Question about Dryers
Maytag stackable LSG1000 has a code L
Washer will not start or fill
zeusfaber
  • 247 Answers
SOURCE: Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Posted on Feb 06, 2007
  • 145 Answers
SOURCE: Maytag top laoder stacked washer LSG1000
If it only leaks in drain it has to be a hole in the drain hose or a plugged up house drain.
Posted on Apr 24, 2008
KevinWhite
  • 1902 Answers
SOURCE: I have a Maytag stackable
Hello & Welcome to FixYa
Please check this picture....part#11 is the water level switch that controls the water level through the valve. Please get back to me if you have any other questions.
Kevin
Posted on Apr 03, 2011
richroth
  • 9472 Answers
SOURCE: My 1988 washer/dryer combo Model
The "E9E" code means Low Voltage is seen at the Control Board. Make sure the RED wire on the Control Board that connects to the Heater Relay is not loose or burnt. This is the LINE ONE voltage supply to the Control Board and if it has a bad, loose or burnt connection it will cause E9E to display. If there are no loose of burnt wire connections then the control board will likely need to be removed and replaced.
Posted on Aug 16, 2011
  • 32 Answers
SOURCE: Clothes don't get warm when I use my maytag
I recommend that you will post your question under the correct category (washing machines) and maybe add more details to it, so it will be easier for Experts to understand the question and answer it.
You can also contact the site directly at: http://www.maytag.com/contact-us/
Posted on Oct 03, 2012
MAYTAG STACKABLE FILLS WITH WATER BUT DOES NOTHING ELSE
Rhonda, could be the safety interlock switch that is tripped when you open the top. The machine will fill with the top open, but will not run in wash or spin cycles. I would start there.
Nov 05, 2013 | Kenmore 24722 Top Load Washer
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Jun 06, 2012 | Furniture
I have a stackable Maytag. The water will not
I had a similar problem I just fixed. There is a fuse inside that keeps the water from filling if it's blown. Might try changing that first.
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Apr 13, 2009 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag neptune stackable washer dryer stopping
Maybe a water fill problem ,washer will stop if no or not enough water enters the tub in a given time
Dec 04, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Dec 15, 2007 | Maytag LSE7806A Top Load Stacked...
Feb 05, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Dryers Logo
29 people viewed this question
Top Dryers Experts
