Question about Microsoft Surface RT
How to delete photos in surface rt - Microsoft Surface RT
Is it possible to transfer pictures from a memory card to the surface rt tablet
Use either microSD card (Surface has a slot for this card), or SD card with USB adapter. This way it is easy to transfer pictures .
Oct 14, 2014 | Microsoft Surface RT
How do I shut down my Surface RT
if you do not mind loosing any data press and hold reset button for 30 seconds will set back to factory default settings or snap case open and try cleaning button surface where it connects
Jul 02, 2014 | Microsoft Surface RT
How do i get my RT to boot
Here are the steps to go back I factory setup. It will remove everything personal you have on the Surface - photos, docs, etc. They will still be in the Share drive if you utilized it for storage.
  1. Restart the device made for Surface.
  2. Press F8 during the initial BIOS post to bring up the Advanced Boot Options screen.
  3. On the Advanced boot options screen, use the arrow keys to highlight Repair your computer, and then press Enter.
  4. Select a keyboard layout, and then click Next.
  5. Type the user name and password of an administrator, and then click OK.
  6. Under System Recovery Options, select Reinstall Windows. This option will restore Surface to the factory image, and any customized user information will be lost.
  7. When the restoration of the factory image is complete, the device made for Surface will restart, and the setup process will begin. This process is identical to the first time you set up Surface; you will be guided by a series of prompts and dialog boxes.
One more note - if you deleted the restore folder to save drive space this will not work. You'll need to take to tech support.
Good luck.
Jun 23, 2014 | Microsoft Surface RT
How do i delete photos on my surface?
Using windows explorer go to the folder that has the photo,, right click on the file and choose delete,
Jun 13, 2014 | Microsoft Surface RT
How do i bypass password screen for microsoft surface rt
Microsoft Surface Microsoft Surface I have provided two links or you may call for help at 225-290-5733
May 21, 2014 | Microsoft Surface RT
Is there a way I can get my surface 2 to recognise the ANT pen drive for my Garmin Vivofit.
I assume it's not a surface PRO 2 but just a regular Surface 2. The surface 2 runs Windows RT which only runs specials apps designed for it. It can't run software that is made for regular Windows computers. Unless garmin creates specific software for Windows RT I'm afraid that it might never work.
You can attempt the software found here: http://download.garmin.com/omt/express/B/GarminExpressInstaller.exe but I doubt it works.
What you're trying to do it akin to runnign iPad apps on a Mac, it doesn't work before the architecture is different.
May 05, 2014 | Microsoft Surface RT
How do i delete photos/videos from the windows surface tablet rt
To delete a photo, go to your Pictures Library. Find the photos you want to delete. Then, just lightly touch the photo and swipe your finger down a little. This will select that photo, you will see a check in the upper right corner of the photo if you did it right. You can continue to select as many photos you want in this way. You will see the option to Delete at the bottom of the screen as soon as you select the first photo. To deselect the photo, just swipe it down again.
To delete a video, go to the Videos folder located on your Desktop and open it up. You can then select each video like you did for the photos. To unselect it, just touch the check mark which is on the top left corner. When you have finished selecting all the videos you want to delete, just click on the big red X on the top toolbar.
One note though - my directions are based on Windows 8.1, so make sure you have installed all your updates.
Hope this helps!
John
Apr 06, 2014 | Microsoft Surface RT
Youtube com
delete the old one password from settings menu then restart and give the new one your own gmail id and password.
Nov 21, 2013 | Microsoft Surface RT
Microsoft Surface RT Logo
887 people viewed this question
Top Microsoft Tablets & eReaders Experts
thetraveler
Level 1 Expert
Les Morrison
Les Morrison
Ruben Caraballo
Ruben Caraballo
Level 1 Expert
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
