Question about Olevia LT42HVi 42 in. LCD Television
Audio quit working when I moved the tv
I've been thru all the menus, and cannot get the audio to come on. Any help please?
  • Anonymous Jan 26, 2009
    THE CONTROL WILL NOT RESPOND TO CERTAIN FUNCTIONS
    Sergeant:
    Champion:
  • 267 Answers
WHAT FUNCTIONS ARE NOT WORKING. THE REMOTE OR ON THE SET ITSELF. CHECK AND MAKE SURE THAT NONE OF THE BUTTONS ON THE SET ITSELF ARE STUCK IN. THIS WILL LOCK UP THE MICRO AND NOT ALLOW OTHER FUNCTIONS TO OPERATE.
Posted on Feb 03, 2009
How do you get audio to play through a receiver? We have the TV running to input on receiver and no sound?!?!
You have to go thru the menus on the TV and tell it you want TV speakers off, and output to surround at fixed volume. Then plug audio out wires (RCA jacks or optical digital wire) from audio outs on TV to AUX or Video or something like that into the receiver.
Jan 21, 2015 | Insignia IS-LCDTV32 32 in. Television
Audio somehow stopped working on my Sansui TV . I've tried resetting the tv, using both the cable and regular remote and I've went to the audio settings and tried changing things . I'm not sure what's
had a jensen that did the same so i bought a surround sound and hooked up through sat box hope this helps you save some money and get better sound
Jan 22, 2013 | Televison & Video
Apple tv to optical audio on avr 1601
You need to assign the optical input to the video input you are using. It's under the 'Input Setup' menu.
Or use HDMI, it will output the audio thru the HDMI connection. Once again assign the input under the Input Setup menu (press the Menu button on remote to access setup menus)
Nov 19, 2011 | Denon AVR-1601 Receiver
Hi I can't figure out how to get my N64 to work on my samsung flatscreen. My friend showed how to do it a while back but now i've forgotten. I've been told I need a scart cable but I...
Whoever told you you need a scart cable is wrong, The N64 is an old console therefore requires you to plug it in via a standard ariel port. You then should turn you N64 on and search for new channels using your TV menus to either automatically search for them or you can tune your tv manually. either way you will probably need to fine tune afterwards. If you need more help please e-mail me at garleet@hotmail.co.uk
Aug 11, 2011 | Nintendo Video Game Consoles & Games
I have a new Denon AVR 1911 receiver all hooked up to my input devices and output thru a single HDMI cable to my Samsung LCD tv.... problem with getting audio from my DVD player: my DVD player is older...
Not likely that all those things are faulty.
The TV and DVD player make and model would be helpful to know. I would recommend running its BEST digital audio to the receiver and its stereo analog audio to the TV just in case you want to watch and hear the DVD in a lo-fi setting without the Denon. I generally advocate for connecting anything high-end (audio or video) ONLY to equipment that can use it or enhance it. Otherwise you may just be wasting expensive cable and adding unnecessary hops and connections that can fail.
Why do you want the audio to go from the DVD to the TV through the Denon? Are there no speakers on the Denon? Modern TV's have lots of inputs for the flexibility I recommend but rarely have decent audio or speakers.
May 06, 2011 | Audio Players & Recorders
Hooking up Kenwood AR-304 to LG TV
You need to connect the TV "Monitor Output" which will be standard audio (RCA) red and white. Then you need to make sure you go into the TV's main menu and go thru "Audio". You may need to turn off the TV's internal speakers to get output via the RCA monitor out. If by chance it has a setting for "Fixed or Variable" for the output, select "Fixed" and control the volume thru the receivers volume control. If you still need further help, don't hesistate to ask! I can walk you thru it. Hope this helps
Aug 18, 2009 | Audio Players & Recorders
The onboard TV guide works perfectly, but inputs are green
Problem solved. Not sure how. The TV has just been moved in, and after hours of rest and being reset a few times the problem went away.
May 19, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Lost everything visual, just audio.
Just enter the appropriate Menu-Setting (without a picture you´ve to do this "blind") - Press "Setup" - 1x key down (=video menu) - 1x key right (switch to sub menus) - 2x key down(=video format) - press select - key up (=interlaced) and press select again - finished!
May 05, 2009 | Televison & Video
I`ve set up my philips digital terrestrial receiver DTR220 and i`ve scanned for all channels, but i can`t pick up any because my aerial is not picking up any signal. I`ve tried different, stronger aerials...
I actually moved my tele to the other side of the room to see if it would work in a different spot and it took me ages to get some signal by moving my aerial around. The signal still wasn`t strong and i didn`t have alot of the channels and then i turned it on a few weeks after and it was working perfectly. Don`t ask me why! :s
Jul 21, 2008 | Audio Players & Recorders
No Sound
First of all try getting a Symphonic remote - http://www.miracleremote.com/ not that expensive. Then you can access all areas of the TV, including all sub menus and see how the audio is set-up.. Could be you have it in SAP mode, (Second Audio Programming), in which case you will hear nothing...
Bill
Nov 19, 2007 | Symphonic SC519DD 19 in. TV/DVD Combo
Olevia LT42HVi 42 in. LCD Television Logo
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
