Question about John Deere Garden
John deere gt262 hARD TO SHIFT MANUAL GEARS
1993 john deere gt262 hard to shift and it has manual shifter.
5 Suggested Answers
  • 566 Answers
SOURCE: manual shift will not engage in gears
hi from uk just out of curiosity ? with engine off try selecting a gear manually by moving the selector link at gearbox from engine compartment if you can feel a selection ? then press clutch and start engine see if car moves with clutch slowly engaged ? if it does? then would suspect the actual g/stick vertical part that fits into the cables gate/selection has broken ? come back with update ? and please give history prior to this fault occuring ?as it would give more of idea what may have gone wrong ?
Posted on Jan 03, 2009
  • 740 Answers
SOURCE: 94 honda accord hard to shift from park
You seem to have two (2) separate problems one may be a BAD brake light switch this switch is mounted at the top of BRAKE pedal and control the locking mechanism on gear shifter(safety component-for example if a kid is sitting in seat with vehicle running he/she will NOT be able to put vehicle in gear without stepping on brake). The other problem is a BAD shifter cable-this cable moves the selector in the transmission when you move shift knob. Good luck and thanks for using FIX YA
Posted on Jan 11, 2009
  • 6982 Answers
SOURCE: WONT SHIFT IN TO PARK
Sounds like the shift cable is coming apart inside. You will need to disconnect it at both ends and make sure it slides easily. if not, change it. If you are good with mechanical things and have a bit of patience it's not too hard. If not let a shop do it.
Posted on Mar 21, 2009
SOURCE: 1997 sL1 Saturn manual transmission hard to change gears
The dipstick is behind the battery, below the master brake cylinder and is not the clutch reservoir. It has a red flip top handle instead of a ring like most dipsticks. It was hard for me to find due to engine grease. I had the same problem and was able to see that I was low on fluid (only a little) and adding fluid helped the problem. Questions? kurt1431 at comcast dot net.
Posted on Jun 29, 2009
2000 Honda GL 1500 SE Gold Wing hard to shift
Hi, Ricky and the usual suspects are:
1. Clutch not adjusted properly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. A loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Hard to shift gears GL1500 Information Questions goldwingdocs com
GL1500 shifting issues
Honda GL1500 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GOLDWING GL1500 Owner Manual
Aug 31, 2017 | 2000 Honda GL 1500 SE Gold Wing
How to fix a shifter indicator dial on a 1993 Buick Century?
Hey Mike, that just means the rod has come off between the shifter and the indicator needle. Gonna be hard to get ot but it can be done.
Dec 01, 2014 | 1993 Buick Century
My scond & fourth gear is grating
The shifter needs to be inspected. The shifter assembly is got misaligned, it has to be open and realign.
There are many other possibilities. But if it was working right up till now and suddenly this occurred then its shifter assembly alignment issue.
Also i suggest you to refer these gear shift issues, which are mostly noticed. These are direct links with appropriate solutions to the specific problems of gear ****.
GEAR SHIFT ISSUES
Gear indicator Shows "3" Instead Of "D"?
http://whoisbyme.blogspot.in/2012/07/gear-indicator-shows-3-instead-of-d.html
2006 Chrysler 300c: Shifter Stuck in Park?
http://technoanswers.blogspot.in/2012/06/2006-chrysler-300c-shifter-stuck-in.html
1998 Ford Expedition: Will not Shift Out of Park?
http://schematicsdiagram.blogspot.in/2012/06/1998-ford-expedition-will-not-shift-out.html
Car will not move when in gear?
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
Mercedes-Benz transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Mercedes Benz not engaging in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Chrysler PT Cruiser only goes in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
2007 Ford Expedition: How to shift car in neutral with Dead Battery
http://www.howtorepairguide.com/2012/11/2007-ford-expedition-how-to-shift-car.html
2002 Nissan sentra will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Nissan Sentra stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car won't downshift sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Buick Park Avenue: Transmission will Not shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
No First gear Starts In Second Gear
http://www.howtobyme.blogspot.com/2012/07/no-first-gear-starts-in-second-gear.html
Ford Taurus won't shift from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
2006 Ford F150: Will Not Shift out Of Park?
http://technoanswers.blogspot.in/2012/06/2006-ford-f150-will-not-shift-out-of.html
Car Transmission will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
1998 Chrysler Voyager: Transmission Problem?
http://howtobyme.blogspot.in/2012/06/1998-chrysler-voyager-transmission.html
Shift indicator directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Chevrolet silverado has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
2002 Chevrolet Avalanche Z71: Gear shift Issue?
http://whoisbyme.blogspot.in/2012/06/2002-chevrolet-avalanche-z71-gear-shift.html
Hard to shift gears on Manual transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Transmission-Hard To Down Shift
http://technoanswers.blogspot.in/2012/07/transmission-hard-to-down-shift.html
Automatic transmission shift lever hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
2000 Nissan maxima shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
2007 Hyundai Santa Fe: Will not Shift out of Park Mode?
http://schematicsdiagram.blogspot.in/2012/06/2007-hyundai-santa-fe-will-not-shift.html
These details will help.
Thanks.
Nov 27, 2012 | Cars & Trucks
What to do to my john deere lx 172 transmission to make it shift easier. the shifter is very hard to move.
Unfortunatly, you have a sealed transaxle, so their is not a place to lubricate it to make it smoother. You can spray wd-40 on the linkage but he binding usually happens inside the transmission.
Nov 04, 2010 | John Deere Garden
It is a 1993 john deere 6100. there are 3 forwards and 1 reverse on one gear stick- 1, 2 ,3, r and the other is a, b ,c ,d ,e. the 1, 2,3, r gear stick has becoe loose and u cannot select gears 2 and 3. I...
The shifters do run cables to the transmission but you likely only need to remove the panel from the right side that covers the shift rods and then you can tighten the 13mm nut that brings the linkage rods together,the nut is on the shift lever not the range lever,Let me know how you make out and if i am wrong also let me know and i will dig deeper.
Sep 28, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
176 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
