Question about RCA RTDVD1 System
I have a new 52" Samsung HD TV with a new Sony Blue Ray player and a Shaw PVR cable box all connected with HDMI cabes. I also have a older digital RCA model RTDVD1 sound system with no HDMI connection and no component connection. It does however have a digital optical connection and a coaix connection as well as the standard RCA in/out connections. We had the sound system working well on our old TV and VCR players but I am not sure how to hook it up with these new components. How is the best way to set this sound system so that I get the Dolby Surround Sound when watching movies on TV or on the Blue Ray DVD?
  • daranger_vic Mar 01, 2009
    Coincidently we just receive the same instructions from the RCA people after waiting a good deal of time. It works fine now. I do have one more task before everything is just right. We have a Shaw digital box ( called a PVR ) serving us. We are supposed to able to put the codes for all of our components on this so the one remote controls everything. We have not been able to find a code fro the RTDVD1 or the Sony Blue Ray which is a model BDP-S350. If you happen know either of these codes or how one could get them I would be grateful.
    Thanks for the help.
  • Anonymous Mar 24, 2014
    NEED TO HOOK UP AT&T U-VERSE TO RCA BLUE RAY SYSTEM
I have the same situation....what I have done is connected my Blue ray to the TV via the HDMI connection and the audio to the RTDVD1 via an Optical cable. I find this is the best connection and sound reproduction so far. The input of the RTDVD is the SAT/Optical input and then switch the source to SAT/OPT. You will have to make adjustments in the BlueRay player's audio setup to enable the 5.1 DB digital sound etc.
Posted on Feb 28, 2009
  • hulk61 Mar 03, 2009
    It appears that most of the Shaw converters have the ability to "learn" from the original remote. here is the link to the "Remotes" page I found and although I am not sure if any of the codes are available for either device, i suspect that if you follow the instructions on "Learning" and teaching the remote...you will get what you are looking for. There my be a limit on the number of additional devices the remote can handle.
    Good Luck
I need help hooking up my system from cable box to old toshiba 52 inch tv does not have hdmi on tv red, green , blue wires i also bought today a sony blue ray player speakers are not working ...
Please indicate the brand and model of your receiver, BD player and your speakers. Basically, you just need to connect the cable box and blue ray player to the receiver. The 5.1 speakers should be connected to the blue ray player, then another set of cables from your BD player to your TV. When you want to use the speakers while watching TV, you need to turn on the blue ray player too.
Sep 15, 2011 | Audio Players & Recorders
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
Only 1 hdmi outlet on TV . I have a high def cable box and a sony blue ray dvd player. How do I connect 2 hdmi cables fron the components to the tv?
Don't used the Blu Ray player on the tv HDMI out put hub.Used the connections for of the Blu Ray player connections by a S-Video cable for the video and the RCA component cable R,W for the connections for the audio out.The high Def.cable box will not work for high Def. this way,but the Blu Ray player will.
May 30, 2011 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
Just connected our directv hd receiver to the tv via component cables, because we just bought a blue ray player and the only output for that is HDMI and since there is only 1 DVI input we had to change the...
You may be able the settings of your directTV box to stop frustrating you. If you help me identify the model you are using, I can research the proper menu choices you will need to choose to select the correct features. There are many different directTV set-top boxes available.
My own home theater setup did the same thing, and my solution was to use component cables from the PVR instead of HDMI cables. It is too bad your blu-ray doesn't allow for this configuration.
My work-around until I realized that using different interconnects fixed the problem, was to turn the TV off and then on again whenever switching from HD to non-HD sources. This fixed my problem, maybe it will fix yours.
I hope that helps.
Mar 28, 2010 | Samsung HLN617W 61" Rear Projection HDTV
I need help setting up the cables on my home theater system. I have: 3 HDMI cables 1 Coaxial cable Yamaha 6250 receiver Samsung 7000 series LCD tv Samsung Blu Ray player Shaw Digital cable PVR box (similar...
2 hdmi inputs on samsung tv? different ways you can do it.if it was me i would run samsung blue ray to tv hdmi in,shaw box [if supported hdmi]to tv in, if not coax.
and i would sound out on tv to yamaha?
Dec 20, 2009 | Yamaha HTR-6130 Receiver
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
Jun 02, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Hookup wrong? I can't get the menu to come up for the VR375
New HD tv. Have digital cable box connected to tv., cable box connected to DVD recorder, but can't get setup menu to come up on tv screen. I had a similar problem. I have a HD tv connected to a digital cable box. I hooked up the DVD recorder with the wires it came with, but it would not play or give me the menu. However it was correctly hooked up. So the next day I connected a HDMI wire from the DVD recorder to the tv and everything works now.
May 24, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
Nov 21, 2008 | Samsung HT-AS720ST Theater System
RCA RTDVD1 System Logo
389 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
