My router light keeps turning orange my model number is f9k1102v1 and this happened the past two nights so I unplugged thhe modem for 10 seconds and did the same for the router and then it'd work again but only for the next day I can't figure out. What wrong with it
  • 7,627 Answers
Reseat and check ALL cables. Reboot the ISP modem and router. Contact the ISP to analyze the signal, have a ISP tech come out to verify the signal, it may be outside equipment.
Posted on Jan 16, 2013
  • 30 Answers
SOURCE: On and off line every 20 flashes.
Have you attempted to connect the internet after the router stops flashing? Do the lights start flashing again? If you do, then it would be considered normal.
If they don't and you do not have an internet connection, try the next step.
Next, plug your computer straight into the modem - Do you have an internet connection now? If you do, your router may require configuration.
Posted on Nov 10, 2007
  • 8 Answers
SOURCE: My Dlink Model WBR 2310 has to be reset all the
when you are connected, go into cmd, type ipconfig /all and note down the ip addresses. in xp, click the wifi icon on your taskbar, then properties and scroll down to tcp/ipv4. click properties, highlight use the following ip address and type in what you found in cmd. for dns, highlight the use the following dns settings and type what you found in cmd. for vista, click the network icon, open network and sharing center and then view status (do the same as xp from then on). hope this helps
Posted on Dec 26, 2009
arvinds88
  • 108 Answers
SOURCE: Losing connectivity to internet..red light goes on on router
Keep the reset button pressed for 3 minutes.
If you have the CD, try to re-install the same router
If you don't, contact the toll-free # 1-800-2235546
Myself or any other technical support executive will assist you further
Posted on Jan 22, 2010
  • 71 Answers
SOURCE: ROUTER LIGHT KEEPS TURNING ORANGE. WHY?
Try upgrading the firmware of the router, helps a lot.
Posted on Jun 10, 2010
drunknmonkey
  • 136 Answers
SOURCE: I have an apple router.
It's a common problem with wireless routers, especially with certain ISP's, there's several theories about why this happens including cheap parts and software on the routers but it can be much worse if it's over a cable connection. Possibly because the MTU is higher on cable networks than wireless ones. This issue doesn't seem to affect wired connections to the routers as much. ie you may still get a working wired connection even if the wireless isn't working.
Certain makes are known to behave this way, with certain ISP's. eg in england there's a cable company called virgin media, belkin routers really don't seem to like them, but netgear seem to work much better, which is probably why virgin recommend netgear and will only supply netgear routers themselves.
Try changing the channel id if it's wireless, as there may be a lot of interference around you and this may or may not have a bearing on this issue. If that doesn't help then ask your isp what make they recommend as they should have an idea of what will work best, at least the tech support dept should.
In my opinion the best makes of routers are netgear and linksys. I also like belkin although they aren't as good as they used to be, and as mentioned can suffer from this problem quite badly in some cases. As you are with a cable
You will never completely eradicate this problem, all wireless routers will need resetting now and again, but it should be weeks or preferably months between each time. Cisco routers may be more reliable but they're business routers and are very expensive, and probably a bit more complicated to setup.
ps. I used to work for virgin media as tech support.
Posted on Jan 18, 2011
Adsl link does not become stable, it shows blinking orange light
Reading the manual Troubleshooting section it looks like your adsl connection is not working. Try unplugging your internet provider's equipment power supply and waiting 10 to 15 seconds. Then plug it back in.If this doesn't work contact your ISP.
Mar 06, 2014 | Belkin Computers & Internet
I just reset my dell computer back to factory setting. How do I now reset up for internet connection. My provider is verizon and I am using internet explorer
You want to reset your internet connection???
If yes then follow the given steps....
Step 1
Turn the modem so that the back of it is facing you. Locate the power supply cord connected to the back of the device.
Step 2
Gently unplug the power supply cord and leave it unplugged for about 10 seconds. If you also have a router connected to the modem, disconnect the power cord of the router as well.
Step 3
After about 10 seconds reconnect the DSL modem power cord. Wait for the status lights on the front of the unit to come on. They may blink at first before turning solid green, or they may first illuminate as orange, then turn green, depending on the modem model. The "Internet" and "Incoming" lights may continue to flicker, this is normal operation for modems.
Step 4
After the modem is reset, reconnect the router power supply if you have a router. Wait a few minutes before resuming normal Internet use.
If you need any kind of technical assistance you can contact support cell
Jan 19, 2013 | Computers & Internet
Router wont give out internet
If you have Checked ALL cables and rebooted both, ISP modem and router, contact the ISP and have the signal analyzed, have a ISP tech come out and verify the signal. It may be a outside equipment issue.
Jan 16, 2013 | Computers & Internet
My internet keeps disconnecting every night and I haft to reset the modem and router to get it to work for another day how do I fix this my router model is f9k1102v1
If you have Checked ALL inside cables, reseated ALL cables and rebooted the ISP modem, wait for selftest, plug in router wait for selftest, rebooted the computer. Contact your ISP to analyze the signal, have a ISP tech come out a verify the signal, it may be outside equipment.
N300 router has a steady orange blinking light
The blinking orange power light suggests that there is a problem with your modem. The modem should be plugged into the top ethernet port of your router. Try turning off your modem for 10 seconds and then turning it back on.
Dec 07, 2012 | Belkin Computers & Internet
WiFi router Linksys MD#WRT110 has stopped working .I now have an orange light on the reseved button
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first.
Jun 05, 2011 | Linksys BEFCMU10 Cable Modem Ethernet and...
I unplugged my Netgear wnr2000 one night, when I woke up in the morning and plugged it back in the on light went to the orange colour which kept flashing on and off and doesn't do anything else, normally...
You have lost your connectivity between modem and router.
Be sure you always start your network in this sequence:
1. Turn off and unplug the modem from the power outlet. Next, turn off the wireless router
and computer.
2. Turn on the modem and wait 2 minutes.
3. Turn on the wireless router and wait 1 minute.
4. Turn on the computer.
If this does not work, come back to your post let me know and we will try a full reset.
Oct 05, 2010 | NetGear WNR2000 Wireless Router
Jan 22, 2010 | Belkin (F5D5231-4) Router
The modem & internet lights on router are flashing orange. All other lights are solid blue. The Verizon DSL modem indicates it is working properly. Have re-set once. What do I do now?
Its your network that's causing connection problem!
1. Try to connect to your network after half an hour!
2. If the server is still busy, don't surf during peak hours! (surf @ night)
3. Change your ISP! (last solution)
Jan 02, 2010 | Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
