Question about Belkin F6C550AVR 550VA Battery Backup with Surge Protection UPS System
How to replace the circuit breaker
The system is not turning on when the activation switch is pushed.
Power windows dont work
There is a circuit breaker for power windows .
Power Window System Components
The power window system consists of the following components:
Driver Door Switch (DDS)
Passenger Door Switch (PDS)
Body Control Module (BCM)
Rear door power window switches
Power window motors in each of the doors
PWR WDO Circuit Breaker
Power Window System Controls
The power window system will operate anytime the Retained Accessory Power (RAP) system is active or when the ignition switch is in the ACCY or ON position.
The driver master control switches are integrated into the DDS. When a power window switch is activated in the up or down positions the DDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the DDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist and during window motor operation the DDS continues to monitor the motor current to verify proper window motor operation.
The DDS controls the passenger window by a serial message to the PDS. When a power window switch is activated in the up or down positions the PDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the PDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist, and during window motor operation the PDS continues to monitor the motor current to verify proper window motor operation. (Scan tool support is available for this system
Check this circuit breaker
RETAINED ACCSRY PRW BRKR 30 amp. located in the left instrument panel fuse box . if the breaker is good check power B+ at the drivers door switch . connector 1 terminal b yellow wire . Sometimes the wires inside the rubber boot coming from body to door break .
Oct 29, 2015 | 2005 Chevrolet Impala
Our 7788F keeps going into a ground fault condition. Need help troubleshooting. John
Ground Fault ???
Troubleshooting Ground Fault
Troubleshooting a ground fault circuit interrupt, or GFI, breaker is pretty straightforward. Troubleshooting the circuit itself can be quite time-consuming.
The GFI breaker is designed with a test button incorporated into the breaker itself.
Pushing the test button should trip the breaker.
On GFI-style breakers the neutral wire going into the house's outlets is connected to the breaker's neutral connector, the white neutral that comes out of the breaker is connected to the neutral bus in the panel, isolating the neutral bus from the neutral wire going into the house.
The test button actually shorts the neutral wire feeding the circuit to the neutral bus in the electrical panel creating a ground fault that should trip the breaker.
It is considered a ground fault because the neutral bus in the main electrical panel is actually connected to the ground bus through the panel's metal casing. What to do if the test button isn't tripping the breaker
Push the test button on the GFI breaker.
The breaker should trip.
If the breaker does not trip, then it may be that the breaker has already tripped and just looks like it's on.
The position of the switch may only move slightly from the on position towards the off position when tripped.
Push the switch on the GFI breaker all of the way toward the off position.
It may take some force to get the breaker to reset.
Turn the breaker back to the on position.
When the breaker has been reset properly you should feel some resistance when pushing the switch back on.
3 Push the test button again and the breaker should trip.
If the breaker still doesn't trip then you should test for power at the screw connections inside of the electrical panel.
Remove the screw that holds the dead front covering the breaker's connections.
Remove the dead front cover.
Test for power with your voltmeter set on AC volts on the highest scale.
For a single pole GFI breaker, touch the black lead from the tester to the silver screw on the GFI breaker and touch the red lead from the tester to the brass screw on the GFI breaker.
You should see 110 volts on the tester. If voltage is seen but the test button won't trip the breaker, then the breaker is bad and should be replaced.
5
Test for power on a two pole breaker by touching the red voltmeter lead to one of screws with a black or red wire connected to it.
Touch the black lead to the other screw with a black or red wire connected to it.
You should read 220 volts or close to it on your voltmeter.
If you read voltage and the test button won't trip, the breaker is bad and needs to be replaced.
What to do if the breaker won't reset and keeps tripping when turned on
6
Unplug everything that is plugged into any of the outlets on the circuit in question.
Try resetting the breaker again by pushing the switch all the way to the off position and then turning it back to the on position.
If it won't reset and trips when the breaker's switch hits the on position, it could be a bad breaker or a problem in the circuit itself.
7
Use your straight-tipped screwdriver to loosen the brass connection screw or screws on the GFI breaker.
Pull the black hot wire, or wires, out of the breaker's connectors.
Loosen the silver screw the white wire is connected to and remove it from the GFI breaker.
8
Push the switch all the way to the off position.
