWERED GRIZZLY. The bow also has a copper BEAR medallion.
DATING YOUR FRED BEAR BOW
There are several features and changes that were made to the bear bows over the years that will help narrow the age of your bow or your potential investment.
1. The Serial Number: These bows usually have, what appears to be a hand inscription on one of the limbs that gives a serial number along with the length and pull weight of the bow. This serial number works very well for dating Bear Bows from 1965-1969 when the first digit of the serial number is the year of manufacture.
For example, a serial number of 5L212 would be a 1965 Bow.
Prior to 1965, the serial numbers for all Bear bows were started over every month, making these bows almost impossible to date by serial number alone. The "K" series of serial numbers (for example KZ9672) were started in 1970.
2. Patent Mark: Most of the BEAR Bows we have sold have the logo and the US Patents printed on it along with the date of CANADA 1953. This date that is printed on all bows made between 1953 and 1972 is simply the date of the patent for a working recurve limb and has nothing to do with the actual model year.
3. Decals & Silkscreening: In 1948 the small Running Bear decal was first and then was replaced by the large Standing Bear decal in mid-1953. The large Standing Bear decal also has the words "Glass Powered Bow" under the Standing Bear.
The large Standing Bear decal was used until 1955 when it was replaced with silk-screening the identification on the bows. By 1956 the silk-screening appeared on all bows.
4. All Wood vs Laminate: If your bow is ALL wood (no laminations of any kind) then your bow had to be made before the mass productions beginning in 1949.
  • If the ALL wood bow has a stamp that reads "Bear Products" in some form it would have been made before the early to mid 40's.
  • If it is stamped "Bear Archery" it would have been made AFTER the early-mid 40's and BEFORE 1949.
  • Also wooden bows with a small "Running Bear" decal can be dated to 1948
5. The Leather Grip: ALL Bear bows had leather grips until 1959. In 1959, the Kodiak Special removed the leather grip and in 1961 the Kodiak did the same, as well as the Grizzly in 1964.
6. The Coin Medallion: Beginning in 1959 all Bear bows had a coin medallion of one type of metal or another. Below are the approx date ranges for the type of coin used.
Copper Coin - 1959
Aluminum - 1960-1961
Pewter - 1962
Brass - 1963 - 1970
Nickel-Silver - 1971-1972
ALL coins were flush with the wood until 1972. In late 1972 the coin was raised above the surface of the bow and came in both gold and chrome covered plastic and are still used in Bear bows today.
7. Manufacturer Location: in 1978 Bear moved all manufacturing and offices to Gainesville, Florida. If your bow shows Gainesville on it then it was made after 1978
8. Model Of The Bow: Check the Model of the bow. Below is a yearly production chart for the most popular Bear Bows.
Wood Handle Take-Down 1969-1972
Wood C-Riser Victor Custom 1973-1975
Magnesium Handle Take-Down A-B-C 1971-1978
Kodiak Static Recurve 1950-1953
Kodiak Recurve 1954-1966
Super Kodiak 1967-1976
Grizzly Static Recurve 1949-1957
Grizzly Recurve 1958-1978
Super Magnum 48 1966-1976
Kodiak Magnum 52" 1961-1977
Kodiak Hunter 58" and 60" 1967-1977
Tamerlane 1962-1968
Tamerlane HC-30 1965-1967
Tamerlane HC-300 1968-1972
Kodiak Special 1955-1967
Temujin 1968-1970
Tarter 1968-1972
Victor Patriot 1973-1977
Victor 1972
Polar (recurve) 1957-1970
Alaskan (leather grip semi-recurve) 1959-1961
Alaskan (recurve) 1966-1970
Tigercat 1964-1978
Bearcat 1964-1971
Black Bear 1972-1978
Little Bear 1965-1978
With this information you should be able to get really close to dating your Bear Bow if not pin-pointing it to the year.
Oct 11, 2017 | Vehicle Parts & Accessories
Bear Compound bow. 60 draw. How much does each turn of the screw decrease the draw weight?
Have you tried this site:
http://shootingtime.com/bow-tech-basics/adjust-draw-weight/
Dec 27, 2014 | Bear Archery Encounter Compound Bow...
1990 black bear bow manual
The big box stores like cabelas has them. Just ask we used to give them away for free when I worked for them. Also maybe on the web for free.
Dec 07, 2013 | Bear Archery Brave III Compound Bow...
Can you put a sight on bear archery youth brave 3 compound bow
If it has 2 holes in the riser to accept a sight yes then you can.
Feb 07, 2013 | Bear Archery Youth Brave 3 Compound Bow...
How do I adjust the draw on a Bear Warrior III Bow
look in the manual and you will see what number coinsides with which draw length. On each cam there is a module with numbers on them. You set these to adjust draw length.
Jan 12, 2013 | Bear Warrior 3 Compound Bow Kit
How many different types of bows are there?
There are seven main types of bows. Recurve bow, compound bow, self-bow, Composite bow, backed bow, longbow and a spine bow.
Aug 26, 2012 | Betsey Johnson Archery
Bear polar recurve brace height
String length is 60 inches. The brace should be 7.5 to 8 inches. Listen for noise and feel for hand shock. Twist the string to add brace. Shoot for the sweet spot. When the bow becomes quiet and the vibration and hand shock is minimal, you have found the sweet spot. Measure your brace height at this point and write it down.
Mar 30, 2009 | Sport & Outdoor - Others
Rail bows when door is closed
What you describe is common with those operators.
Jan 01, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Bear Archery Charge RTH Compound Bow Package Logo
88 people viewed this question
Top Bear Archery Archery Experts
pbickwermert
Level 1 Expert
Andre De Beer
Andre De Beer
Level 1 Expert
Tom Chichester
Are you a Bear Archery Archery Expert? Answer questions, earn points and help others
