Question about Pyle PHPNC45 - High-Fidelity Noise-Canceling Headphones With Carryin
How do I install AAA batteries in Pyle Home PHPNC45 Headphones?
The installation guide does not show where the batteries go, and I don't see any compartment on the headphones that lead to the batteries. Any idea where the AAA batteries go on these headphones?
    New Friend:
  • 109 Answers
Turn the left cup counter-clockwise - tah dah!
Posted on Jan 16, 2013
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pyle Master
  • 1,001 Answers
Bluetooth Headphones V4.1 Wireless In-Ear Noise Cancelling Sweatproof Headset for iphone6/6s iPhone 7/Samsung Galaxy S7/S7 edge and Android Amazon com Charm sonic Bluetooth Headphones V4 1 Wireless In Ear Noise...
Posted on Dec 14, 2016
How do I change batteries? I cannot find their location.
The right earphone holds the batteries. Grab the cushion and TURN it slightly and it will release from the headset. Don't pull it off without turning first.
The two AAA batteries are exposed. Just replace and replace cushion with slight turn.
Sep 10, 2011 | Koss Quiet Zone QZ99 Consumer Headphones
TI 82 Does it need the disk battery and 4 AAA batteries to work?
No. The calculator runs on the four AAA batteries. The lithium battery is solely to retain the contents of the memory while you change the AAA batteries. If you don't care about retaining the memory, you don't need the lithium battery. You do, however, need the AAA batteries to use the calculator.
Jul 31, 2011 | Texas Instruments TI-82 Calculator
Battery on a 2005 Mustang went dead. Had a Jump to get the car started. Drove & speedometer & odometer worked fine. However, I had Triple AAA install a new battery & now they don't work. ...
Did AAA clean the battery cable connections when they installed your battery? Did you check the fuse for the insrument panel?
It could be just bad timing or a coincidense but I am more likely to think things are connected. If your gauges worked after jump starting your car, but not after AAA changed the battery, something changed or was left disconnected.
Jul 03, 2011 | 2005 Ford Mustang
RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Mar 27, 2009 | RCA WHP141 Consumer Headphones
Batteries
You need to remove the rubber on each side of the headset - and you will need to replace one "AAA" battery on each side - hope this helps
Aug 25, 2008 | Sharper Image (CT411) Consumer Headphones
Maxell NC-II noise reduction headphones.
Look closely at the battery icons under the batteries.The installation of the batteries in these headphones is different than most electronic devices the batteries sit side by side in the same direction both + ends are on top and both - ends are on the bottom
Jan 06, 2008 | Maxell HP/NC-III Consumer Headphones
My ti89 titanium doesn't turn on
I had the same problem. I changed the batteries and it didn't work. I took out the batteries for about 30 minutes, and then put them back in, and it turned on.
Aug 21, 2007 | Texas Instruments TI-89 Calculator
Pyle PHPNC45 - High-Fidelity Noise-Canceling Headphones With Carryin Logo
276 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