Turn the switch back to the on position.
If the breaker still won't reset, then the problem is the breaker itself and it should be replaced with a new one of the same size, brand and model.
If the breaker resets normally and the test button trips the breaker when pushed, the problem is in the circuit itself and an electrician should be called to find your ground fault.
9
Reconnect the black wire, or wires, to the brass screws on the GFI breaker.
Reconnect the white wire to the silver screw on the GFI breaker.
10
Replace the dead front cover into the breaker panel.
Install the screw or screws that hold the dead front in place.
http://www.hilo-electric.com/blank?pageid=63
Aug 14, 2013 | Computers & Internet
Motion sensor light not tripping off
If new, then it could be faulty. If old, then may have water damage.
POSSIBLE CAUSE
1. Light switch is turned off.
2. Flood lamp is loose or burned out.
3. Fuse is blown or circuit breaker is turned off.
4. Daylight turn-off is in effect.
5. Incorrect circuit wiring, if this is a new installation.
6. Light control aimed in wrong direction.
SOLUTION
1. Turn light switch on.
2. Check flood lamp and replace if burned out.
3. Replace fuse or turn circuit breaker on.
4. Recheck after dark.
5. Verify wiring is correct.
6. Re-aim light control to cover desired area.
Sep 04, 2011 | Heath Zenith Secure Home Motion Activated...
Cutler Hammer 20 Arc Fault breaker for bedroom outlets will not reset after activating test switch.
The circuit breaker must be turned to the "off" position first from the middle position, and then to the "on" position. The cutler hammer arc breakers carry a lifetime warranty so if it will not reset you may want to contact the manufacture.
Oct 24, 2010 | Cutler Hammer BR120AF BREAKER CIRCUIT BR 1...
Replaced switch but circuit breaker trips on start up ! Mowermm600
Your circuit breaker will trip because of two main reasons:
  • Electrical power point circuit is overloaded (too many appliances active on the same power point circuit)
  • Power Lawn mower has become unsafe as your active live is able to reach your earth connection (e.g. short-circuit). Make sure that you have correctly reconnect ALL your power leads wires (check that the Active and Neutral wires have not been transpose). With power off/device unplug, use a multimeter on resistance range and verify that your active lead pin is not showing a reading against the Earth (middle) pin when the mower switch is turn on or off! There should not be any resistance reading between the Earth and Neutral (opposite pin to Active) pins either!
Hope it helps.
Aug 01, 2010 | Black & Decker Garden
Pushomatic Double Pole, 20amp problem. When I
Most two-pole breakers have a small plastic bar that connects the two switches allowing them to be synchronized and used as a single breaker. However there are some two pole breakers that are intended to be used as two separate breaker and lack the need for the bar that synchronizes them, this is because they are not being used to power a single circuit or item, but separate circuits, or items. so no the breaker is not bad, and yes can be used to power single circuits or items.
Jan 17, 2010 | Connecticut Electric & Switch Thqp115...
My rv's A/C will not turn on. When I was camping I had my A/C running and when I tird to turn it off with my remote the system would not respond. So, I went to the breaker and manually shut it off. The...
first turn the power on to the unit and taking a pencil manually activate the contactor switch by pushing the contactor swith in. (this is the switch that the power feeds to the unit from the supply) if the unit activates and runs then you problem would be your low voltage control(transformer) if not then the problem will be in the circuit board. Good Luck on repairs
Dave
Sep 01, 2009 | Heating & Cooling
Looking for 2 15amp single pole pushmatic circuit breakers.
A Google search for "15 amp pushmatic" turned up several links. Here's one for a retailer with new ones and an eBay store with cheaper prices (maybe pullouts):
http://www.aplussupply.com/break/push/push.htm
http://stores.ebay.com/Sparkys-Place_Pushmatic-Categories_W0QQfsubZ10975954
Did you also check the big-box stores like Home Depot or Lowe's or electric suppliers in your area?
Feb 11, 2009 | Connecticut Electric & SWITCH UBIP130...
Circuit breaker
on the fuse house board? just push the breaker back up. joe
Nov 21, 2008 | MotorGuide STANDARD MOTOR REPLACEMENT...
Belkin F6C550AVR 550VA Battery Backup with Surge Protection UPS System Logo
32 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
