Question about Broan-NuTone N-QT140L Combination Light Fan Exhaust Fan
Where do you find the broan-nutone n-qt140l?
Did the nu-ton qt140l get discontinued?
3 Suggested Answers
  • 95 Answers
SOURCE: broan nutone 721
If you remove the the lens there should be a model number online. There are several places online that sells parts. The 721 is a Broan part if yours says Nutone then you will need to try to find that model number.
www.nutone.com
https://www.centralvacuumstores.com/fan_help.php
www.rinutonedistr.com
Posted on Feb 18, 2009
  • 95 Answers
SOURCE: We have a Broan/Nutone 763RLN Ceiling Fan/Light in need of cleani
The grille is held in place by the reflector. The reflector is hidden by the the lens. The first step is to remove the lens, then you will remove the light bulb. You will see one wing nut above the light socket. If you unscrew that the reflector and the grille should come down. The replacement motor assembly for the 763 RLN is the S0503B000, if you are looking for a little more power you could also purchase the S0504B000
http://bit.ly/ax4Upk
Posted on Nov 19, 2010
Our exhaust fan is really noisy. Nutone QT 100N-B model. Where can we purchase a new one?
This model has been discontinued but replacement motor assemblies are available. There is no off the shelf model that will fit in the existing housing. If you do not want to replace the housing then the motor assembly is the way to go.
You ca purchase the replacement from either site below:
http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/0696B000-Motor-Assembly.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=qt100l&Search.x=0&Search.y=0
Jun 07, 2011 | Broan-NuTone QT100L Fan
I need the glass for a QT100L Nu Tone bathroom fan
The replacement NuTone lens number is 84449000.
http://bit.ly/bfmiYu
Oct 31, 2010 | Broan-NuTone QT100L Fan
I have a Nu-tone 8663 RP Combo fan and light. The unit has been a great unit for a good number of years. The fan is shot. Motor bearings I think. How can I get a replacement fan assy. ?
I just ordered a replacement fan motor for this same exhaust fan. I got it from here, http://www.electricmotorwarehouse.com/aosmith/nutone/nutone1.htm
It's this one,
1.2 amps, 115 volts 60hz
1550 RPM; Shaft 1/4" x 1"
Rotation = CCW
3.3" Diameter Motor
2 Mounting Studs Opposite Shaft End
Motor Case Length 1 15/16"
2-Prong 115 Volt plug
For Model 8663RP, 8673RP
8664RP (86933-000)
86933000, JA2B104N, JA2B104
can substitute 99080517
Part # 86933
$43.95
It's on the first page, and the 8th motor on the page at the time of this post. Hope this helps!
Oct 20, 2010 | Broan-NuTone N-8663RP Combination Light...
Fan is making ratteling noise.
pull off cover and check fan for a loose bearing. "will wobble if it has a loose bearing". if not a bad bearing then tap on moptor housing while on and be careful not to touch a fan blade. then replace cover in reverse. :)
Sep 21, 2010 | Broan-NuTone N-QT140L Combination Light...
I need a heating elament for my Braun model qtx100HL-A ceiling fan heater. I took it out and it is a 6260 eichen 120 v / 1425 watt
My Nutone Model 765HL uses the same heater; I tried the Broan-Nutone website but they were out of stock. Finally found it at Central Vacuum Stores for $35. Here's the direct link: http://www.centralvacuumstores.com/nutone/Broan-Nutone-Heater-Elements/QTXN-Series.php
Hope this helps!
Sep 06, 2010 | Broan-NuTone Heating & Cooling
Problems with exhaust fan NuTone Model LS 100SE
The fan/motor part of the Broan fan is replaceable. They are actually very simple to take out and install a new part.
The part can be easily purchase here...
http://parts.broan-nutone.com/broan/Shop
Heatman101
Feb 27, 2010 | Broan-NuTone N-LS100SE Exhaust Fan Exhaust...
Can the Nu Tone QTRN110 Exhaust fan be installed w/o access to attic? Mounting holes appear to be only on the flanges.
Before you put the metal box up make sure you have a couple of securely fastned pieces of wood there that the fan box will fit tightly between. Then put up the box and run screws through the metal box to hold the fan up. Then install the guts of the fan...
Heatman101
Feb 22, 2010 | Broan-NuTone Nutone QTRN110 Quiet Test 110...
Nu tone model QT-100N-B. looking for a replacement. Were can I buy 2 of them in sacramento, ca?
There is no replacement fan for that model that will fit in the existing housing. You can buy the replacement motor assembly.
You can buy these online and have them shipped to you:
or
http://www.centralvacuumstores.com/search/search.php?keywords=qt110&x=47&y=15&asug=
or
http://www.partstore.com/Part/Broan-Nutone%20Group/Broan/0696B000.aspx?s=froogle
Jan 07, 2010 | Broan-NuTone QT100L Fan
Exahaust fan not working
The best thing to do is buy the replacement motor. It is usually a pretty simple thing to change out and it sure beats having to take down the whole thing. Here is an article on finding the right motor. http://nutoneproducts.blogspot.com/2009/05/nutone-bath-fan-motor-replacement.html
Jul 12, 2009 | Broan-NuTone N-667RN Combination Light Fan...
Trying to remove service grill for Nutone QT140L combo fan/light
Yeah it takes a good push and a sharp tug to get them off if they've been there for awhile, they get greasy and stick, They sometimes bend a bit coming out but they're easy to staighten after you clean them. and yes they are one part.
Jun 02, 2009 | Broan-NuTone N-QT140L Combination Light...
Broan-NuTone N-QT140L Combination Light Fan Exhaust Fan Logo
Top Broan-NuTone Dryers Experts
Mike Squire
maddyveggie
Level 1 Expert
Are you a Broan-NuTone Dryer Expert? Answer questions, earn points and help others
