Question about Interface Sonitrol Security Alarm Lcd Plus Keypad Interface
Need sonitrol keypad instructions - Interface Sonitrol Security Alarm Lcd Plus Keypad Interface
We misplaced our programming instructions and would like to know how we set up our keypad with our own code. Thanks, Susan
Reprogramming BE 365:
This link will take you to the page you need, to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Jul 18, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Need to change lock code but lost instructions. BE365 PLY 716
May 21, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Inidcator light is flashing read and I need to change the battery. Are there any special instruction to doing that and do I need to reprogram the lock code after that? Thanks...
According to the installation instructions, you should not have to reprogram the lock after changing batteries.
At any rate, here is a great link where you will find videos and instructions for Schlage locks:
May 16, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Do I have to reprogram my lock after changing the battery?
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Apr 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
I lost my instructions to change the keypad password, can you please instruct me on how to change this password?
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
Jan 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Instructions needed for changing the keypad combination of a Schlage Camelot Keypad Lock 26D. I lost the instructions. Please advise. Send information to douglas_kleweno@nass.usda.gov
Dec 17, 2010 | Schlage Locks & Locksmithing
We have a Model 1245R Lift_master Professional Line 1/3 H.P. Security+ garage opener. We need to reprogram our wireless keypad but the instructions refer to an ENTER button when our keypad has NO ENTER...
If your keypad doesn't have the enter button it is an earlier model and will not work with what you have now. You will need to call your Liftmaster dealer to get the latest model.
Sep 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Trying to reset a new 4 digit code in my wireless remote Sears 139.53754 but I dont know the current code which the instructions say I need in order to reset. I tried the smart button on the motor unit...
You don't need the current code. What you need to do is press and immediately release the smart button and then walk over to your keypad and enter any 4 digit code you like. If this doesn't work your keypad is bad.
Aug 14, 2010 | Sears Craftsman LiftMaster Chamberlain...
DOMINO KEYPAD PROGRAM NEW CODE. LOST INSTRUCTIONS
Press and immediately release the smart/learn button on your motor unit and then walk over and put any 4 digit code you like and press enter.
Jul 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can keypads only for the ti-nspire be purchased?
http://epsstore.ti.com/OA_HTML/ibeCCtpItmDspRte.jsp?section=11092&item=76072&JServSessionIdrootdlek22=umke2gv3m1.n6LzoN8M/AzOnMTOogTxpQOUtxCLbx0Ka0--
Dec 12, 2008 | Texas Instruments TI-Nspire Graphic...
Interface Sonitrol Security Alarm Lcd Plus Keypad Interface Logo
215 people viewed this question
Top Interface Home Security Experts
Tom Chichester
Are you an Interface Home Security Expert? Answer questions, earn points and help others
