Question about Sony Tablet S 16GB 9.4" LED TruBlack WiFi Android Tablet - SGPT111
Red light flashing wont power Tablets - Sony Tablet S 16GB 9.4" LED TruBlack WiFi Android Tablet - SGPT111
Asus tablet zs800 won't turn on
Make sure the power cord is plugged into the computer and the wall and if it still wont turn on try wiggling the power cord connecter where it goes into the tablet .or hold the power button down and see if any lights flash on at all
Apr 21, 2017 | ASUS Tablets & eReaders
It wont turn on when charging the red light is on for abut 4hours and then turns green i unplug it and it wont turn on ive holding down the volume + and power button and still nothing
tablets are designed to be throwaway.
you can buy new batteries off ebay but replacing the battery will require cutting and soldering as the batteries in these tablets are soldered directly to the board and are stuck in place with glue and electrical insulating glass tape. Not a big job but fiddly and anyone with a soldering iron skill and basic leccie-tronics can do it.
it may be the battery - when you press the power button does the screen flicker or does the green power light come on.
pressing the power button whilst pressing the up or down volume button should take you into recovery mode - do this whilst the power block is plugged in - if the tablet shows signs of life with the power block plugged in you can be sure its the battery..
when tablets are vroken its usually by being dropped and this can cause the screen connector to come loose so you get no display but power lights will still be on.
Apr 26, 2015 | Nabi 2
When connected to charger red lights keeps flashing but tablet wont charge or switch on
Your dc socket is probably on its way out- soon it wont connect charge at all-bad future outlook on this- return if possible.
Mar 10, 2015 | Craig CMP741d Tablet
Etouch android wont charge
switch off.wait for 5 mins.
connect to pc or laptop with usb cable.
press & hold power button till it turns on then off.
press power button for 3 secs.it should work.
if no luck try this-
switch on by pressing power button while holding volume + and -.
keep hold of both until powers on.
can take few mins.
good luck!!!
Jun 27, 2012 | Tablets & eReaders
Kindle fire has red battery showing. I have charged it but it wont work
It may be the power cord but it is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it started flashing a red battery symbol this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
May 15, 2012 | Amazon Kindle Fire
Blackberry playbook red light flashes but it won 't turn on
this happened to me, it needs charging make sure the lead has the blackberry symbol facing up....
May 12, 2012 | RIM Blackberry Playbook 7Inch Tablet...
Wont power on
Most likely scenario is either the power supply or motherboard died. Check to see if the led near the main psu plug to the motherboard is green. If it is red or not on then more than likely the psu died. If the light to the mb is green then check your RAM and video card as those components going bad or coming unseated would also prevent the system from booting. Once you find the defective part replace with a new one and you should be back up ans running. Good luck & I hope this helps.
Jul 07, 2009 | Tablets & eReaders
Sony Tablet S 16GB 9.4" LED TruBlack WiFi Android Tablet - SGPT111 Logo
56 people viewed this question
Top Sony Tablets & eReaders Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Tablet and eReader Expert? Answer questions, earn points and help others
