Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
LiftMaster 1/3 HP- Door Opens but won't close
There is power to my garage door and opens freely with no problems. The problem has started recently that the light flashes and the door won't close. At first I thought it was due to the freezing weather. Then I noticed one of the sensor lights was not on. I replaced the sensor with a brand new one...still no light. Then I thought it might be the wire connecting the sensor to the main board so I replaced it with brand new wire. Still no luck. When I press the green button on the panel, the light turns on. (when I don't press it, it flashes every now and then). Any idea what the problem could be? Do I need to replace the back panel/logic board or the whole system?
    Problem Solver:
  • 11 Answers
MAKE SURE THEY BOTH SEE EACH OTHER, THE EYES HAVE TO BE LINED UP TO SEE EACH OTHER. SO TAKE A STRING AND GO FROM ONE EYE TO THE OTHER AND TRY TO LINE THEM UP THAT WAY THE EYE SHOLD GO ON TO GREEN OR RED. GOOD LUCK
Posted on Jan 25, 2009
4 Suggested Answers
  • 548 Answers
SOURCE: LiftMaster 1/3 HP- Garage Door Opens but will not close
I have had a similar problem related to my doors when they get cold-soaked. The tracks actually warp a little throwing the sensors off and causing the door to bind. The door will go down a bit then come back up. I overcame this be resetting the force that the motor puts out to lower the door and it works fine now. If you can wait for things to warm up, use the manual release lever and lower the door by hand and then reset the lever so the door can't be opened manually.
Posted on Jan 24, 2009
SOURCE: Chamberlain Liftmaster Professional 1/2 HP
Okay...upon further inspection, my left spring has broken in two. Going to call around for some quotes to replace the spring. Thanks for the suggestions.
Posted on Jul 25, 2008
  • 3197 Answers
SOURCE: garage door opens a few inches and stops
On the rear of the motor unit near where all those white wires go you will find the 'up force'. Increase this 1/4 turn and try.
Posted on Dec 07, 2009
Garage door will close, stays shut for a few seconds and then opens on its own.
The opener is closing too far. On the side of the opener, you should see 2 white knobs, recessed into the side. Using a flat blade screw driver, adjust the close knob (closest to the door side of the opener), anti-clockwise until the door will close gently on the floor.
Aug 24, 2013 | liftmaster Garage Door 1/2 Hp
My door opener is a Searcraftmans 1/2 hp. The door opens about 2 feet and stops. Press the button and it closes. Door moves freely when disengaged. Any suggestions
You most likely have a stripped drive gear. Remove the cover from the motor unit and it will be obvious if this is the case. It is a white nylon gear just in front of the motor.
Jan 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/2 HP Garage Door opener won't open or close. Has been working fine until I pulled out this morning. The door will move freely if I disengage from opener. Went up ladder to see chain not...
The shaft on these garage door motors are not direct drive systems. You'll have to open up the box to see what the actual problem is. I have had stuff like this happen where a gear just slipped out of place.
http://www.aaadooropeners.com/?gclid=CLH3wt628p8CFVZS2goduwSLYQ
Here is a link for a parts supplier. I don't know your model but it looks like most of the Liftmaster worm screw gears and drive gears are plastic so it's possible that one of them has cracked.
Feb 14, 2010 | liftmaster Chamberlain Garage Door Opener...
My Liftmaster 1/2 H.P. opens but cannot be closed (without depressing the button on the wall until the garage door comes down all the way. Any help will be much appreciated
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Jan 25, 2010 | liftmaster Chamberlain Garage Door Opener...
My liftmaster 2265 1/2 hp remote does not close
If the door starts to close and the main light flashes 10 times and the door reverses to the open position it is a problem with the door sensors. Make sure they are pointed at one another and they each have a small light that must be on and not flickering.
If it starts to close but reverses and the main light does not flash 10 times it is possibly the RPM sensor which is a small printed circuit board just in front of the motor.
Nov 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door barely opens/ opens with physical lifting assistance
It sounds like you have a broken door spring or the drive gear in the opener is stripped. You will have to take the cover off the opener and you will find the white nylon gear just in front of the motor.
Sep 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman garage door opener (1/2 hp) won't close proper
Check your door sensors. They have probably been bumped. Tweak them until they are pointed at one another and the small light on each one is lit and not blinking.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,647 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
