Question about Motorsports
91astro van can't start I have to prime with carb spray
    Sergeant:
    Champion:
  • 495 Answers
Carb or FI?
Posted on Nov 20, 2013
Where is vento gt5 choke located
If the fuel tank is mounted below the carb, a fuel pump will be utilized since gravity won't work. You may be able to take a syringe & spray a little gas in the carb & see if it will run long enough to get it all primed up. Be careful with the flammables.
May 19, 2014 | Vento HipHop Motorcycles
My 82 XJ650 won't start after cleaning the carbs.
try taking the carb off and let it set in sea foam for a night
Jul 19, 2013 | Motorcycles
Toro Power Clear 418 ZE Snow Blower won't stay started
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
Dec 06, 2012 | Toro Garden
The firwt time this year I tried to start my Briggs Troybilt Pressure Washer, it will not pump gas. I spray gasoline in to the carb and it starts for a moment. I spray gas in the cylinder, and it fires for...
If you left gas in it over the winter, particularly with the ethanol blends, the carb's probably all gunked up. You'll likely have to pull the carb, clean it and rebuild it.
Jul 06, 2011 | Briggs & Stratton Briggs Stratton 2550...
I have a 1989 RAM w100 with a stock 318. I'm
If you can spray carb cleaner in the carb then you have either a fuel supply problem or fuel delivery problem. Check your fuel pressure and make sure it is in spec. Then check the spray in the carb spray.
May 27, 2011 | 1989 Dodge W150
Want start changed plug an fuel filter it starts if i prime the carb.
Will it run if you keep priming it??? More than likly the carb is durty. Take the air filer off and have carb. cleaner handy. Start it up and spray carb. cleaner intermitenly in the carb till it runs properly. Ifthat does not correct the problem the carb. needs to be cleaned . Not to be done other than some one who knows how !!!
Apr 13, 2011 | Troy Garden
Toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running unless primer button continuouly pushed. Gas seems to not be independently flowing, requires manual priming to stay running. As soon as primer gas used, will stop running.
The tube in the bottom of the carb. is probably clogged. Remove the carb, and bowl and try spraying WD-40 through the tube, it should spray into the venturi if it doesn't try using a tip cleaner to unclog the tube.
Apr 12, 2009 | Garden
Motorsports Logo
54 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
