Question about Friedrich D50 Dehumidifier
Dehumidifier turns off
The dehumidifier turns off after about 2 minutes. It feels hot in the back. After it cools off it will go on again, but only stay on for a short time.
Take out the fan motor and test it with direct power supply if it did not work more than 2 min,change the fan motor.
Posted on Jul 17, 2007
I have a Kenmore Dehumidifer, model number 580.53650200 and it's been sitting around in the garage for a while. Before I plugged it in I ran the air compressor over it fairly well, blowing out the...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 05, 2011 | Kenmore 5365 Dehumidifier
My dehumidifier wont cool. it used to but now only hot air comes out. i need it to cool down my area desperately bad! please send your advice back ASAP! thank you!
heatman101
May 30, 2011 | Fedders A7DH45B2A Dehumidifier
My dehumidifier will turn on but after a few minutes it shuts off on it's own.
heatman101
Apr 26, 2011 | Whirlpool AD70USS Dehumidifier
Water is not going into the tank, but it does run and panel lights up. Filter is clean. It worked for the past 2 months.
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again.
Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running.
If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils.
If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck
Aug 16, 2010 | Haier HD656E Dehumidifier
My dehumidifier has not, does not collect any water. HELP !
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Take care.
Aug 10, 2010 | Amcor AHD45 Dehumidifier
Kenmore 54501 turns on but nothing happens in my damp basement
A dehumidifier heats and cools the air to remove moisture. Most are like a small air cond. The Condenser coil is right in front of the evap.coil. So the compressor may not be coming on. Does it sound the same as before? It may be low on freon. You will have to get in there and listen and feel the lines at or near the compressor, Learn how to get down in there to the compressor. Run it for 10 Mins. unplug it, open it up, and feel the lines. Some lines should be or can be HOT to the touch. Some should be cool. The smaller the line the hotter it should be, and the compressor should be warm (to hot) to the touch. repost for more info.
Jul 08, 2009 | Kenmore 54501 Dehumidifier
Discharge air is HOT!! - not cool
A Dehumidifier will not cool your basement, just make it seem cooler at the same temp. Your dehumidifier may be undersized even for that purpose.
You need an AC outlet of a central AC in your basement, or a window unit if there are windows.
Warm air at discharge is normal.
Sep 04, 2017 | LG LD40E Dehumidifier
The dehumidifier is blow cold air
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Apr 07, 2009 | Kenmore 54701 Dehumidifier
Runs, but overheated, tripped outlet causing freezer full of rotten food
There was a recall on these - it depends on the age.  I bought mine in 2003 or 2004, and they sent a repairman out to replace a circuit board.  Call Maytag to see if yours was in the recall.
Aug 09, 2008 | Maytag M7DH65B2A Dehumidifier
Dehumidifier switches on and off continuously
Patty - Is it possible that the dehumidifier is cycling... meaning there is not enough moisture in the air for it to run constantly.
Aug 16, 2007 | Kenmore 54501 Dehumidifier
Friedrich D50 Dehumidifier Logo
192 people viewed this question
Top Friedrich Dehumidifiers Experts
Bill Long
Gil Shultz
Marvin
Marvin
Are you a Friedrich Dehumidifier Expert? Answer questions, earn points and help others
