My internet keeps disconnecting every night and I haft to reset the modem and router to get it to work for another day how do I fix this my router model is f9k1102v1
  • 7,627 Answers
If you have Checked ALL inside cables, reseated ALL cables and rebooted the ISP modem, wait for selftest, plug in router wait for selftest, rebooted the computer. Contact your ISP to analyze the signal, have a ISP tech come out a verify the signal, it may be outside equipment.
Posted on Jan 16, 2013
bc_axys
  • 49 Answers
SOURCE: My router keeps disconnecting the internet
a blinking power light suggest that the device is already broken. Go to the command prompt and ping the roouter. If you can still ping it then i suggest to upgrade the firmware of your router.
Posted on Oct 27, 2007
osborne382
  • 306 Answers
SOURCE: no internet light on modem afer router is used
go to http://support.dlink.com/chooseCountry.asp
for proper set up of the router...most likely it has conflicting IP Address's. If they wont help you can contact your ISP for support or get a differ router.
Posted on Nov 10, 2007
dante777
  • 623 Answers
SOURCE: Help please! TP-Link Wireless Router TL-WR641G stopped working
It looks like all your devices by themselves are working fine.
Good start.
If you took the router out of your office I assume that the settings from the office and your home are different, which causes the setup not to work properly.
First of all you should find out which hardware version of the router you have and download the manual from here, so you have the information at hand when you're not online.
Then you want to rest the router to factory settings, so you start clean. In order to do so, use the Factory Default Reset button: First, turn off the router's power. Second, press and hold the default reset button then turn on the router's power, until the SYS LED lights up (about 3 seconds). Last, release the reset button and wait for the router to reboot.
Follow the instructions in the manual form page 8 on onwards with a special view on setting up PPPoE. Have your information form your DSL provider handy (Account name and password).
The default webpage for the router interface is http://192.168.1.1
Username and password are both "admin".
Do not enable any wireless security until everything is working fine.
Make sure later to change the password to something else, so no one can "take over" your router.
If this solution did not help, please don't rate it as "Thanks for trying" or so, but leave a comment instead and I will check back and we can work form there.
Posted on Jan 27, 2009
  • 67 Answers
SOURCE: Belkin 54G won't connect to the internet
Are you sure your modem is giving a WAN IP from your ISP? Try power-cycling your modem with your router unplugged then bring up your router next, if you havent tried that already... After that try connecting your modem directly to a PC and set your NIC card to DHCP and see if you get an IP address thats routable to the internet (i.e not a private IP)
Posted on Mar 28, 2009
SOURCE: WND3300
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Posted on Oct 05, 2009
Netgear N600 keeps disconnecting from internet
If your router isn't running firmware v 1.0.0.46 then download that from Netgear's website and upgrade the router's firmware.
Jan 28, 2013 | NetGear WNDR3400 N600 Wireless Dual Band...
Orange globe keeps appearing on my dlink dir655 and it disconnects internet
First try replacing your LAN cable between you internet modem and the router. A bad cable the is intermittent may cause this issue. Try rebooting the modem. Also if possible try a direct connection to your internet modem by LAN cable or wireless and see if your connection stays up. You could have a bad internet modem or other connection issue from your provider
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset.
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Dec 12, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Everything works great for a while then all of a sudden i cannot get access to the internet. I reset the router and my modem and everything works OK. This would not be a problem except that it happens a...
The first thing you should do is try to isolate the problem to either your router or your modem. The next time you lose connectivity, only reset one of the devices and see which one is causing the disconnect. Then, once you've determined where the problem is, go online to the device manufacturer's website and see if you can download updated firmware for the device, which may fix stability issues that the version you have doesn't address.
Jan 01, 2011 | Linksys Wireless-G WRT54G Router
I have an ADSL D-Link modem (DSL-300G)that works fine. I hooked a D Link wired router, EBR-2310 and can't get to the internet. It use to work until one day recently the kid moved wires arround because no...
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Oct 07, 2009 | D-Link 4-Port Ethernet Broadband Router...
Cencor propblem
I don't know the answer to this question, but all I do is disconnect my battery everytime I have issue with my Jimmy and it seems to fix the problem. I don't know if this is going to help you or not but give it shot. disconnect your battery for 5 minutes and see what it will do.
Mar 18, 2009 | 1999 GMC Jimmy
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
My D-link DI-524 Wireless router not working.
g´day m8,
Your D-Link AirPlus G DI-524 Wireless Router needs a hard reset.
Log in to your router, go to -> administration -> factory default -> Restore Factory Defaults: =  "yes"
Then save settings.
You have now reset the router.
First thing you do is set your wireless setup in your computer to the same, i.e. no security.
Test if there is connection, if, the start with the setup from the top, beginning with admin password.
/Teis
Dec 19, 2008 | D-Link DI-524 4 Port Wireless-G Router -...
Router gets disconnected
If you know how to open the setup page of the router, look for MTU. Normally it is set to Auto with default size of 1500. Now set it to manual and change the value to 1463 and save the changes. Power cycle the router by unplugging the power for 30 seconds then plug it back in. Observe your connection if it keeps on dropping.
Another is you need to isolate the problem if its the router or the modem. Try to connect your PC directly to your modem and observe if it does the same thing. If it does the same problem, call your Internet Provider to fix the modem.
If the problem still persist on the router after changing the MTU, try to update the Firmware of the router and hard reset it by pressing the reset button for 15 seconds then power cycle it.
Jul 24, 2008 | U.S. Robotics (USR8200USR8800KIT)
Intermitent DSL/Internet Connnectivity 2701 Router
Hii,
* If you can connect after disconnecting power and reconnecting, it means there is formation of static charge on modem
* Check whether there is any cordless phone or any other satellite devices next to the modem. If so, move the modem 10 feet away.
* If your modem is placed on carpet, please place it on wooden desk
For guest:
Do you see the power is also interrupted while loosing connection? If so try plugging the modem into different socket. Dont waste money for simple problems.
If this doesnt work, please dont rate me down, if it works, please rate me as fixya!!! lol...
Have a nice day!!!
Jun 04, 2008 | 2wire (1000-000057-000) Modem
NEW BELKIN WI FI CABLE ROUTER NOT WORKING AFTER 4 DAYS OF USAGE
I would try a hard reset of the router to reinstall the original settings. Then reconfigure and test again. If ther is no change then as you probably suspect the router has failed. Let us know if you have any other questions and please don't forget to rate this posting.
Feb 06, 2007 | Belkin Wireless Cable/DSL Gateway Router
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
