Ice maker does not make ice. water pools in the mechanism-not the bin. Refrig works fine.
There's no ice
If your ice maker has stopped producing ice completely, check these, in this order:
Small or too few ice cubes
If the ice maker is producing ice poorly--making small cubes or too few cubes--you probably have a clogged water line, a defective water-inlet valve, or a defective ice maker mold thermostat that isn't cycling properly. Check these:
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
Specks in the cubes
If you find black or gray specks in your ice cubes, have a look at the ice cube tray. If the protective coating is peeling away, the most economical solution is to completely replace the ice maker.
Check if there is a leak on the water lines. Check if water lines are freezing.
If no water is coming to the icemaker, you need to replace the icemaker assembly, or the pump.
see also
What
is wrong with your Ice Maker?
Ice Maker
Hi
Kindly check it could be because of following reasons :
Temperature must be 5 degrees (Fahrenheit) or colder to work properly.
The ice maker will produce between 2.5 to 4.0 pounds of ice a day depending on your model. Side-by-side models come with a large ice bucket and it may take up to three days to fill this container.
Open valve completely.
Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
If equipped with a water filter, replace filter canister or cartridge.
Please feel free to contact for further assistance
Thanks
Rylee
The refrigerator works fine other thatn the ice maker does not make ice. It does not appear to have power to it and water pools in the mechanism. (not the bin) Is it clogged up?? What other advice can you offer? It is slightly more than 3 years old and was working fine to this point.
Thank you
Barry
