Question about HP Pavilion dv1000 Notebook
Still not working AFTER i pressed fn key nd f4
What am i doing wrong, my ex husbnd bought it for me and it worked FINE up intil i unpluged the vga cord from my laptop, now i cant get it to work , last night, i hooked it up, but the only thing that would show up on my tv was my desktop background
  • 40 Answers
You likely have the pc in dual screen mode, meaning that your seeing a second screen you can access by going off the right side of your screen. Usualy you can press fn and f4 a second time to get it into cloned mode.
Posted on Jan 24, 2009
Hi there I have a Toshiba CT - 9969 and want to connect my laptop using VGA? What must I do and where do I switch to VGA on the remote? Thank you
connect to TV using VGA port and select device or mode to PC in tv menu. or using remote
press laptop fn +F4
or see display change button in FN buttons .press with or without FN button . if you use HDMI pls cinnect with HDMI cable and in TV pls select HDMI mode in video mode
There is a row of Function keys at the top of the keyboard on every Toshiba notebook. These give you quick access to some useful functions. To activate them, just press the FN button on the keyboard together with the function key to activate the following commands.
press FN+F4
Nov 16, 2016 | Toshiba Computers & Internet
Connect laptop logik tv
If your TV has an VGA input. Connect a VGA lead from your laptop to the TV. Press and hold on the laptop, the Fn key whilst pressing F4 to allow an external display to work. Set the TV to VGA in and there you are.
Oct 25, 2013 | Computers & Internet
Compaq laptop prasario cq60 won't turn on yes it's plugged in yes outlet works yes I checked all electrical connections and outlets
have you tried to remove the battery and wait a couple of minutes then re-insert. make sure your battery charger is working, light flashes also indicates low power.
Mar 01, 2013 | Computers & Internet
I need to connect my laptop to the LCD TV. Please tell me after connecting VGA with audio cable, what I should do on laptop to get the desktop details on TV Monitor? N.K.Makam
Hold the "fn" key and press the corresponding function key at the top to change the display. There should be a picture on the key that implies this function. For example, my compaq laptop uses the F4 key for this so i would press and hold "fn" then press and release F4.
Mar 05, 2011 | Proscan 32LB30QD 32 in. LCD TV
I have a accer 5515 I bought a vga to s,vid cord to hook up my tv as a mon and it does not work
change the input on the tv to svideo, then press the FN key hold it and press the monitor key either F10 or F4 it should have 2 monitors or a picture of open laptop and a monitor...hope this helps
Oct 07, 2010 | Computers & Internet
I have a hp pavillion dv2315nr laptop with a black screen. In the past, I was always able to resolve the issue by pressing fn/f4 at start up which worked but takes a long time to kick in. Now however...
when you power up the press F8 key then enter in enable vga mode then go to control panel ->display ->settings ->change screen resolution to 1024*768 then apply and ok then restart .
Thanks for using fixya.
Please rate solution if it helps.
Jul 25, 2009 | Computers & Internet
Vga output on travelmate 2480 dont work
After you plug it into the projector, you need to tell the computer to send the output to the VGA. This is done by pressing a combination of the Fn key and an Fx key, usually the F4 key; it will have a picture of a screen on it in blue. Press it once will direct all output to the VGA port, press it twice will show the picture on the laptop and the VGA port, and pressing it again shows on the laptop only.
Thanks and please take a moment to rate as fixya.
Mar 04, 2009 | Acer TravelMate 2480 Notebook
My laptop will turn on but with no screen
Try unplugging the battery and starting up with power only. Any Luck? If that works the battery can be put back in and try charging again. Another thing to try is to hold down the fn key and press f4 key once. If that doesn't work try again fn and f4. If all else fails try unplug and take out battery. Then take out the memory and put it back in and try to turn the laptop back on.
Aug 01, 2008 | Computers & Internet
No Signal
On your notebook press fn key and look for F# key that has a monitor or lcd picture on it( ex: F5 or F4). and press on it as well while holding down fn on keyboard
Apr 08, 2008 | Optoma EzPro 739 Multimedia Projector
HP Pavilion dv1000 Notebook Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
