Question about Intertherm P3RA-060K Air Conditioner
Intertherm thermostat wiring problem
My husband tried to put in a new digital thermostat but it turned out to be not compatible now we are trying to put the old one on and it doesn't now seem to work i think it is wiring could some one help
  • Anonymous Apr 15, 2009
    I AM TRYING TO FIND A COMPATIBLE THERMOSTAT TO REPLACE A INTERTHERM A/C HEATER THERMOSTAT
    Novelist:
  • 88 Answers
Thanks for your Question,
A question or two for you, when your husband was hooking up the new stat, could he have inadvertently touched the low voltage wires together ? if so have you checked the circuit board at the furnace to see if the fuse is blown ? The fuse looks like a automotive fuse on the board, look carefully sometimes its a little hard to find it, take the fuse out and look at it, you can tell if its burned out, I would almost be certain that this is where your problem is at, replace the fuse with another 3amp fuse, make sure the power is off before doing this, and with the power off hook in your new t-stat, bet it will work for ya ! Or hook back up the old one, in any case you seem to have a power issue, hope this was of help, thanks again for your question,
mr.grzz
Posted on Jan 24, 2009
  • bobstegall Jan 08, 2013
    I appreciate your suggestion however my unit has a circuit board in the furnance and one in the compressor outside I could not find a fuse any other suggestions
How can I connect an Intertherm furnace with a heat pump to a new Honeywell thermostat?
Ensure that that thermostat is for a heat pump and has connections for the emergency heat strips.
Feb 02, 2016 | Heating & Cooling
Intertherm furnace M1BG wont fire
Make sure the gas valve is turned to the ON position after you had it in PILOT position. Also check the thermostat low voltage wiring @ furnace...jumper the Red & White wires to bypass the thermostat temporarily. Make sure there is 24 volts on you low voltage circuit.
Dec 16, 2013 | Intertherm P3RA-048K Air Conditioner
I have an Intertherm Thermostat. It was broken when a quilt rack fell from the wall. The wires were still attached, but we believe the thermostat was damaged, because the heat pump will not run at all,...
Yes they should be compatible, but you may have to jumper rc and rh on the new thermostat if you have not already. Also you may have blown the low voltage fuse of the Intetherm circuit board. It should be located in the electrical compartment of the unit. The fuse will be a blade type, 3 or 5 amp.
Jun 19, 2011 | Intertherm P3RA-048K Air Conditioner
Have an Intertherm thermostate in mobile home controlling gas hearing and elec ac. Blue wire to thermostat connects to the "A" terminal on the thermostat...Blue wire goes to a terminal on the...
If there are only two wires going to the thermostat? Then you will not be able to use a Digital Programable stat. Intertherm and Coleman furnaces do the switching different than regular furnaces. They use the switching from heat to AC at the furnace with the rocker switch. They use the thermostat to either break the connection or make the connection. They use a heating only thermostat.... Hope this helps
Jan 02, 2011 | Intertherm P3RA-048K Air Conditioner
I have an intertherm rpbmb030k combo a/c and heat. Had frion put in the unit over the summer and a new digital thermostat. Unit has worked great until we needed heat. Unit works great on aux. heat but...
Hi, if the unit had a leak in it, was the leak located and repaired? Did he check the pressures in the unit now? If it switches to the aux mode ( Heat Strips ) is normally caused when your primary unit, compressor and freon are low on charge. I would have that checked.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Dec 03, 2010 | Intertherm P3RA-060K Air Conditioner
Intertherm Heat Pump
Some of the old heat pumps made the reversing valve in the heating mode. On your new thermostat the orange wire will need to be on the B terminal. If it was color coded? I hope you made notes of how it was.
Jan 05, 2010 | Heating & Cooling
Wiring in a new thermostat
yes .common as in the netural side of the transformer x to cif not hooked up the stat will still work. and honeywell has good support for their products . Tom
Jun 20, 2009 | Intertherm P3RA-048K Air Conditioner
the wire that is on the x- terminal  on the old tstat will be c-terminal on the new tstat.
Oct 26, 2008 | Heating & Cooling
Lightning struck outside our house last night. Air does not work. Unit outside does but the thermostat smelled like the wires were melting. Husband got a new thermostat but we can't get the unit to come...
lightning is in KVolt range, the exterior unit is most likely damaged at the low voltage cables to the thermostat, melted out, should get a sparky in to trace the lowV lines, and check out the unit, lightning is not forgiving
Jun 22, 2008 | Intertherm Heating & Cooling
Intertherm P3RA-060K Air Conditioner Logo
583 people viewed this question
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
