Question about KitchenAid Refrigerators
Refrigeratoe Model #KSRA25ILSS03 How do I stop the door water dispenser from leaking?
SOURCE: Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Posted on Apr 04, 2007
  • 146 Answers
SOURCE: water dispenser leak
I think I would think about getting a new one. It would cost more to fix it and then you may not get it back together so it wouldn't leak.
Posted on Dec 29, 2007
Krazytech
  • 725 Answers
SOURCE: water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
Posted on Sep 01, 2008
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
philbran
  • 242 Answers
SOURCE: in door water dispenser leaking on my kitchenaid superba
Hello , I can help , If water is coming out of the tube in the door the only problem you could have is the water inlet valve not sealing all the way causing water to seep out and leak, this is normal to happen over time and the only way to fix it without turning your water off to the unit is to replace the water inlet valve , it is not extremly difficult and will cost about 50 dollars. it is the part that you connect your water line to in the lower rear of the unit. This should get you going if you have any questions just ask. tell me how it works out.
Phil
Posted on Jan 07, 2009
When I run the water dispenser there is a water leak on the floor.
What happens to be the model number?
26173865-qoiw5swae02ur1lnfj3irvmf-5-0.jpg You very likely have a leak in the water line coupling at the bottom or top of the dispenser door where it goes through the hinge
APPLIANCE 911
Apr 24, 2016 | Refrigerators
Maytag fridge side by side freezer door leaks water
If the insulation in the door has blown, it cannot be replaced. If there is a dispenser in the door, look at all the plastic parts for any splits or leaks. To test if it is the dispenser, turn off the water supply for a few days. If the water stops collecting in the door it's a good sign.
Apr 22, 2014 | Maytag MZD2766GES Side by Side...
Model #ed22tqxvw00 problem: my water faucet in door was leaking when not being used so I turned off the water supply to the refridgerator but the faucet continues to leak drops of water. Where is the...
A couple things you need to check for your refrigerator water leak. First, if the water is actually leaking from the plastic tube for the water dispenser, and not from the flapping door that opens to allow ice to flow through door. If water is dripping from the flapping door, this could be ice melting, are you having any freezer temperature problems, is ice cream or bread soft ? If temperatures are fine, inspect the ice in the bucket, is it in clumps or one solid block of ice? If you have either this problem or the water is dripping from the plastic tube for the water dispenser, you likely have a problem with your water valve for either the ice maker or the water dispenser. Either way, both valves are part of one assembly, and both have to be replaced.
The other thing you need to check is that source water valve you shut off. Since there is no pump in a refrigerator, only those valves, the water that is leaking out of the fridge has to still be coming into the refrigerator. In other words, either that source valve is not shut off completely or it too is bad, or you shut the wrong source valve off, possibly for your house humidifier.
Nov 04, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Mar 03, 2008 | Frigidaire PLHS267ZA Side by Side...
Water leaking from water dispenser
replace your water valves one for the door disp is leaking
Feb 16, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Something leaking from dispenser frame
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
21 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
